    [Extension][$] CompoScene v2.0.2 (Updated)
    33 Posts 20 Posters 57.5k Views 20 Watching
    • renderizaR
      renderiza
      @srx said:
      This is good idea, but already done. Trogluddite made this plugin, automatically exporting images too:
      http://sketchucation.com/forums/viewtopic.php?t=49422
      Maybe its a good idea to provide a space on the main post to include similar or recommended plugins.
      Interesting to note that even before I posted this plugin I did mention Rendering Favourites (v1.1) by Trogluddite on the Developers forum HERE. By the way thank you TIG for helping me out!
      @thomthom said:
      They don't appear to be doing the same thing...
      I do agree and I still plan to keep using both of them for that same reason.
      @nemesis said:
      renderiza, nice start. will wait for further development.
      Thank you!...Hope to finish the update soon. 👍
      @trogluddite said:
      Certainly very different approaches - I built 'Render Favourites' with the specific intent of avoiding the creation of scenes (personal preference, I like them to be only for camera viewpoints). I have never rendered or post-processed an SU model in my life, so was quite stunned by the positive reaction of 'renderers'!
      Guess it just depends how folks like to go about doing their rendering - though I guess my plugin must take a bit of setting up for it, as it doesn't have the ready-made 'presets' for the render layers (nor enough 'favourite' slots do provide all of the ones that Renderiza lists at the same time).
      Anyhow - since both are free plugins, I just though I'd drop in to say that if any of the code from my plugin looks handy for making a "best of both worlds" version, then please feel free to take and use anything that looks useful.
      Sadly, I don't have the time lately for much plugin work - but I'll happily try to answer any questions that might arise from trying to adapt the code.
      Studying other people is code is the best way I have found to learn and I thank you for sharing that possibility, will certainly be giving it a peek.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        [pre:3o6vfvzs]Authors:: Renderiza
        Plugin Name:: [SU]Ch
        Version:: 1.0.1
        Date:: 6/29/2013
        Cost:: Free[/pre:3o6vfvzs]
        Update for [SUCh v1.0.1]
        Exporting all your scene is now automated and easier than before.
        http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
        • halroachH
          halroach
          Very cool idea! 👍 👍
          1. The only hitch I find is that it is a bit difficult to return back to my initial style that I am used to working with. Maybe if you could add a tab with the style that was being used before applying this plugin.
            You could call it "default" or "user" or "shaded with textures" (my default)... something along that line.
          2. Actually one more little hitch. I had to manually enable "fog" for the ZDepth to work. Either have that done with the plugin, if not possible make a note of it somewhere that Fog must be enabled.
          FlexTools - Super Quick Windows, Doors, Slats...
          • renderizaR
            renderiza
            That is really good idea I'll make sure to include it in next update. 👍
            @halroach said:
            1. Actually one more little hitch. I had to manually enable "fog" for the ZDepth to work. Either have that done with the plugin, if not possible make a note of it somewhere that Fog must be enabled.
            The ZDepth channel enables fog but it seems there is a bug that even though its activated it doesn't work most of the time. What I do to fix it is give the start or end fog slider a little nudge to make the fog visible again. Not 100% sure how to solve this at the moment but hopefully fixing it manually is not that bad.
            Thanks,
            Renderiza
            • renderizaR
              renderiza
              [pre:sttzodg5]Authors:: Renderiza
              Version:: 1.0.2
              Date:: 7/5/2013
              Cost:: Free[/pre:sttzodg5]
              Update for [SUCh v1.0.2]
              %(#909090)[New Features:
              • Default scene will now be created so that you don't lose the page style you had before creating new rendering channels.
              • Now you have the option of exporting single scene.]
              http://s18.postimg.org/9qbz1jee1/newebdialog_1.png
              • V
                valerostudio
                A+++ This is fantastic. I can't tell you how many times I setup each of these passes on the fly.
                • renderizaR
                  renderiza
                  Glad you found it useful...Cheers!
                  • alsomarA
                    alsomar Extension Creator
                    Hi there!
                    First of all, thanks for your great work. The thing is, will Su[Ch] come to SketchUp 2014? I usually use 2014, but I have yet installed SketchUp 2013 just for this plugin 😄
                    Greetings and regards.
                    Alejandro Soriano Visuals · All my links
                      sanjeevkmishra
                      HI There,
                      I'm using a mac and just tried to use this plugin. Sadly the plugin is showing a blank window. What could be wrong?? I'm using SU13. thnx for the update.
                      Rgds,
                      Sanjeev
                      • O
                        ominoliquido
                        Thanks for a great plugin.
                        it would be very helpful if all the channels were named after the scenes they are generated from.
                        (EX: Scene1-Texture, Scene1-Lin)
                        I often work with multiple scenes and it's not possible to export channels with the same name.
                        Cheers
                        • E
                          eworden
                          I seem to have lost the Export Channels capability. Anyone else have this issue?
                          I can create channels, but the Export function is no longer available.
                          This is an extremely important function for me and I cannot find a replacement solution.
                          Anyone have any ideas?
                          • X
                            xrowdac
                            hello guys,. I have installed this plug-in on ver.8 SKetchup all seems working the only problem i encountered is that the Z-depth has no depth literally its a same image as the alpha..
                            can anyone help me?
                            appreciate it.. GOD BLESS to all.
                            Francis
                            • alsomarA
                              Hi there,
                              you only have to change a little the default values for distance in the fog floating window ( window > fog ) and it's done
                              • masterpaulM
                                masterpaul
                                I don't think this works on 2016, Unfortunately. I really like the defaults from this.
                                  Seems it perfectly works in SU 2016! 🤓
                                  • renderizaR
                                    renderiza
                                    I am finally working on this extension once again and have updated it. I changed the name from '[SU]CH' to 'Styler' and here are a few things that changed.
                                    • I added new 'User Interface' which is drawn directly on SketchUp's view and want to know if you guys like it better than the Web-Dialog.
                                    • You can now pick the folder for exporting images.
                                    • Also fixed the Zdepht Scene.
                                    I am planning to add other cool features soon. Also, I am charging a small fee to justify the hours I spend programming my plugins.
                                    Thanks,
                                    Renderiza
                                    • renderizaR
                                      renderiza
                                      The 3D model used in example was made by Digson
                                      • Default
                                      http://4.bp.blogspot.com/-uBtr6MdH09w/UcoYsXxP6lI/AAAAAAAAAEQ/0YV7QSvABsc/s1600/default.jpg
                                      • Alpha
                                      http://3.bp.blogspot.com/-Ln3ii1OwWLM/UcoZJRv2eYI/AAAAAAAAAEg/S3B534YKka4/s1600/alpha.jpg
                                      • Clay
                                      http://1.bp.blogspot.com/-2i9dXfwrEWA/UcoY7lpJs6I/AAAAAAAAAEc/Vlga_UuMKXo/s1600/clay.jpg
                                      • Color
                                      http://4.bp.blogspot.com/--TZCVYECg1g/UcoZYUQwRwI/AAAAAAAAAEo/XB_pZQEN-6Y/s1600/color.jpg
                                      • Color by Layer
                                      http://2.bp.blogspot.com/-UHkldGwuNpg/UcoZfl52QoI/AAAAAAAAAEw/noiGAtYicpE/s1600/colorbylayer.jpg
                                      • Line
                                      http://1.bp.blogspot.com/-1isg8WjEE3c/UcoZprWsUGI/AAAAAAAAAE8/KniGlU-JD08/s1600/line.jpg
                                      http://2.bp.blogspot.com/-ODhUep8l0RI/UcoaSNRLRoI/AAAAAAAAAFQ/hqlsa1yT8C8/s1600/profile.jpg
                                      • Shadow
                                      http://2.bp.blogspot.com/-HSq562xiJqU/UcoaZuBmU3I/AAAAAAAAAFY/OQAVBZPLAOk/s1600/shadow.jpg
                                      • Texture
                                      http://1.bp.blogspot.com/-noXATCOUak0/UcoafMOlBcI/AAAAAAAAAFg/pkT38dnLi3k/s1600/texture.jpg
                                      • Zdepth
                                      http://1.bp.blogspot.com/-Kh5qvHvbl5o/UcoakYA7uqI/AAAAAAAAAFo/JMGb9X0aGKg/s1600/zdepth.jpg
                                      • renderizaR
                                        renderiza
                                        Hi, I have added a Youtube Video of CompoScene for anyone interested.
                                        Also, I am planning to add more videos of SketchUp related stuff so if you are interested you can subscibe to my channel… https://www.youtube.com/user/RenderizaStudio
                                        Enjoy!
                                        • renderizaR
                                          renderiza
                                          CompoScene Updated to v2.0.1
                                          https://s20.postimg.org/i4pm29znh/dlg.png
                                          Export Feature
                                          Added transparent export option for:
                                          *** PNG
                                          • TiFF**
                                            Note: Remember to disable the ‘Sky’ checkbox in the Style Tray options if you want the background to be fully transparent.
                                          Enjoy!
                                          _______________________________________________________________________________
                                          ❖ Get my SketchUp Extensions:
                                          • CompoScene
                                          • iSelect
                                          • Face Director
                                          ❖ Follow Me:
                                          • Twitter
                                          • Facebook
                                          • YouTube
                                          • renderizaR
                                            renderiza
                                            Fixed in CompoScene v2.0.2
                                            • Web Dialog will not appear if exit button is pressed.
                                            • Message Box asking ‘Do you want to Exit?’ after clicking outside the CompoScene UI will not be displayed now.
                                            • WebDialog has been modified & resized.
                                            • Module names have been changed.
                                            • Changed require .rb which bypassed the extension registration system preventing users from being able to disable the extension.
                                            • Now when you delete all scenes the style kept is the one in the first slot.
                                            • The default page is created with the style used before creating channels.
                                            • Fixed Save button from being hit without the export button being active.
                                            • Fixed bug that activated transparency on jpg resulting in white background on the alpha channel.
                                            • Updated Extension Info as well.
                                            Important!
                                            Delete the previous version of CompoScene before installing the new version to avoid problems…
                                            Go to Plugins folder and delete:
                                            • MiSU_CompoScene (folder)
                                            • MiSU_CompoScene.rb
                                            CompoScene is in continuous development and since I am a solo developer it’s helpful when I receive feedback on what to fix or add next.
