    [Plugin] TIG-LayersFromList
    26 Posts 7 Posters 3.6k Views 7 Watching
      A >=v2014 Plugin to read data from a file and from that add/change Layers by name and/or change the Layers' Colors. http://sketchucation.com/pluginstore?pln=TIG_LayersFromList See its PluginStore entry for the Overview etc...
        Anyway to control the layer naming when colours are included in the file?
        I get 'Floor\t26,188,156' as the layer name when ideally I only want the Floor.
        Floor\t26,188,156
        Walls\t46,204,113
        • KrisidiousK Offline
          Krisidious
          Oh you sir are a rock star... very nice.
          By: Kristoff Rand
            @Rich
            Read the instructions. 😲
            You separate the Layer's name from the R,G,B with a TAB !
            I used "\t" to indicate the TAB - otherwise you'd not see it in the text !
            Since you can have ANY character, other than a "\t" TAB or a "\n" NEWLINE, in a Layer's name, we need to come up with a way of indicating where the Layer's name ends and the R,G,B starts.
            As it's read line-by-line we can't use "\n", so the clear option is the TAB.
            So use the TAB key, don't type "\t" πŸ˜’
            In Notepad++ you can use find "\t" and replace with "\t" - with regexp checked...
              I read the instruction...clear as mud
                also i set my text editor to do space and not tabs so now i've to set it so it does tabs to make this work
                a really nice tool but not digging the implementation.
                  Why set it to replace TABs with spaces, that just makes adjusting indents in/out more complicated than you need.
                  Provided that you always use the actual text "\t" as the separator AND never use "\t" inside a Layer's name I can adjust the code to trap for idiocy πŸ˜†
                  Watch for an update πŸ˜•
                  I'll also look at adding Alpha transparency to the Layer Color, so with material-by-layer a glass layer can be transparent... but I don't think it is accessible through the API, although you can do it manually by editing the Layer's Color in the Layer Browser...
                    Because a certain colleague complains about tabs. So I switched.
                    A dialog with a color picker would be nice
                      That's built-in already.
                      Existing layer or new-layer, in the Layer Manager, click the colored block to the right of the entry, and set the RGBA as desired...
                        Yes, but if i could have a better solution than the default it would be nice
                        and accepting hex values would be a plus
                          Here is v1.1 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList It now uses a ':' [colon] as the default separator between the LayerName and the R,G,B values
                          LayerName:123,123,123
                          If the layer's name also includes a ':' it is trapped for and is not changed within the name...
                          You can now edit the .RB file and choose another separator, provided it's not a ',', which is reserved for the R,G,B separation...
                          I have looked at the possibility of assigning an optional Alpha transparency to the layer's color - unfortunately the Ruby API gives no access to a Layer-Color's alpha settings - you can however, edit the Layer's color in the Layer Browser and assign it there...
                          • Miner_JeffM Offline
                            Miner_Jeff
                            Hello,
                            Not sure if anyone else is experiencing this or not.
                            I have not tested V1.1 with Windows 8 yet only Win 7.
                            Version 1.0 worked with Win 7. Layers were created as described in the instructions using a [TAB] delimiter. (Sketchup pro 2015, Win 7)
                            V1.0 with Sketchup Pro, Win 8 would not work. Layers names would show as Rich describes
                            "Layer01 255,0,128" and random color.
                            V1.1 with Sketchup Pro, Win 7 gives layers named "Layer01:255,0,128" with random color
                            V1.1 with Sketchup Pro, Win 8 - not tested yet.
                            Cheers,
                            Miner_Jeff
                              Works fine for me... πŸ˜•
                              Can you PM me the txt file you are using...
                              I'm thinking it might be an encoding issue...
                              If you used Notepad it'll probably be ANSI.
                              With Notepad++ you can change the format to suit >= v2014's Ruby2...
                              Also can you try using this 'empty' file - copy+paste the LayerName:123,123,123 lines from the original - this is encoded as UTF8-without-BOM, and works for me fine...
                              If that file works then I can try and force the encoding better on the 'read' ?
                              MyLayers.txt
                                @Miner_Jeff
                                Thanks for the PM.
                                I can use the 'colon' [or 'TAB'] txt file just fine...
                                The layers/colors come in as expected.
                                Have you tried my own txt file.
                                I expect it won't matter...
                                BUT your files already work fine for me πŸ˜•
                                  Miner_Jeff
                                  Hi TIG,
                                  After some testing, it appears that I have a weird issue with Notepad++ [under investigation!]
                                  Using plain Notepad to make the Layers.txt file, the plugin results are as expected.
                                  Nice work again!
                                  Many thanks, πŸ˜„
                                  Miner_Jeff
                                  Q: How do you sink a 1000 m mine shaft?
                                  A: Blast one round at a time.
                                    Krisidious
                                    Can this export from one file and create the text file that will be used on another file?
                                    By: Kristoff Rand
                                      No, but I'll write its sibling LayersToList πŸ˜‰
                                        Krisidious
                                        lol... It's great just the way it is TIG... Thank you.
                                        Currently I open a sketchup model and find I want the layers from another. So I open a second instance and then copy/paste geometry from old to new and thus transfer layers. Only takes a few clicks.
                                        By: Kristoff Rand
                                          Krisidious
                                          @miner_jeff said:
                                          Hi TIG,
                                          Check your encoding on Notepad++ please.
                                          By: Kristoff Rand
                                            @Kris
                                            I wrote **TIG-LayersToList** anyway - http://sketchucation.com/forums/viewtopic.php?p=568648#p568648
                                            You can use it to make Layer-sets for reuse in other Models in conjunction with this tool - TIG-LayersFromList http://sketchucation.com/pluginstore?pln=TIG_LayersFromList ...
