    [Plugin] follow me rotate
    211 Posts 79 Posters 259.7k Views 79 Watching
      @pep
      NO !
      You do NOT remove the CN suffixed version 😒
      Leave it where it is.
      It is actually the ENglish version within the CN wrapper, owing to a code typo by the author.
      So that CN version loads and works OK - giving ENglish menus rather than the ChiNese ones it was meant to make...
      In v2014 the EN has some ChiNese text which causes failures...
      So if you remove the EN version that error will stop appearing as SketchUp starts.
      The CN one loads and works OK on its own...
      BUT the EN one will always fail in v2014, so NOT having that EN one load just stops any related errors !
      • pep75P Offline
        pep75
        Sorry, will try it! Thanks!
          myskp99
          Hello mates, hope one can answer this:
          installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message:
          Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
          c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
          inp=Inputbox.new "±äÐθúËæ"
          -e:1:in `eval'
          hope some help, why does this happen?
          thanks
            -e:1:in `eval'
            thanks
            See a few posts back http://sketchucation.com/forums/viewtopic.php?p=530627#p530627 and then http://sketchucation.com/forums/viewtopic.php?p=531322#p531322
            One of the .RBS files inside the RBZ is wrongly encoded [in Chinese!], so if you delete it the other version will load and work OK... Note the error in the file naming that is confusing - remove the EN but keep the CN version...
            • gonashviliG Offline
              gonashvili
              Seems super.
              Does it work for a free v8?
              Can't seem to install this.
                @gonashvili said:
                Seems super.
                Please [re]read the post immediately before your own...
                http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                You need to access this plugin's folder inside Plugins, and then delete an RBS file - illogically the EN version is wrong! - keep the CN one... 😒
                  gonashvili
                  Oh I had it working, just couldn't find it in the menu at first, then forgot to delete my post.
                  Cheers 😄
                    alnahrini
                    Hi guys,,
                    i just installed it, but i have this error message
                    Note: am using sketchup 2016
                    Error: c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                    c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                    SketchUp:1:in `eval'
                    please can any one help me..
                    thanks in advance
                      @alnahrini said:
                      Hi guys,,
                      thanks in advance
                      Read TIG's post just a few up from yours.
                        pipinek
                        After installing the plugin on SU 2015 I have the following message on SU start:
                        Error: c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                        c:/users/artur/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                        c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                        I will be thankful for any solution to this issue.
                        Thank you in advance.
                          You might do the same thing I suggested in the post just above yours in response to the post before that in which the poster reported the exact same problem.
                          • I Offline
                            irminv
                            I installed the plugin, but I get an error message whenever I start SU.
                            also the plugin is not visible as a toolbar.
                            I have SU15 pro...
                              Reread this, about using the correct [but oddly named] version http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                                I have SU15 pro...
                                What makes you think there is a toolbar button that is missing? If you watch the tutorial video in the first post, you see it tells you the tool is accessed through the Plugins menu which is now called the Extensions menu.
                                  Albert95
                                  Hello wikii Is it possible to update "follow me and rotate" for sketchup 2017 ?
                                  console ruby
                                  Error: #<NoMethodError: undefined method curve' for nil:NilClass> c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:28:in wikii_push_pull'
                                  c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                                  thank you
                                  Albert
                                    Albert95
                                    Hello,
                                    I followed the advice of Tig : "Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu]."
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=13014%26amp;start=120#p530627
                                    But "FAR" does not work properly to model a rope.
                                    Can I get help
                                    thank in advance
                                    Albert
                                    follow-me and rotate in sketchup 2017
                                    • chriC Offline
                                      chri
                                      hi
                                      Same problem as Albert .
                                      I had trying after removing the "en" file but the plugin still does not work !
                                      The error message has disappeared but i don't see the plugin menu.
                                        @chri
                                        You do not seem to have actually removed the ..._en,rbs file as the error-message relates to that !
                                        To recap...
                                        There are two version of the plugin installed by the RBZ.
                                        The ..._en one loads in preference to the .._cn one,
                                        Perversely the .._en one has issues because of Chinese characters etc - so that needs removing [..._en.rbs] and the other one [with ..._cn.rbs ending] will be used loaded successfully...
                                        Note how the author has misnamed the two files before encrypting them !
                                        • BoxB Offline
                                          I'm not sure the plugin works properly on 2017 anyway.
                                          I installed it earlier and it was very flaky, (highly technical term).
                                            Works in the 2016! 😄
                                            Seems not yet in 2017 (even remove en .... )
                                            • 11
                                            • 9 / 11
