    [Extension][$] CompoScene v2.0.2 (Updated)
    33 Posts 20 Posters 53.2k Views 20 Watching
    • X Offline
      xrowdac
      hello guys,. I have installed this plug-in on ver.8 SKetchup all seems working the only problem i encountered is that the Z-depth has no depth literally its a same image as the alpha..
      can anyone help me?
      appreciate it.. GOD BLESS to all.
      Francis
      • alsomarA Offline
        alsomar Extension Creator
        Hi there,
        you only have to change a little the default values for distance in the fog floating window ( window > fog ) and it's done
        Alejandro Soriano Visuals · All my links
        • masterpaulM Offline
          masterpaul
          I don't think this works on 2016, Unfortunately. I really like the defaults from this.
            Seems it perfectly works in SU 2016! 🤓
            • renderizaR Offline
              renderiza
              I am finally working on this extension once again and have updated it. I changed the name from '[SU]CH' to 'Styler' and here are a few things that changed.
              • I added new 'User Interface' which is drawn directly on SketchUp's view and want to know if you guys like it better than the Web-Dialog.
              • You can now pick the folder for exporting images.
              • Also fixed the Zdepht Scene.
              I am planning to add other cool features soon. Also, I am charging a small fee to justify the hours I spend programming my plugins.
              Thanks,
              Renderiza
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                renderiza
                The 3D model used in example was made by Digson
                • Default
                http://4.bp.blogspot.com/-uBtr6MdH09w/UcoYsXxP6lI/AAAAAAAAAEQ/0YV7QSvABsc/s1600/default.jpg
                • Alpha
                http://3.bp.blogspot.com/-Ln3ii1OwWLM/UcoZJRv2eYI/AAAAAAAAAEg/S3B534YKka4/s1600/alpha.jpg
                • Clay
                http://1.bp.blogspot.com/-2i9dXfwrEWA/UcoY7lpJs6I/AAAAAAAAAEc/Vlga_UuMKXo/s1600/clay.jpg
                • Color
                http://4.bp.blogspot.com/--TZCVYECg1g/UcoZYUQwRwI/AAAAAAAAAEo/XB_pZQEN-6Y/s1600/color.jpg
                • Color by Layer
                http://2.bp.blogspot.com/-UHkldGwuNpg/UcoZfl52QoI/AAAAAAAAAEw/noiGAtYicpE/s1600/colorbylayer.jpg
                • Line
                http://1.bp.blogspot.com/-1isg8WjEE3c/UcoZprWsUGI/AAAAAAAAAE8/KniGlU-JD08/s1600/line.jpg
                http://2.bp.blogspot.com/-ODhUep8l0RI/UcoaSNRLRoI/AAAAAAAAAFQ/hqlsa1yT8C8/s1600/profile.jpg
                • Shadow
                http://2.bp.blogspot.com/-HSq562xiJqU/UcoaZuBmU3I/AAAAAAAAAFY/OQAVBZPLAOk/s1600/shadow.jpg
                • Texture
                http://1.bp.blogspot.com/-noXATCOUak0/UcoafMOlBcI/AAAAAAAAAFg/pkT38dnLi3k/s1600/texture.jpg
                • Zdepth
                http://1.bp.blogspot.com/-Kh5qvHvbl5o/UcoakYA7uqI/AAAAAAAAAFo/JMGb9X0aGKg/s1600/zdepth.jpg
                  renderiza
                  Hi, I have added a Youtube Video of CompoScene for anyone interested.
                  Also, I am planning to add more videos of SketchUp related stuff so if you are interested you can subscibe to my channel… https://www.youtube.com/user/RenderizaStudio
                  Enjoy!
                    renderiza
                    CompoScene Updated to v2.0.1
                    https://s20.postimg.org/i4pm29znh/dlg.png
                    Export Feature
                    Added transparent export option for:
                    *** PNG
                    • TiFF**
                      Note: Remember to disable the ‘Sky’ checkbox in the Style Tray options if you want the background to be fully transparent.
                    Enjoy!
                    _______________________________________________________________________________
                    ❖ Get my SketchUp Extensions:
                    • CompoScene
                    • iSelect
                    • Face Director
                    ❖ Follow Me:
                    • Twitter
                    • Facebook
                    • YouTube
                      renderiza
                      Fixed in CompoScene v2.0.2
                      • Web Dialog will not appear if exit button is pressed.
                      • Message Box asking ‘Do you want to Exit?’ after clicking outside the CompoScene UI will not be displayed now.
                      • WebDialog has been modified & resized.
                      • Module names have been changed.
                      • Changed require .rb which bypassed the extension registration system preventing users from being able to disable the extension.
                      • Now when you delete all scenes the style kept is the one in the first slot.
                      • The default page is created with the style used before creating channels.
                      • Fixed Save button from being hit without the export button being active.
                      • Fixed bug that activated transparency on jpg resulting in white background on the alpha channel.
                      • Updated Extension Info as well.
                      Important!
                      Delete the previous version of CompoScene before installing the new version to avoid problems…
                      Go to Plugins folder and delete:
                      • MiSU_CompoScene (folder)
                      • MiSU_CompoScene.rb
                      CompoScene is in continuous development and since I am a solo developer it’s helpful when I receive feedback on what to fix or add next.
                        rodrigo_cerci
                        oh man! this used to be a free plugin 😞 too bad.
                        But a guy needs to make a living, anyway great plugin man
                          Gen Peka
                          @renderiza said:
                          [pre:2auevudn]Authors:: Renderiza
                          Plugin Name:: [SU]Ch
                          Version:: 1.0.1
                          Date:: 6/29/2013
                          Cost:: Free[/pre:2auevudn]
                          Update for [SUCh v1.0.1]
                          Exporting all your scene is now automated and easier than before.
                          http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
                          Hello Renderiza
                          I previously used this plugin [SU]ch, but i don't know what happened, the plugin disappeared from my extensions in sketchup and i'm trying to redownload it from the Extension Warehouse but it always fails. What happened? Could you post a valid link? Thank you so much
                            rosto
                            [Su]ch a comfortable plugin it was!
                            Have anybody saved the plugin before it gone, please?
                            Composcene`s website unfortunately does not working 😞
                            Or maybe there is a similar solution?
                              aenc_randyc
                              Same thing happened to me, extension no longer can be found, Indie3D seemed to be no longer existed, emailed Rafael but email doesn't work either. I purchased the extension back in 2021, need to download the extension but can't find nobody nor any response.
                              • 2 / 2
