    [Plugin] TIG-LayersFromList
    26 Posts 7 Posters 5.3k Views 7 Watching
      also i set my text editor to do space and not tabs so now i've to set it so it does tabs to make this work
      a really nice tool but not digging the implementation.
        Why set it to replace TABs with spaces, that just makes adjusting indents in/out more complicated than you need.
        Provided that you always use the actual text "\t" as the separator AND never use "\t" inside a Layer's name I can adjust the code to trap for idiocy πŸ˜†
        Watch for an update πŸ˜•
        I'll also look at adding Alpha transparency to the Layer Color, so with material-by-layer a glass layer can be transparent... but I don't think it is accessible through the API, although you can do it manually by editing the Layer's Color in the Layer Browser...
          Because a certain colleague complains about tabs. So I switched.
          A dialog with a color picker would be nice
            That's built-in already.
            Existing layer or new-layer, in the Layer Manager, click the colored block to the right of the entry, and set the RGBA as desired...
              Yes, but if i could have a better solution than the default it would be nice
              and accepting hex values would be a plus
                Here is v1.1 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList It now uses a ':' [colon] as the default separator between the LayerName and the R,G,B values
                LayerName:123,123,123
                If the layer's name also includes a ':' it is trapped for and is not changed within the name...
                You can now edit the .RB file and choose another separator, provided it's not a ',', which is reserved for the R,G,B separation...
                I have looked at the possibility of assigning an optional Alpha transparency to the layer's color - unfortunately the Ruby API gives no access to a Layer-Color's alpha settings - you can however, edit the Layer's color in the Layer Browser and assign it there...
                • Miner_JeffM
                  Miner_Jeff
                  Hello,
                  Not sure if anyone else is experiencing this or not.
                  I have not tested V1.1 with Windows 8 yet only Win 7.
                  Version 1.0 worked with Win 7. Layers were created as described in the instructions using a [TAB] delimiter. (Sketchup pro 2015, Win 7)
                  V1.0 with Sketchup Pro, Win 8 would not work. Layers names would show as Rich describes
                  "Layer01 255,0,128" and random color.
                  V1.1 with Sketchup Pro, Win 7 gives layers named "Layer01:255,0,128" with random color
                  V1.1 with Sketchup Pro, Win 8 - not tested yet.
                  Cheers,
                  Miner_Jeff
                    Works fine for me... πŸ˜•
                    Can you PM me the txt file you are using...
                    I'm thinking it might be an encoding issue...
                    If you used Notepad it'll probably be ANSI.
                    With Notepad++ you can change the format to suit >= v2014's Ruby2...
                    Also can you try using this 'empty' file - copy+paste the LayerName:123,123,123 lines from the original - this is encoded as UTF8-without-BOM, and works for me fine...
                    If that file works then I can try and force the encoding better on the 'read' ?
                    MyLayers.txt
                      @Miner_Jeff
                      Thanks for the PM.
                      I can use the 'colon' [or 'TAB'] txt file just fine...
                      The layers/colors come in as expected.
                      Have you tried my own txt file.
                      I expect it won't matter...
                      BUT your files already work fine for me πŸ˜•
                      • Miner_JeffM
                        Miner_Jeff
                        Hi TIG,
                        After some testing, it appears that I have a weird issue with Notepad++ [under investigation!]
                        Using plain Notepad to make the Layers.txt file, the plugin results are as expected.
                        Nice work again!
                        Many thanks, πŸ˜„
                        Miner_Jeff
                        Q: How do you sink a 1000 m mine shaft?
                        A: Blast one round at a time.
                        • KrisidiousK
                          Krisidious
                          Can this export from one file and create the text file that will be used on another file?
                          By: Kristoff Rand
                            No, but I'll write its sibling LayersToList πŸ˜‰
                            • KrisidiousK
                              Krisidious
                              lol... It's great just the way it is TIG... Thank you.
                              Currently I open a sketchup model and find I want the layers from another. So I open a second instance and then copy/paste geometry from old to new and thus transfer layers. Only takes a few clicks.
                              By: Kristoff Rand
                              • KrisidiousK
                                Krisidious
                                @miner_jeff said:
                                Hi TIG,
                                Check your encoding on Notepad++ please.
                                By: Kristoff Rand
                                  @Kris
                                  I wrote **TIG-LayersToList** anyway - http://sketchucation.com/forums/viewtopic.php?p=568648#p568648
                                  You can use it to make Layer-sets for reuse in other Models in conjunction with this tool - TIG-LayersFromList http://sketchucation.com/pluginstore?pln=TIG_LayersFromList ...
                                  • jujuJ
                                    juju
                                    wow, should be a real great thing if the two were to be combined
                                      Here is v1.2 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList
                                      It fixes an issue reported by some Win8 users, where the layers' color were not getting set correctly.
                                      • Miner_JeffM
                                        Miner_Jeff
                                        Hi Folks,
                                        If you need to create a sequence of layers with text and numbers with specific colours I have shared a means to create the text file easily for use with this wonderful ruby of TIG's.
                                        It can be used to verify the colour of RGB values too by colouring the cell to RGB values specified.
                                        I used MS excel and VBA. It can be found here http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63894
                                        Cheers,
                                        Miner_jeff
                                        • sumasterS
                                          sumaster
                                          Can we set Default Text file path in this script . . . . . ?
                                          Thank you,
                                          SUmaster
                                            Please expand on this, so we might understand your question...
