    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Moopingkrupdesign
      thank you
        TraxXx
        Hi !
        This is such a great plugin but I'm just having troubles to make a grass area by spraying a proxy grass made previously. I've tried different size of proxy, even a little sized bunch of grass but I still don't understand why sketch up is spreading my proxy everywhere in the scene (even on different heights). No matter what area I selected on my mesh (google earth terrain) it doesn't stick grass proxy to it but does a big crow all over my scene. Is that anything related to the fact i'm trying to apply it on a mesh, I saw a russian using "make fur" with proxy on a handmade mesh and he could apply it without troubles. I'm stuck with that, could you help me ? thanks ๐Ÿ˜„
          marvsweden
          I've read the documentation and this whole thread but I still can't get my head around the axis configuration.
          I have this component
          and I want the flag's front face facing the camera but all I get is this
          If i fiddle with direction and force I can kinda close to what I'm aiming for
          but the flags are tilted and I still think that I'm missing something here. Can anyone see what I'm doing wrong?
          Thanks guys!
          • TIGT Online
            There is a degree of randomness in the Fur component-placement settings.
            You need to play with that to get near what you want.
            Alternatively look at the 'ComponentSpray' plugin, with appropriate settings it should also do what you want.
            To make all of your component-instances 'face' the same way, you could select them and run a snippet in the Ruby Console. Something like:
            m=Sketchup.active_model;s=m.selection.grep(Sketchup;;ComponentInstance).select{|i|i.definition.name="MyFlag"};m.start_operation("!");s.each{|i|t=i.transformation;x=t.xaxis;a=X_AXIS.angle_between(x);v=x.cross(X_AXIS);v=Z_AXIS if v.length==0;i.transform!(Geom;;Transformation.rotation(t.origin,v,a))};m.commit_operation;
            Replace the component's name with the actual one!
            This is one step undo-able.
              marvsweden
              Thanks TIG. That sounds like a sofisticated way. Never ran anything from the Ruby console. I'll give it a try.
              I did however use the make crowd option and found it to produce a somewhat more pleasing result.
              • U Offline
                urban journey
                Hi guys,
                This plugin has absolutely changed my life with Sketchup being a landscape designer, i use it all the time.
                I do have a similar problem though to a previous poster and couldn't see a solution from reading through. Essentially, i select an area, a grass component and then generate and it throws components outside the selected area - see screenshot showing this and my Fur settings....
                  TraxXx
                  Any suggestion concerning my problem ?
                  • TIGT Online
                    Have you tried reading the usage notes.
                    Perhaps you have a setting that ignores the selection ?
                    Perhaps posting a screenshot or two would elicit more help...
                      TraxXx
                      I'm having the same issue as urban journey, this is pretty much what it looks like, but with grass
                      • cottyC Offline
                        cotty
                        Maybe the component axes are misplaced?
                        my SketchUp gallery
                          TraxXx
                          Well I've checked the components axis but it seems normal. That wouldn't explain why they are dispatched all over the scene anyway... It seems like it's gonna stay a mistery ! ๐Ÿ˜ž
                            AMANI1805
                            How do I install this to my Google SketchUp Plugin? I tried putting the file under my plugins folder but that doenst seem to work. Help please?
                            • TIGT Online
                              Please learn the SketchUp basics - like installing Plugins...
                              The RBZ is an archive containing the file[s] [and perhaps subfolders of support files] needed by a particular script.
                              Virtually all Plugins (and Extensions [just a more complex form of plugin]) come packaged in RBZ archives.
                              For example, those in the SketchUcation and ExtensionsWarehouse...
                              An RBZ does NOT belong in the Plugins folder - move it back into your Downloads folder...
                              Since the release of SketchUp v8M2 there has been a native tool provided to install these tools from their RBZ archives.
                              SketchUp menu, Window > Preferences > Extensions > Install... button
                              Find the RBZ and after answering in the affirmative to the installer's dialog[s], the Plugin is installed automatically for you into your Plugins folder, and it loads.
                              Thereafter, it will load whenever SketchUp starts.
                              If you have v8 and it refuses to install then you need to adjust your Permissions to the Plugins folder inside the SketchUp folder...
                              Properties > Security > Edit... ALL those listed need FULL permissions ticked... Apply/OK.
                              • Y Offline
                                yjinbs21
                                Where Fur for sketchup 2015 64bit?
                                • cottyC Offline
                                  cotty
                                  From the first post of this topic:
                                  @tak2hata said:
                                  DOWNLOAD HERE
                                  Get the latest version from the PluginStore:
                                  http://sketchucation.com/resources/pluginstore?pln=fur_en
                                  or AutoInstall from within SketchUp using the SketchUcation Tools
                                  This version is SU 2015-64 compatible...
                                  my SketchUp gallery
                                    alvro
                                    Does the plugin work on windows 8.1? I tried to install several versions on SU14 and SU15 and always makes the same error: Error: #<Encoding::UndefinedConversionError: "\x81" to UTF-8 in conversion from Windows-1252 to UTF-8>
                                    Any help?
                                    • Z Offline
                                      zcaalock
                                      I have same problem as most of people here: when am using component as source the thing spreads out everywhere. I went through the whole threat and no solution, cannot see any flags to set it up and component axis are set same to rectangle where i want to place the grass.
                                      Any help?
                                      http://s16.postimg.org/unpg6eqdh/grass.png
                                        muchomurka2
                                        wow,thx!
                                          Sejoe
                                          This plugin doesn't working on version 2015 always giving error
                                            It works for others with SketchUp 2015.
                                            Saying "always giving error" but not sharing the error message makes it impossible for anyone to help you if that's what you want. Share the error and you will get some assistance.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 32
                                            • 33
                                            • 13 / 33
