    Installation of .rb plugins in 2014 and 2015
    17 Posts 6 Posters 9.0k Views 6 Watching
      I installed the plugin after editing it and it showed up for me and it seems to work just fine. Did you edit the text exactly as shown and restart SketchUp after saving the file? What program did you edit in?
      • sfto1S
        sfto1
        No luck, It's not that critical either. Thanks for the help.
          Check your PMs.
          • sfto1S
            sfto1
            Notepad
              Hmmm.....
              • BoxB
                @dave r said:
                Check your PMs.
                It's about defcon two at the moment and if I don't cook her dinner soon who knows where it will end up..
                  I knew you'd be along.
                    I also confirm that making that simple change to the end of the code should make it load [under the View menu !] and it works fine...
                    • sfto1S
                      sfto1
                      Thank you to all. Dave R helped get it straight.
                      • DDKD
                        DDK
                        trying to figure out how to add this rb file, its not showing up in the install list but is in my downloads .... I don't know code so im not changing it.. can anyone help with newb terms? πŸ˜•
                          What rb file?
                            driven
                            @ddk said:
                            trying to figure out how to add this rb file, its not showing up in the install list but is in my downloads .... I don't know code so im not changing it.. can anyone help with newb terms? :?
                            there is no 'auto-instal' for any .rb files, only .rbz...
                            notice the 'z', it's stands for 'zipped', so if you 'zip' any .rb then rename it's extension from .zip to .rbz, it will appear in the add extension list...
