    Sketchup modelin problem
    18 Posts 7 Posters 1.9k Views 7 Watching
    • cottyC
      cotty
      What's playup?
      Is the triangulate all faces checkbox active in the fbx-export options?
      my SketchUp gallery
        MistahGrizzly
        playup is plugin for exporting models to cryengine
          MistahGrizzly
          after checking the triangulate all faces is happen this on maya and 3dmax
            MistahGrizzly
            any suggestions on fixing the model ?
              Maybe some faces are "reversed" inside SU !
                MistahGrizzly
                why when check to show hidden geometry is not showing nothing ? 😞
                  MistahGrizzly
                  i think i find solution with obj exporting
                  • K
                    kaas
                    Because there's apparently nothing to show. In short:
                    • In SketchUp, even irregular planes (like a wall with a hole for a window) can be just 1 element. Sometimes it's not and 'show hidden geometry' will reveal something.
                    • In most 3d programs, these kind of shapes can't be made as just 1 element. They are internally split up into an assembly of triangles (like in your first picture).
                    To speed up resolving your problem:
                    • what kind of export format do you use from SketchUp? fbx? obj? something else?
                    • in what program are you viewing the 3d model? CryEngine? something else?
                    • can you add / post your sketchup model so we can have a look at it?
                    • kimi kimiK
                      kimi kimi
                      If I understood you correctly, you are importing this into 3ds Max (and Maya) from SketchUp? In skp you don't have triangles, but they do appear in Max? You also mentioned enabling "triangulate all faces" in export options. First, try turning that off. And the best way to import a .skp file into 3ds Max, in my experience, is either by saving it as version 06 and then directly importing that .skp file, or, export it to .3ds format and then import it.
                        MistahGrizzly
                        in the sketchup the model is clear nothing wrong but when i export in fbx file in 3d max i can't remember how look when i import it but in maya is black model with many edges/lines/triangles,but now with obj file is better maybe the fbx exporting is not working well in sketchup
                        in sketchup
                          MistahGrizzly
                          nope still not working 😞
                          • oceanembersO
                            oceanembers
                            Well you can make it not black in maya by reversing the normals (in 2016 I think it's mesh display -> reverse faces), if that actually matters. As for the triangles, they shouldn't make a difference to your end result. I suspect you just need to apply a material in cryengine and like... deselect the object to stop the edges from showing up?
                            • Jean LemireJ
                              Jean Lemire
                              Hi folks.
                              If you have SU Pro, you can export from SU as dwg then import the dwg into a new empty model while specifying "Merge coplanar faces" when importing. This shall eliminate all this triangulation.
                              Just ideas.
