    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.2k Views 135 Watching
    • JQLJ Offline
      JQL
      Well what was your point exactly?
      www.casca.pt
      Visit us on facebook!
      • BoxB Offline
        Which proved my point, the follow me reacts differently if the profile is grouped rather than the path being grouped. The origin axis comes into play when the path is grouped.
        So my original assertion that odd things occur when you group the path is true.
        Also my original model was orthographically correct and shows the relationship between the global axis and the group axis. If I did the follow me the other way it would have produced a sphere.
        Moving the axis of the path solves the problem but is unrelated to the original post.
        I simply pointed out that while Carsten was showing something that works beautifully one way it doesn't work the same way when reversed.
        I'll add this for luck.
        • JQLJ Offline
          JQL
          Duh!
          www.casca.pt
          • pmolsonP Offline
            pmolson
            Did you know
            When you have a group open and everything else is faded away and hard to see you can click on the
            (use sun for shading button check box) and the rest of the model is then clear to see.
            I like this option for when I want to reference my open group to other parts of the model.
            • cottyC Offline
              cotty
              πŸ‘
              In addition, you can influence this here furthermore...
              my SketchUp gallery
              • pbacotP Offline
                Just came across the follow me showdown. Maybe cause I'm coming off a cold ...I'm confused. Would be nice to know the best practice for other than circle paths. I have always thought it was a hassle needing to have the objects in the same context...but now I find you don't . Duh!!!
                • icedkaszI Offline
                  icedkasz
                  Just discovered that ctrl+shift+V pastes in place. Didn't know that for 3 versions. I've made messes out of contour maps by being millimeters off.
                  • cottyC Offline
                    cotty
                    In the preferences, you can switch those two and use Ctrl+V for paste in place and Ctrl+Shift+V for simple pasting (I'm using pasting in place much more often).
                    my SketchUp gallery
                    • Bob JamesB Offline
                      Bob James
                      You're not alone
                      • JQLJ Offline
                        JQL
                        @bob james said:
                        You're not alone
                        I never found that myself because that was exactly the shortcut I used with V8. As I always imported shortcuts I thought that was exclusively my command... I guess that counts as a Duh!
                        www.casca.pt
                          Oh - wait - that shortcut is now out of the box?
                          • JQLJ Offline
                            JQL
                            It isn't? I always export/import it before I try it... so how would I know?
                            It seems this will get some more duhs!
                            www.casca.pt
                              I'm glad it's now a default - as it's the first shortcut I ever set up. (Though I also import so I missed this.)
                              • pbacotP Offline
                                I set mine to just shift-v long ago and didn't know the default setting. Oddly I made so it is opposite of CAD, instead of changing the regular paste short-cut-- if that makes sense, so really I keep switching from one program to the other. Why am I writing this? Sitting here on first cup of coffee just killing time that I will want for later on...
                                • jiminy-billy-bobJ Offline
                                  jiminy-billy-bob
                                  Are you sure?
                                  Not on my PC. No shortcut is assigned to Paste in Place.
                                  • JQLJ Offline
                                    JQL
                                    That was the sneaky suspicion I had.
                                    www.casca.pt
                                      Maybe someones don't know this one! πŸ˜„
                                      Very uggly speedy test, it was just for see if that is working! πŸ˜’
                                      That's work fine! 😎
                                      Power of the "<>"! πŸ‘
                                      http://s6.postimg.org/bjkgz3tg1/text.gif
                                      • Wo3DanW Offline
                                        Wo3Dan
                                        And \n for line feed
                                        So when you have a dimension value 2500mm, adding \nceiling height results in:
                                        2500mm
                                        ceiling height
                                        (plain text, not associated anymore with changes in geometry)
                                        But replacing 2500mm by <>\nceiling height becomes:
                                        2500mm
                                        ceiling height
                                        (text with value following changes in geometry)
                                          Thx for the Info! β˜€
                                            Bob James
                                            @bob james said:
                                            @jql said:
                                            Apologies accepted if you post it on the Duh thread!
                                            So here goes my duh:
                                            @bob james said:
                                            This seems so simple that it must already exist, but I could not find it.
                                            For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
                                            I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
                                            I apologize if this already exists
                                            @jql said:
                                            LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
                                            Or you can make your life painless if you draw a 4 sided polygon without exploding it.
                                            Those two are native tools. Do you forget sketchup also has native tools?
                                            Your suggestions create 45 deg rotated squares.
                                            Why can't someone just make a simple extension to make an orthogonally positioned square starting from a center point?
                                            • 34
                                            • 35
                                            • 6 / 35
