πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Live Edge Slab
10 Posts 8 Posters 2.0k Views 8 Watching
    This is a bench with a claro walnut live edge slab for the seat. I drew the slab at the request of a woodworker who wanted to know if it could be done. I guess it can be. Actually, thanks to TIG's Image Trimmer, it's a walk in the park.
      Very nice.
        davidheim1
        And a good tutorial about using the plug-in on the "Design.Click.Build" blog on finewoodworking.com .
        Best,
        dh
          cotty
          Best,
          dh
          Yes, it's certainly worth a link:
          http://www.finewoodworking.com/item/120817/drawing-a-live-edge-slab
          πŸ‘
          my SketchUp gallery
          • H Offline
            HornOxx
            Dave - a great "walk in the park"! πŸ‘
            Thanks Cotty for this Explanation link.
            Thanks Tig, again for this very useful tool.
            (I did not recognize this great "Image Trimmer" feature so far)
            never trust a skinny cook
              Thank you all.
                dale
                Masterful as usual Dave. Can't tell you all I have learned from you.
                  beautiful!
                    So realistic! And pretty too. How did you render it?
                      Thank you, gentlemen.
                      Dale, surely you can tell. It isn't a secret. πŸ˜„
                      Peter, the rendering was done in Kerkythea. The "set" is just a large rectangle. No walls or ceiling. Two lights inserted via SU2KT. I used a plastic material preset to get the glossiness of the wood and I used the texture for the slab as a bump map and set the strength to 0.25. It's probably wrong but whenever I want to add a little bump, I just use the texture image for the map. Seems to work fine. Rendered at preset 7 or 8. I forget which. Easy setup and quick render.
