    [Plugin] TIG-LayersFromList
    26 Posts 7 Posters 5.3k Views 7 Watching
      @rich o brien said:
      also i set my text editor to do space and not tabs so now i've to set it so it does tabs to make this work
      a really nice tool but not digging the implementation.
      Why set it to replace TABs with spaces, that just makes adjusting indents in/out more complicated than you need.
      Provided that you always use the actual text "\t" as the separator AND never use "\t" inside a Layer's name I can adjust the code to trap for idiocy πŸ˜†
      Watch for an update πŸ˜•
      I'll also look at adding Alpha transparency to the Layer Color, so with material-by-layer a glass layer can be transparent... but I don't think it is accessible through the API, although you can do it manually by editing the Layer's Color in the Layer Browser...
        Because a certain colleague complains about tabs. So I switched.
        A dialog with a color picker would be nice
          That's built-in already.
          Existing layer or new-layer, in the Layer Manager, click the colored block to the right of the entry, and set the RGBA as desired...
            Yes, but if i could have a better solution than the default it would be nice
            and accepting hex values would be a plus
              Here is v1.1 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList It now uses a ':' [colon] as the default separator between the LayerName and the R,G,B values
              LayerName:123,123,123
              If the layer's name also includes a ':' it is trapped for and is not changed within the name...
              You can now edit the .RB file and choose another separator, provided it's not a ',', which is reserved for the R,G,B separation...
              I have looked at the possibility of assigning an optional Alpha transparency to the layer's color - unfortunately the Ruby API gives no access to a Layer-Color's alpha settings - you can however, edit the Layer's color in the Layer Browser and assign it there...
              • Miner_JeffM
                Miner_Jeff
                Hello,
                Not sure if anyone else is experiencing this or not.
                I have not tested V1.1 with Windows 8 yet only Win 7.
                Version 1.0 worked with Win 7. Layers were created as described in the instructions using a [TAB] delimiter. (Sketchup pro 2015, Win 7)
                V1.0 with Sketchup Pro, Win 8 would not work. Layers names would show as Rich describes
                "Layer01 255,0,128" and random color.
                V1.1 with Sketchup Pro, Win 7 gives layers named "Layer01:255,0,128" with random color
                V1.1 with Sketchup Pro, Win 8 - not tested yet.
                Cheers,
                Miner_Jeff
                  Works fine for me... πŸ˜•
                  Can you PM me the txt file you are using...
                  I'm thinking it might be an encoding issue...
                  If you used Notepad it'll probably be ANSI.
                  With Notepad++ you can change the format to suit >= v2014's Ruby2...
                  Also can you try using this 'empty' file - copy+paste the LayerName:123,123,123 lines from the original - this is encoded as UTF8-without-BOM, and works for me fine...
                  If that file works then I can try and force the encoding better on the 'read' ?
                  MyLayers.txt
                    @Miner_Jeff
                    Thanks for the PM.
                    I can use the 'colon' [or 'TAB'] txt file just fine...
                    The layers/colors come in as expected.
                    Have you tried my own txt file.
                    I expect it won't matter...
                    BUT your files already work fine for me πŸ˜•
                    • Miner_JeffM
                      Miner_Jeff
                      Hi TIG,
                      After some testing, it appears that I have a weird issue with Notepad++ [under investigation!]
                      Using plain Notepad to make the Layers.txt file, the plugin results are as expected.
                      Nice work again!
                      Many thanks, πŸ˜„
                      Miner_Jeff
                      Q: How do you sink a 1000 m mine shaft?
                      A: Blast one round at a time.
                      • KrisidiousK
                        Krisidious
                        Can this export from one file and create the text file that will be used on another file?
                        By: Kristoff Rand
                          No, but I'll write its sibling LayersToList πŸ˜‰
                          • KrisidiousK
                            Krisidious
                            lol... It's great just the way it is TIG... Thank you.
                            Currently I open a sketchup model and find I want the layers from another. So I open a second instance and then copy/paste geometry from old to new and thus transfer layers. Only takes a few clicks.
                            By: Kristoff Rand
                            • KrisidiousK
                              Krisidious
                              @miner_jeff said:
                              Hi TIG,
                              Check your encoding on Notepad++ please.
                              By: Kristoff Rand
                                @Kris
                                I wrote **TIG-LayersToList** anyway - http://sketchucation.com/forums/viewtopic.php?p=568648#p568648
                                You can use it to make Layer-sets for reuse in other Models in conjunction with this tool - TIG-LayersFromList http://sketchucation.com/pluginstore?pln=TIG_LayersFromList ...
                                • jujuJ
                                  juju
                                  wow, should be a real great thing if the two were to be combined
                                    Here is v1.2 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList
                                    It fixes an issue reported by some Win8 users, where the layers' color were not getting set correctly.
                                    • Miner_JeffM
                                      Miner_Jeff
                                      Hi Folks,
                                      If you need to create a sequence of layers with text and numbers with specific colours I have shared a means to create the text file easily for use with this wonderful ruby of TIG's.
                                      It can be used to verify the colour of RGB values too by colouring the cell to RGB values specified.
                                      I used MS excel and VBA. It can be found here http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63894
                                      Cheers,
                                      Miner_jeff
                                      • sumasterS
                                        sumaster
                                        Can we set Default Text file path in this script . . . . . ?
                                        Thank you,
                                        SUmaster
                                          Please expand on this, so we might understand your question...
                                            db11
                                            Hi TIG -
                                            Thanks for a very useful plugin (along with it's companion).
                                            I have a request for a plugin that would build on these two, in order to automatically replace Layers From with Layers To in a SU file. My thought is that the easiest way would be with a simple two column csv file that gives the equivalences: 'From' in col A and 'To' in col B.
                                            I would use it to harmonize layer names across models, so that imported components would always land on the right layers, without having to manually delete and merge the newly imported layer(s).
                                            Not sure how difficult it would be, but would be a great help.
                                            Thanks,
                                            Doug
