    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • T
      TraxXx
      Any suggestion concerning my problem ?
        Have you tried reading the usage notes.
        Perhaps you have a setting that ignores the selection ?
        Perhaps posting a screenshot or two would elicit more help...
        • T
          TraxXx
          I'm having the same issue as urban journey, this is pretty much what it looks like, but with grass
          • cottyC
            cotty
            Maybe the component axes are misplaced?
            my SketchUp gallery
            • T
              TraxXx
              Well I've checked the components axis but it seems normal. That wouldn't explain why they are dispatched all over the scene anyway... It seems like it's gonna stay a mistery ! 😞
                AMANI1805
                How do I install this to my Google SketchUp Plugin? I tried putting the file under my plugins folder but that doenst seem to work. Help please?
                  Please learn the SketchUp basics - like installing Plugins...
                  The RBZ is an archive containing the file[s] [and perhaps subfolders of support files] needed by a particular script.
                  Virtually all Plugins (and Extensions [just a more complex form of plugin]) come packaged in RBZ archives.
                  For example, those in the SketchUcation and ExtensionsWarehouse...
                  An RBZ does NOT belong in the Plugins folder - move it back into your Downloads folder...
                  Since the release of SketchUp v8M2 there has been a native tool provided to install these tools from their RBZ archives.
                  SketchUp menu, Window > Preferences > Extensions > Install... button
                  Find the RBZ and after answering in the affirmative to the installer's dialog[s], the Plugin is installed automatically for you into your Plugins folder, and it loads.
                  Thereafter, it will load whenever SketchUp starts.
                  If you have v8 and it refuses to install then you need to adjust your Permissions to the Plugins folder inside the SketchUp folder...
                  Properties > Security > Edit... ALL those listed need FULL permissions ticked... Apply/OK.
                  • Y
                    yjinbs21
                    Where Fur for sketchup 2015 64bit?
                    • cottyC
                      cotty
                      From the first post of this topic:
                      @tak2hata said:
                      DOWNLOAD HERE
                      Get the latest version from the PluginStore:
                      http://sketchucation.com/resources/pluginstore?pln=fur_en
                      or AutoInstall from within SketchUp using the SketchUcation Tools
                      This version is SU 2015-64 compatible...
                      my SketchUp gallery
                        alvro
                        Does the plugin work on windows 8.1? I tried to install several versions on SU14 and SU15 and always makes the same error: Error: #<Encoding::UndefinedConversionError: "\x81" to UTF-8 in conversion from Windows-1252 to UTF-8>
                        Any help?
                        • Z
                          zcaalock
                          I have same problem as most of people here: when am using component as source the thing spreads out everywhere. I went through the whole threat and no solution, cannot see any flags to set it up and component axis are set same to rectangle where i want to place the grass.
                          Any help?
                          http://s16.postimg.org/unpg6eqdh/grass.png
                            muchomurka2
                            wow,thx!
                              Sejoe
                              This plugin doesn't working on version 2015 always giving error
                                It works for others with SketchUp 2015.
                                Saying "always giving error" but not sharing the error message makes it impossible for anyone to help you if that's what you want. Share the error and you will get some assistance.
                                  Yes works fine for the 2015 & 2016! 😎
                                    Sejoe
                                    This is my make fur error what can i do for this?I uninstalled program and installed two times but nothing changed,please help...
                                    my make fur error
                                      This looks like a UTF8 issue with SketchUp's Ruby file-path reading...
                                      There are ways of sidestepping this in the newest Ruby - not always invoked.
                                      So these might not have been effected in this tool's code.
                                      Your Windows user-name seems to be "ADMİN" [I assume that's Turkish (Türk) with a dotted 'I' ?] rather than the immediately acceptable "ADMIN".
                                      Accented characters in user-names are very well known for causing issues like this...
                                      But newer Plugins, which ought to use the latest Ruby methods, can often sidestep these problem...
                                        marcodallago
                                        I have a problem.. I need to create grass in the green area of the image, so that will look the walkway emerge from the grass. But how can i do? With your plugin grass elements come out from the path and this is not what I want. Is there a workaround?
                                        • majidM
                                          majid
                                          فایل آپدیت زبان فارسی
                                          Here is the updated Persian ( Farsi ) language file
                                          در مسیر فایلهای زبان پلاگین بریزید
                                          مثلا
                                          C:\Users"User name"\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugin
                                            sexypox69
                                            I too had the issue of selecting a surface and when I make fur it would be scattered everywhere except the selected surface. After changing the axis of my proxy that seem to solve the issue. I the tutorial i watch it showed the changing of the axis of the component but not to the proxy created with it. I guest when I changed component to a proxy it changed the imput axis....well this is what worked for me...Im a bit lost when it comes to these things
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 32 / 33
