    Installation of .rb plugins in 2014 and 2015
    17 Posts 6 Posters 8.9k Views 6 Watching
    • sfto1S Offline
      sfto1
      No luck, It's not that critical either. Thanks for the help.
        Check your PMs.
        • sfto1S Offline
          sfto1
          Notepad
            Hmmm.....
            • BoxB Offline
              @dave r said:
              Check your PMs.
              It's about defcon two at the moment and if I don't cook her dinner soon who knows where it will end up..
                I knew you'd be along.
                  I also confirm that making that simple change to the end of the code should make it load [under the View menu !] and it works fine...
                  • sfto1S Offline
                    sfto1
                    Thank you to all. Dave R helped get it straight.
                    • DDKD Offline
                      DDK
                      trying to figure out how to add this rb file, its not showing up in the install list but is in my downloads .... I don't know code so im not changing it.. can anyone help with newb terms? πŸ˜•
                        What rb file?
                          driven
                          @ddk said:
                          trying to figure out how to add this rb file, its not showing up in the install list but is in my downloads .... I don't know code so im not changing it.. can anyone help with newb terms? :?
                          there is no 'auto-instal' for any .rb files, only .rbz...
                          notice the 'z', it's stands for 'zipped', so if you 'zip' any .rb then rename it's extension from .zip to .rbz, it will appear in the add extension list...
