    Live Edge Slab
    10 Posts 8 Posters 2.1k Views 8 Watching
      This is a bench with a claro walnut live edge slab for the seat. I drew the slab at the request of a woodworker who wanted to know if it could be done. I guess it can be. Actually, thanks to TIG's Image Trimmer, it's a walk in the park.
      • BoxB Offline
        Very nice.
          davidheim1
          And a good tutorial about using the plug-in on the "Design.Click.Build" blog on finewoodworking.com.
          Best,
          dh
          • cottyC Offline
            cotty
            Best,
            dh
            Yes, it's certainly worth a link:
            http://www.finewoodworking.com/item/120817/drawing-a-live-edge-slab
            πŸ‘
            my SketchUp gallery
            • HornOxxH Offline
              HornOxx
              Dave - a great "walk in the park"! πŸ‘
              Thanks Cotty for this Explanation link.
              Thanks Tig, again for this very useful tool.
              (I did not recognize this great "Image Trimmer" feature so far)
              never trust a skinny cook
                Thank you all.
                • daleD Offline
                  dale
                  Masterful as usual Dave. Can't tell you all I have learned from you.
                  • Rich O BrienR Online
                    beautiful!
                    • pbacotP Offline
                      So realistic! And pretty too. How did you render it?
                        Thank you, gentlemen.
                        Dale, surely you can tell. It isn't a secret. πŸ˜„
                        Peter, the rendering was done in Kerkythea. The "set" is just a large rectangle. No walls or ceiling. Two lights inserted via SU2KT. I used a plastic material preset to get the glossiness of the wood and I used the texture for the slab as a bump map and set the strength to 0.25. It's probably wrong but whenever I want to add a little bump, I just use the texture image for the map. Seems to work fine. Rendered at preset 7 or 8. I forget which. Easy setup and quick render.
