    1.5k Posts 471 Posters 3.4m Views 470 Watching
      @runningutes said:
      Getting a strange result after installing the rounded corner extension in Sketchup 2015.
      I created a square, selected one edge, and ran the extension. The edge I selected is gone and instead I get this image below.
      This is the first time using the extension
      Any tips or help?
      https://dl.dropboxusercontent.com/u/3238476/roundcorners1.jpg
      You say you made a square but I think you mean a cube? It looks as if you have the Offset (radius) value set too large. The setting you used for the radius is 1000mm but your cube can't be anywhere close to that size. Try changing the Offset to something small enough that it fits your cube.
      Edit:
      I duplicated your results by setting the radius much larger than the cube.
      With a more appropriate setting, it rounds the edge as expected.
      Take some time to read the instructions in the first post of this thread. There is also a PDF reference file available.
      • N Offline
        Noemi
        Hello!, i tryed to install roudedcorners directly through Sketchucation pluging stores, after instslling freddo library, and it appears this when autoinstall: ( inside a box)
        You can Write to the Main Plugins Folder, and...
        You have a Custom-Plugins Folder.
        C:/ Users/noemi/appdata/roaming/sketchup/sketchup2015/sketchup/plugins
        c:/ Programdata/sketchup/sketchup2015/sketchup/plugins
        i don't find this folder and don't know what does it mean... should i create another folder, what should i do? thanks for any help!
        • fredo6F Offline
          NEW RELEASE: RoundCorner v3.0a - 09 Jul 15
          RoundCorner 3.0a is refresh of this now old plugin.
          The main evolutions are related to the User Interface:
          1. Updated button palette, separating the buttons in 4 areas: Edges selection, Parameters, Edge properties and Geometry Generation.
          2. Post-modification: You can now modify the parameters after the generation of the geometry without reselecting edges. When one or several parameters are changed, you can apply to the previous generation by clicking on “APPLY CHANGE”. As soon as you select an edge, this option is no more available and the parameters will apply to the next generation.
          3. Detection of Overlaps: RoundCorner now detects the situations of overlaps and show them in Preview mode and display a warning message before generation of the geometry.
          4. Edge properties: there is an additional control for edges bordering the corners.
          • massimoM Offline
            massimo Moderator
            Thank you very much for this update Fredo.
            This is a great new feature and a huge time saver. 👍
            • pbacotP Offline
              This may be the paragon of your plugins, Fredo, which are all superb at that. A hugely useful and essential tool that only gets better and more refined over time!
                jcyber
                Thank you so much fredo6
                • fredo6F Offline
                  NEW RELEASE: RoundCorner v3.0b - 17 Jul 15
                  RoundCorner 3.0b fixes a major bug preventing the plugin to launch for Sketchup 2013 and earlier versions.
                  So it is IMPORTANT to upgrade to v3.0b if you run these versions of Sketchup.
                  Sorry for inconvenience
                  • Z Offline
                    z200121
                    Yep with little measures that splatting soon as Enter!
                      No a very clear comment 😒
                      If you mean that using very small dimensions causes a BugSplat, then this a well know limitation of SketchUp -both in SketchUp's native tools and many Plugins...
                      Models with edges [and any faces they might support] < 1/1000" long can 'exist', BUT they cannot be 'created' - this is because at that size the tolerance built in to SketchUp means that it takes the edge's start/end points to be coincident.
                      The work around is to scale the geometry up x100 or more, do the intricate creation and scale back down afterwards.
                      As I said - the tiny geometry can exist, but it cannot be created...
                      • dereiD Offline
                        derei
                        @tig said:
                        ...can exist, but it cannot be created...
                        Use this as your motto, is cool ! 😄 💚
                        DESIGNER AND ARTIST DEREI.UK
                          littleche
                          its great ! thanks fredo .
                          • DDKD Offline
                            DDK
                            One of the best plug-ins ever, thank you!!! makes my models look more realistic. the best part of this is it keeps the faces grouped as one. cheers keep making more 😄
                              kashiu
                              Hi fredo
                              I have the su2015 & Im interstate in the round corner pouring, can you help me?
                                littleche
                                HI
                                I Have problem with this model . round corner can't rounding this model and recive overlab error.
                                How can I fix this problem?
                                P & P.skp
                                thanks
                                • fredo6F Offline
                                  @littleche said:
                                  HI
                                  thanks
                                  Unfortunately, with the current algorithm, this is not possible.
                                  At the sharp corner, you have edges which are smaller than the offset.
                                    littleche
                                    @fredo6 said:
                                    @littleche said:
                                    HI
                                    thanks
                                    Thank you fredo . You are always trying to develop this plugin.And I thank you very much.If you are not a thing of SketchUp shortage!
                                    I hope you can fix algorithm in the next version .Always sincerely pray for your success...
                                    • W Offline
                                      Will C
                                      I've been using this plugin for a while now and it's pretty awesome. Makes curving edges a lot faster with less frustration. Thanks for making this.
                                        Tony2015
                                        thx fredo
                                        • bac9-flclB Offline
                                          bac9-flcl
                                          @fredo6
                                          Is it possible to fix the chamfer process failing on such a corner?
                                          http://i.imgur.com/EuaXGhj.png
                                          It's pretty much impossible to avoid places like those in serious quad-based hardsurface modeling, and other chamfering implementations (in 3ds Max, Maya, etc.) never had issues with topology like that, so I'm not sure if anything really prevents proper chamfering here. Typically, corners like those are simply resolved like this:
                                          http://i.imgur.com/8UUbDRJ.png
                                          • fredo6F Offline
                                            Not possible with the current algorithm.
                                            Would require another technique, which I may implement one of these days.
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 70 / 74
