    [Plugin] TIG-Fracture
    39 Posts 15 Posters 15.4k Views 15 Watching
      This plugin is not working for the MAKE version ?
      • massimoM
        massimo Moderator
        404 Not Found
        (sketchucation.com)
        • KrisidiousK
          Krisidious
          Dude... I can use this for Stained Glass. Nice TIG.
          By: Kristoff Rand
            Dependencies: Pro
            Ah! curious maybe because that use some solids functions πŸ˜„
              Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG_Fracture
              It now has three options to set constraints for the splitting around the XYZ axes, 0 to 1.
              The nearer to 0 the 'flatter' the split on that axis.
              With all three set to 1 it's entirely random.
              Play with their interrelationships to see the effects.
              Also now there are three 'Form' options:
              • Stacked - all parts left in place
              • Exploded - all parts from the center
              • Scaled - each part by ~90% to leave gaps
                If a non-Stacked Form is chosen it is separately undo-able.
                All of the Fragmentation is now undo-able in one step.
                Excellent....
                [edg3d:2r4rerg8]Kkw7hxg8YhQU3ne[/edg3d:2r4rerg8]
                Another request that if there's materials in the model you can choose which material get assigned to the faces sliced faces?
                  Option for have only boxes ?
                    Voxelize?
                    • deaneauD
                      deaneau
                      cool TIG..this plugin and sketchyPhysics could be a dream team πŸ‘ πŸ‘ πŸ‘
                      • KrisidiousK
                        Krisidious
                        Nice logo Rich...
                        By: Kristoff Rand
                          Voxelize?
                          Something like only horizontal and vertical fractures! πŸ˜‰
                            Here's v4.0 http://sketchucation.com/pluginstore?pln=TIG_Fracture It now has slightly different options.
                            The 'Size' for the two parts is now 0.01 to 0.5 [1 to 50%].
                            The XYZ axes options are now better described as 'Variance'.
                            A 'Jitter' option has been added [0 to 1].
                            If an XYZ Variance is set to 0 then the splitting is done parallel to those axes.
                            The Jitter affects the randomness of the splitting plane.
                            Any Jitter is ignored if all XYZ Variances are 0.
                              Nice!
                              Any chance of material support?
                              This is a crazy tool!
                                driven
                                @rich o brien said:
                                ...Any chance of material support?...
                                if you pre-paint the group it inherits the material...
                                  jorgeeparra
                                  TNKS IMPRESSIVE PLUGIN ..
                                    not on the sliced faces. i was hoping i could load a material onto the cut face based on materials in current library.
                                      Paint the faces within the group as desired [here RGB].
                                      Paint the group itself [here Yellow].
                                      Fracture the group.
                                      The resultant pieces keep the RGB materials on any original faces, BUT any 'cut faces' will match the original group's material [Yellow]Capture.PNG
                                      • CadFatherC
                                        CadFather
                                        wow... fab plugin TIG!
                                        • deaneauD
                                          deaneau
                                          πŸ‘ πŸ‘ πŸ‘
                                          TIG, isnt better to place the download links in your first post?
                                          i look in the future and your version 10 is on the next following pages in this tread πŸ˜„
                                            @deaneau said:
                                            :thumb: πŸ‘ πŸ‘
                                            The 'Download' button always links to the Plugin's current version in the PluginStore.
                                            So the link in the first post is the same as the one in the last update post.
                                            They all take you to the same PluginStore entry.
                                            I simply thinks it's better to put a link in any update post. as it obviates the need for you to find the link in the first post or search the PluginStore... πŸ€“
                                            Anyway, enjoy playing with it πŸ˜‰
                                            • 2 / 2
