    Copied components automatically tilted to remain flat on sur
    27 Posts 9 Posters 2.6k Views 9 Watching
      I don't know why it worked and then doesn't but you really should be setting up the rivet as a gluing component. You'd save yourself a lot of work.
      • hellnbakH Offline
        hellnbak
        Well, just tried that, doesn't seem to do anything different.
          Did you set it up correctly?
          • pbacotP Offline
            Only you can have done so much with SU while utilizing so few of the features. It's incredible, just like your modelling. It MUST have to do with gluing. Hope you figure it out soon.
            • hellnbakH Offline
              hellnbak
              Just read about gluing components here http://help.sketchup.com/en/article/114533
              Sooooo complex and confusing πŸ˜• Seems more straightforward to do it the way I have been.
              But then most things are confusing to me, that's probably just the problem.
              Thing is, it did automatically adjust the components to each new surface, just by copying and moving them. There has to be some explanation of why this happened.
              • hellnbakH Offline
                hellnbak
                As I said, I have never used gluing for any component. And when I checked my model, when I click on each of the components that were involved in this, the "unglue" option is greyed out - wouldn't this indicate that they were not glued?
                • hellnbakH Offline
                  hellnbak
                  Just watched a couple of videos on YouTube, much more helpful than that website. So I think I have it now, you can't just pick a glued component and copy it, you have to keep getting them from the component browser for this to work, right? That seems to be working.
                  • pbacotP Offline
                    yes maybe. If you look at the component in the component browser and select "edit" it should say.
                    Oh wait. I can make a component like that. First when you create a component on a surface,SU automatically makes it a gluing component. I did this, then went in and reset the "glue to: none" in the component window. Copy and paste, it still adjusted to the new surface, but "Unglue" was gray....How you did it IDK. Hmm, but subsequent use is sketchy.
                      slbaumgartner
                      Yes, glueing is a "behavior" tied to the component definition. It comes into play when you fetch a new instance from the component browser. As noted earlier, under certain circumstances it gets set by default when you create a new component (sort of like the "replace selection" checkbox). You have to pay attention or you might get one glued without knowing!
                      • hellnbakH Offline
                        hellnbak
                        I cannot remember the last time I used the component browser. But now that I know how to use the glue function, it will make some of my efforts much, much, much easier,
                        While at the same time making me very, very, very discouraged. All those wasted hours spent placing components by hand. Many wasted hours. I can't help but be discouraged knowing that my lack of knowledge about Sketchup has increased my difficulty level not only in this instance, but who knows how many other things have been needlessly complicated and time consuming simply because I just don't know how to do them the way they should be done.
                        • BoxB Offline
                          Next time you are doing something that seems painfully tedious, post it and see how others would do it.
                          • emerald15E Offline
                            emerald15
                            @hellnbak said:
                            who knows how many other things have been needlessly complicated and time consuming simply because I just don't know how to do them.
                            Well, I hadn't realised how much more helpful it would be to glue components either. I knew it was a option... just didn't take the time to explore it!
                            However, we never stop learning. If I hadn't read this thread... I wouldn't have learnt this technique. Hope that makes you feel a little better?
                            PS. perhaps we should now be call it 'rivet' not 'glue'! πŸ˜„
                              I'm also surprised at how much you've done with so little. It makes me a little sad, though, because it means you've been working much harder than you need to.
                              In addition to adding the gluing behavior, you should think about where to put the origin so that you can easily direct the insertion of the component. Look at this video. The first part of the video shows inserting a component that has gluing behavior set and the insertion point located so the component goes exactly where it is wanted.
                              It seems to me someone (probably TIG) wrote a plugin a long time ago that obviates the need to go back to the component browser each time. It would certainly be useful for placing your rivets.
                              • Bob JamesB Offline
                                Bob James
                                @Dave R
                                What plugin is this?
                                  Bob, it's the Wudworx toolset. From the top, Dovetails, Mortises and Tenons, Boardmaker and Drill. I mostly use the Dovetail and Drill tools out of that set.
                                    Bob James
                                    Thank you, Dave. In the video the drill seemed to be being used to "clean out" a cylindrical countersink around the component.
                                      Bob, the Drill tool can make straight sided holes, counterbored holes and countersunk holes and can even make arrays of holes. In the video I made the holes after placing the bolts because the gluing plane was placed at the top of the head so they would sit flush with the surface of the part. The bolts would have been difficult to put in place like I wanted them if there was no surface under the guidepoint. I already had the dimensions for the counterbored holes set for the tool so I didn't need to call up the settings window before drilling.
                                      • andybotA Offline
                                        andybot
                                        I use gluing all the time with stuff like windows. The trick is, you can copy it from one face to another and keep the "glue" behavior, but it can be kind of hit or miss. If you are snapping to an edge, most often, it will NOT glue. If you just move "by eye" from one face to another, then it does most often glue. That's the way I usually do it, and then I go back and align by moving to relative alignment points (like I have to move a window up slightly to match the previous window heat height.) If I have time, I could do a quick video.
                                        The other thing, stuff becomes automatically a glued component if you draw it on a face then make a group out of it. No need to use component browser at all for either of my points of advice. πŸ˜„
                                        Andy
                                        • hellnbakH Offline
                                          hellnbak
                                          Dave, I have tried to locate the plugin you mentioned, but no luck. I stopped visiting the plugin thread a loooonnnngggg time ago, just got too frustrating with all the plugins that sounded so fantastic but knowing that I probably wouldn't be able to use the dang things right. The thread has changed a lot since then.
                                          I did come across a few that sounded promising, I'll check them out later.
                                          Anyhow, any idea how I might find that plugin?
                                          I ask because I've not had a whole lot of luck with gluing my rivets and I'm working on several models that have approximately a bazillion of them.
                                          Thanks in advance for any help you can provide.
                                          • JQLJ Offline
                                            JQL
                                            The fastest way to create one is drawing a closed shape in a face, without touching any edge.
                                            (Design on Face and not on Group/Component)
                                            The fastest way to copy one around is using the face where it is glued as reference for the copy.
                                            (Reference the point from the face outside the Gluing Component, and never from a point inside of the component)
                                            This is because the reference point you pick for copying the component MUST be in the same plane that it's glued into.
                                            (sometimes this plan is easy to find even inside the component, most times it's better to find it in the face it's glued to.)
                                            Take a look at the gif:
                                            Last but not least Superglue plugin is a Must have plugin for a Gluing and ungluing sets of components.
                                            www.casca.pt
                                            Visit us on facebook!
