    [Extension][$] CompoScene v2.0.2 (Updated)
    33 Posts 20 Posters 56.9k Views 20 Watching
    • renderizaR Offline
      renderiza
      [pre:3o6vfvzs]Authors:: Renderiza
      Plugin Name:: [SU]Ch
      Version:: 1.0.1
      Date:: 6/29/2013
      Cost:: Free[/pre:3o6vfvzs]
      Update for [SUCh v1.0.1]
      Exporting all your scene is now automated and easier than before.
      http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • halroachH Offline
        halroach
        Very cool idea! 👍 👍
        1. The only hitch I find is that it is a bit difficult to return back to my initial style that I am used to working with. Maybe if you could add a tab with the style that was being used before applying this plugin.
          You could call it "default" or "user" or "shaded with textures" (my default)... something along that line.
        2. Actually one more little hitch. I had to manually enable "fog" for the ZDepth to work. Either have that done with the plugin, if not possible make a note of it somewhere that Fog must be enabled.
        FlexTools - Super Quick Windows, Doors, Slats...
          renderiza
          That is really good idea I'll make sure to include it in next update. 👍
          @halroach said:
          1. Actually one more little hitch. I had to manually enable "fog" for the ZDepth to work. Either have that done with the plugin, if not possible make a note of it somewhere that Fog must be enabled.
          The ZDepth channel enables fog but it seems there is a bug that even though its activated it doesn't work most of the time. What I do to fix it is give the start or end fog slider a little nudge to make the fog visible again. Not 100% sure how to solve this at the moment but hopefully fixing it manually is not that bad.
          Thanks,
          Renderiza
            renderiza
            [pre:sttzodg5]Authors:: Renderiza
            Version:: 1.0.2
            Date:: 7/5/2013
            Cost:: Free[/pre:sttzodg5]
            Update for [SUCh v1.0.2]
            %(#909090)[New Features:
            • Default scene will now be created so that you don't lose the page style you had before creating new rendering channels.
            • Now you have the option of exporting single scene.]
            http://s18.postimg.org/9qbz1jee1/newebdialog_1.png
            • V Offline
              valerostudio
              A+++ This is fantastic. I can't tell you how many times I setup each of these passes on the fly.
                renderiza
                Glad you found it useful...Cheers!
                • alsomarA Offline
                  alsomar Extension Creator
                  Hi there!
                  First of all, thanks for your great work. The thing is, will Su[Ch] come to SketchUp 2014? I usually use 2014, but I have yet installed SketchUp 2013 just for this plugin 😄
                  Greetings and regards.
                  Alejandro Soriano Visuals · All my links
                    sanjeevkmishra
                    HI There,
                    I'm using a mac and just tried to use this plugin. Sadly the plugin is showing a blank window. What could be wrong?? I'm using SU13. thnx for the update.
                    Rgds,
                    Sanjeev
                    • O Offline
                      ominoliquido
                      Thanks for a great plugin.
                      it would be very helpful if all the channels were named after the scenes they are generated from.
                      (EX: Scene1-Texture, Scene1-Lin)
                      I often work with multiple scenes and it's not possible to export channels with the same name.
                      Cheers
                      • E Offline
                        eworden
                        I seem to have lost the Export Channels capability. Anyone else have this issue?
                        I can create channels, but the Export function is no longer available.
                        This is an extremely important function for me and I cannot find a replacement solution.
                        Anyone have any ideas?
                        • X Offline
                          xrowdac
                          hello guys,. I have installed this plug-in on ver.8 SKetchup all seems working the only problem i encountered is that the Z-depth has no depth literally its a same image as the alpha..
                          can anyone help me?
                          appreciate it.. GOD BLESS to all.
                          Francis
                          • alsomarA Offline
                            Hi there,
                            you only have to change a little the default values for distance in the fog floating window ( window > fog ) and it's done
                            • masterpaulM Offline
                              masterpaul
                              I don't think this works on 2016, Unfortunately. I really like the defaults from this.
                                Seems it perfectly works in SU 2016! 🤓
                                  renderiza
                                  I am finally working on this extension once again and have updated it. I changed the name from '[SU]CH' to 'Styler' and here are a few things that changed.
                                  • I added new 'User Interface' which is drawn directly on SketchUp's view and want to know if you guys like it better than the Web-Dialog.
                                  • You can now pick the folder for exporting images.
                                  • Also fixed the Zdepht Scene.
                                  I am planning to add other cool features soon. Also, I am charging a small fee to justify the hours I spend programming my plugins.
                                  Thanks,
                                  Renderiza
                                    renderiza
                                    The 3D model used in example was made by Digson
                                    • Default
                                    http://4.bp.blogspot.com/-uBtr6MdH09w/UcoYsXxP6lI/AAAAAAAAAEQ/0YV7QSvABsc/s1600/default.jpg
                                    • Alpha
                                    http://3.bp.blogspot.com/-Ln3ii1OwWLM/UcoZJRv2eYI/AAAAAAAAAEg/S3B534YKka4/s1600/alpha.jpg
                                    • Clay
                                    http://1.bp.blogspot.com/-2i9dXfwrEWA/UcoY7lpJs6I/AAAAAAAAAEc/Vlga_UuMKXo/s1600/clay.jpg
                                    • Color
                                    http://4.bp.blogspot.com/--TZCVYECg1g/UcoZYUQwRwI/AAAAAAAAAEo/XB_pZQEN-6Y/s1600/color.jpg
                                    • Color by Layer
                                    http://2.bp.blogspot.com/-UHkldGwuNpg/UcoZfl52QoI/AAAAAAAAAEw/noiGAtYicpE/s1600/colorbylayer.jpg
                                    • Line
                                    http://1.bp.blogspot.com/-1isg8WjEE3c/UcoZprWsUGI/AAAAAAAAAE8/KniGlU-JD08/s1600/line.jpg
                                    http://2.bp.blogspot.com/-ODhUep8l0RI/UcoaSNRLRoI/AAAAAAAAAFQ/hqlsa1yT8C8/s1600/profile.jpg
                                    • Shadow
                                    http://2.bp.blogspot.com/-HSq562xiJqU/UcoaZuBmU3I/AAAAAAAAAFY/OQAVBZPLAOk/s1600/shadow.jpg
                                    • Texture
                                    http://1.bp.blogspot.com/-noXATCOUak0/UcoafMOlBcI/AAAAAAAAAFg/pkT38dnLi3k/s1600/texture.jpg
                                    • Zdepth
                                    http://1.bp.blogspot.com/-Kh5qvHvbl5o/UcoakYA7uqI/AAAAAAAAAFo/JMGb9X0aGKg/s1600/zdepth.jpg
                                      renderiza
                                      Hi, I have added a Youtube Video of CompoScene for anyone interested.
                                      Also, I am planning to add more videos of SketchUp related stuff so if you are interested you can subscibe to my channel… https://www.youtube.com/user/RenderizaStudio
                                      Enjoy!
                                        renderiza
                                        CompoScene Updated to v2.0.1
                                        https://s20.postimg.org/i4pm29znh/dlg.png
                                        Export Feature
                                        Added transparent export option for:
                                        *** PNG
                                        • TiFF**
                                          Note: Remember to disable the ‘Sky’ checkbox in the Style Tray options if you want the background to be fully transparent.
                                        Enjoy!
                                        _______________________________________________________________________________
                                        ❖ Get my SketchUp Extensions:
                                        • CompoScene
                                        • iSelect
                                        • Face Director
                                        ❖ Follow Me:
                                        • Twitter
                                        • Facebook
                                        • YouTube
                                          renderiza
                                          Fixed in CompoScene v2.0.2
                                          • Web Dialog will not appear if exit button is pressed.
                                          • Message Box asking ‘Do you want to Exit?’ after clicking outside the CompoScene UI will not be displayed now.
                                          • WebDialog has been modified & resized.
                                          • Module names have been changed.
                                          • Changed require .rb which bypassed the extension registration system preventing users from being able to disable the extension.
                                          • Now when you delete all scenes the style kept is the one in the first slot.
                                          • The default page is created with the style used before creating channels.
                                          • Fixed Save button from being hit without the export button being active.
                                          • Fixed bug that activated transparency on jpg resulting in white background on the alpha channel.
                                          • Updated Extension Info as well.
                                          Important!
                                          Delete the previous version of CompoScene before installing the new version to avoid problems…
                                          Go to Plugins folder and delete:
                                          • MiSU_CompoScene (folder)
                                          • MiSU_CompoScene.rb
                                          CompoScene is in continuous development and since I am a solo developer it’s helpful when I receive feedback on what to fix or add next.
                                            rodrigo_cerci
                                            oh man! this used to be a free plugin 😞 too bad.
                                            But a guy needs to make a living, anyway great plugin man
