    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      @hilalevi said:
      it doesnt work on sketchup 2014. what do i need to do to make it work?
      Yes. It does work on SketchUp 2014. The first thing you need to do to get help making it work is give specific and useful information. How did you install it? Which version? What are you expecting to see that you aren't seeing?
      • OsamaAlshamiO Offline
        OsamaAlshami
        Hi tak
        tanks for tool it's very useful.
        I translate it to ArabicLanguage. πŸ˜„
        only little problem with translation.
        "Main" & "Default"phrase not translated in (web dialog) ❓
        Arabic translate for (Make Fur).
          brylie10
          sirs can you elp me with these. there are no grass in some parts.what might be the problem???thanks in advance! πŸ˜•
            tak2hata
            Hi,brylie10.
            Please set more high value for "Max Number"
            That is limitation of fur blades number on one face.
            Max Number on dialog
            Right Image is Inputbox dialog.
            Left Image is Webdialog.
            by TAK2HATA
              tlchu6
              sirs please advise how Webdialog works on mac ? Many thanks
              • romboutR Offline
                rombout
                I have that stripped view under mac os 10.6.8 using SU8. WHen i open the HTML in Chrome it does look correct however.
                  Gian8989
                  Does it works on Sketchup 8?
                    Yes. Please read through the thread.
                      Moopingkrupdesign
                      thank you
                        TraxXx
                        Hi !
                        This is such a great plugin but I'm just having troubles to make a grass area by spraying a proxy grass made previously. I've tried different size of proxy, even a little sized bunch of grass but I still don't understand why sketch up is spreading my proxy everywhere in the scene (even on different heights). No matter what area I selected on my mesh (google earth terrain) it doesn't stick grass proxy to it but does a big crow all over my scene. Is that anything related to the fact i'm trying to apply it on a mesh, I saw a russian using "make fur" with proxy on a handmade mesh and he could apply it without troubles. I'm stuck with that, could you help me ? thanks πŸ˜„
                          marvsweden
                          I've read the documentation and this whole thread but I still can't get my head around the axis configuration.
                          I have this component
                          and I want the flag's front face facing the camera but all I get is this
                          If i fiddle with direction and force I can kinda close to what I'm aiming for
                          but the flags are tilted and I still think that I'm missing something here. Can anyone see what I'm doing wrong?
                          Thanks guys!
                            There is a degree of randomness in the Fur component-placement settings.
                            You need to play with that to get near what you want.
                            Alternatively look at the 'ComponentSpray' plugin, with appropriate settings it should also do what you want.
                            To make all of your component-instances 'face' the same way, you could select them and run a snippet in the Ruby Console. Something like:
                            m=Sketchup.active_model;s=m.selection.grep(Sketchup;;ComponentInstance).select{|i|i.definition.name="MyFlag"};m.start_operation("!");s.each{|i|t=i.transformation;x=t.xaxis;a=X_AXIS.angle_between(x);v=x.cross(X_AXIS);v=Z_AXIS if v.length==0;i.transform!(Geom;;Transformation.rotation(t.origin,v,a))};m.commit_operation;
                            Replace the component's name with the actual one!
                            This is one step undo-able.
                              marvsweden
                              Thanks TIG. That sounds like a sofisticated way. Never ran anything from the Ruby console. I'll give it a try.
                              I did however use the make crowd option and found it to produce a somewhat more pleasing result.
                              • U Offline
                                urban journey
                                Hi guys,
                                This plugin has absolutely changed my life with Sketchup being a landscape designer, i use it all the time.
                                I do have a similar problem though to a previous poster and couldn't see a solution from reading through. Essentially, i select an area, a grass component and then generate and it throws components outside the selected area - see screenshot showing this and my Fur settings....
                                  TraxXx
                                  Any suggestion concerning my problem ?
                                    Have you tried reading the usage notes.
                                    Perhaps you have a setting that ignores the selection ?
                                    Perhaps posting a screenshot or two would elicit more help...
                                      TraxXx
                                      I'm having the same issue as urban journey, this is pretty much what it looks like, but with grass
                                      • cottyC Offline
                                        cotty
                                        Maybe the component axes are misplaced?
                                        my SketchUp gallery
                                          TraxXx
                                          Well I've checked the components axis but it seems normal. That wouldn't explain why they are dispatched all over the scene anyway... It seems like it's gonna stay a mistery ! 😞
                                            AMANI1805
                                            How do I install this to my Google SketchUp Plugin? I tried putting the file under my plugins folder but that doenst seem to work. Help please?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 31 / 33
