    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • BoxB
      I am preparing my eggs for the sucking lesson.
      • JQLJ
        JQL
        You have to center the axis inside the circle group prior to follow me.
        www.casca.pt
        Visit us on facebook!
        • JQLJ
          JQL
          Sh** I'm doing it right now in several ways, but can't gif it!!!!
          www.casca.pt
          • JQLJ
            JQL
            wait a moment... changing computer!
            www.casca.pt
            • BoxB
              I think you have made my point for me. If the profile is in a group it causes a different result because it relates the group axis to the global axis. But if the profile is in a group it simply uses the group Axis.
              QED
                #handbags
                • BoxB
                  at forty paces!
                  • JQLJ
                    JQL
                    Well what was your point exactly?
                    www.casca.pt
                    • BoxB
                      Which proved my point, the follow me reacts differently if the profile is grouped rather than the path being grouped. The origin axis comes into play when the path is grouped.
                      So my original assertion that odd things occur when you group the path is true.
                      Also my original model was orthographically correct and shows the relationship between the global axis and the group axis. If I did the follow me the other way it would have produced a sphere.
                      Moving the axis of the path solves the problem but is unrelated to the original post.
                      I simply pointed out that while Carsten was showing something that works beautifully one way it doesn't work the same way when reversed.
                      I'll add this for luck.
                      • JQLJ
                        JQL
                        Duh!
                        www.casca.pt
                        • pmolsonP
                          pmolson
                          Did you know
                          When you have a group open and everything else is faded away and hard to see you can click on the
                          (use sun for shading button check box) and the rest of the model is then clear to see.
                          I like this option for when I want to reference my open group to other parts of the model.
                          • cottyC
                            cotty
                            πŸ‘
                            In addition, you can influence this here furthermore...
                            my SketchUp gallery
                            • pbacotP
                              Just came across the follow me showdown. Maybe cause I'm coming off a cold ...I'm confused. Would be nice to know the best practice for other than circle paths. I have always thought it was a hassle needing to have the objects in the same context...but now I find you don't . Duh!!!
                              • icedkaszI
                                icedkasz
                                Just discovered that ctrl+shift+V pastes in place. Didn't know that for 3 versions. I've made messes out of contour maps by being millimeters off.
                                • cottyC
                                  cotty
                                  In the preferences, you can switch those two and use Ctrl+V for paste in place and Ctrl+Shift+V for simple pasting (I'm using pasting in place much more often).
                                  my SketchUp gallery
                                  • Bob JamesB
                                    Bob James
                                    You're not alone
                                    • JQLJ
                                      JQL
                                      @bob james said:
                                      You're not alone
                                      I never found that myself because that was exactly the shortcut I used with V8. As I always imported shortcuts I thought that was exclusively my command... I guess that counts as a Duh!
                                      www.casca.pt
                                        Oh - wait - that shortcut is now out of the box?
                                        • JQLJ
                                          JQL
                                          It isn't? I always export/import it before I try it... so how would I know?
                                          It seems this will get some more duhs!
                                          www.casca.pt
                                            I'm glad it's now a default - as it's the first shortcut I ever set up. (Though I also import so I missed this.)
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
