[Plugin] follow me rotate
Sorry, will try it! Thanks!
Hello mates, hope one can answer this:
installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message:
Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
inp=Inputbox.new "±äÐθúËæ"
-e:1:in `eval'
hope some help, why does this happen?
thanks -
-e:1:in `eval'
thanks
See a few posts back http://sketchucation.com/forums/viewtopic.php?p=530627#p530627 and then http://sketchucation.com/forums/viewtopic.php?p=531322#p531322
One of the .RBS files inside the RBZ is wrongly encoded [in Chinese!], so if you delete it the other version will load and work OK... Note the error in the file naming that is confusing - remove the EN but keep the CN version... -
Seems super.
Does it work for a free v8?
Can't seem to install this.
@gonashvili said:
Seems super.
Please [re]read the post immediately before your own...
http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
You need to access this plugin's folder inside Plugins, and then delete an RBS file - illogically the EN version is wrong! - keep the CN one...
Oh I had it working, just couldn't find it in the menu at first, then forgot to delete my post.
Cheers
Hi guys,,
i just installed it, but i have this error message
Note: am using sketchup 2016Error: c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
SketchUp:1:in `eval'please can any one help me..
thanks in advance
@alnahrini said:
Hi guys,,
Note: am using sketchup 2016please can any one help me..
thanks in advance
Read TIG's post just a few up from yours.
After installing the plugin on SU 2015 I have the following message on SU start:
Error: c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
c:/users/artur/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
SketchUp:1:in `eval'I will be thankful for any solution to this issue.
Thank you in advance. -
Thank you in advance.You might do the same thing I suggested in the post just above yours in response to the post before that in which the poster reported the exact same problem.
I installed the plugin, but I get an error message whenever I start SU.
also the plugin is not visible as a toolbar.
I have SU15 pro... -
Reread this, about using the correct [but oddly named] version http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
I have SU15 pro...What makes you think there is a toolbar button that is missing? If you watch the tutorial video in the first post, you see it tells you the tool is accessed through the Plugins menu which is now called the Extensions menu.
Hello wikii Is it possible to update "follow me and rotate" for sketchup 2017 ?
console ruby
Error: #<NoMethodError: undefined methodcurve' for nil:NilClass> c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:28:inwikii_push_pull'
c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:inblock in <main>' SketchUp:1:incall'thank you
Albert -
Hello,
I followed the advice of Tig : "Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu]."But "FAR" does not work properly to model a rope.
Can I get help
thank in advanceAlbert
hi
Same problem as Albert .
I had trying after removing the "en" file but the plugin still does not work !
The error message has disappeared but i don't see the plugin menu.
You do not seem to have actually removed the ..._en,rbs file as the error-message relates to that !
To recap...
There are two version of the plugin installed by the RBZ.
The ..._en one loads in preference to the .._cn one,
Perversely the .._en one has issues because of Chinese characters etc - so that needs removing [..._en.rbs] and the other one [with ..._cn.rbs ending] will be used loaded successfully...
Note how the author has misnamed the two files before encrypting them ! -
I'm not sure the plugin works properly on 2017 anyway.
I installed it earlier and it was very flaky, (highly technical term). -
Works in the 2016!
Seems not yet in 2017 (even remove en .... )
I've not tested it in v2017 - but if it is "flaky" it will now be unfix-able because its code is encrypted !
