    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 537.2k Views 102 Watching
      Pu
      Thanks you Fredo 😍
      • N Offline
        nickchun
        Just been taking another look at this great looking tool, but I am having problems colouring edges. It goes though the motions but when I exit the tool(double click), the edges revert back to black. Works fine on everything else, faces, text etc. Am I missing something? Great piece of work though, thank you.
        using the tool
        on exit of tool
        • fredo6F Offline
          It's probably related to your Style setting fro edges (default, by material, axis).
          Thurpaint enable the 'Edge by Material' mode during the coloring but siwtch back to your current mode when exiting.
          So you edge probably received the color by your are not in the proper style to see them.
          • N Offline
            nickchun
            Great. I will take a look at it. Thanks for the quick reply and great plugin.
            • EdsonE Offline
              Edson
              hi fredo,
              I am having similar problems to nickchun (immediately above). I have found out about switching to Edge by Material but I cannot grasp how to choose a color and apply to edges. thrupaint seems to be stuck with the face color.
              what it is the workflow to chose a color and apply it to an edge? thanks.
              http://www.mahfuz.arq.br
              • fredo6F Offline
                @edson said:
                hi fredo,
                You need to disable the Face button in the palette. Then you will only paint edges.
                • EdsonE Offline
                  Edson
                  @fredo6 said:
                  @edson said:
                  hi fredo,
                  fredo,
                  this is not my point. I do have the Face button disabled.
                  my problem is not being able to paint the edges with the color/texture I wish to. if you look at the screen capture below you will see that ThruPaint is stuck with the material I applied to the faces, and I can only paint the edges with that texture. how can choose and apply another color/texture to the edges? in the video I see you chosing a color and applying it to edges.
                  • KrisidiousK Offline
                    Krisidious
                    If we have messed up the UVs on a curved peice of geometry, how can we reset all of the geometry to be identical? When I hit reset it doesn't seem to make all UV's the same.
                    By: Kristoff Rand
                      scndchexin
                      hao to download??
                      • TIGT Online
                        @scndchexin said:
                        hao to download??
                        From the SCF PluginStore ?
                        Get Fredo's Lib too...
                        • DesertRavenD Offline
                          DesertRaven
                          Hi Fredo6, I am doing some roads in Sketchup and I came upon your plugin "thruPaint" amongst others to get the job done. Btw, ThruPaint rocks, easy to use amazing results, as intended, in no time.
                          I also used "curvyloft" to get the ramp shape.
                          Only thing at the end of the day I ran into a weird issue exporting the finished textured roadway.
                          The road texture was broken up into many pieces as you can see in my export folder.
                          Is this a general sketchup quirk? I was assuming the plug in would only align the UW's accordingly and not chop up the texture image? ?
                          Am I missing something ? Anybody else ever had this issue?
                          Kind regards, Olav
                          simplicity is the ultimate sophistication
                            Kind regards, Olav
                            This depend on the exporter. SketchUp support UVQ - as oppose to just UV. The Q value is used for perspective mapping. Not all applications or file format support this.
                            To preserve the visual appearance some exporters will then generate new textures for faces with perspective mapping.
                              DesertRaven
                              Kind regards, Olav
                              So basically, there is no solution?
                              I'd like to have only one texture so that I can import this into Unity and apply other maps, derived from the bitmap used, like normal maps displacement maps etc... 😢
                                Not sure what format you are exporting to, but one can at the expense of some visual deviation convert UVQ to UV. Depending on the mesh the visual difference might not be that noticeable.
                                  DesertRaven
                                  FBX, and yes, it's a quad mesh.
                                    DesertRaven
                                    Dead end?
                                    • fredo6F Offline
                                      That's bascally what ThurPaint is doing. To obtain the result with a quadmesh, it does change the U, V and Q values, as you need the perspective distortion to render the quads properly.
                                      As thomthom said, this may cause a problem in the exporter.
                                      I have no solution for that, sorry.
                                        AcesHigh
                                        @desertraven said:
                                        Dead end?
                                        why don´t you try 3DS, OBJ, DAE or other format before giving up? Maybe other formats won´t have the same problem.
                                        alternativelly, you are exporting FROM Sketchup. I know there are some programs that can open Sketchup files and then you can save them as something else. I never used those programs nor I know if the end result would be different, but maybe you should try (IF there is a trial version) SimLab exporter plugin or SimLab Composer... it seems SimLab Composer can work with several formats including Sketchup. So MAYBE you can open your sketchup file in SimLab Composer and export as FBX and the result MIGHT be different...
                                          sreejithjayaram93
                                          **How do you use thru paint to texture a plain flat circular path?? I Keep getting an error in the quadmesh UV mode ... Ive attached the screen shot for the same.. 😞
                                          Thanks in advance... 😄**
                                          here it is...
                                            rv1974
                                            @desertraven said:
                                            Dead end?
                                            Take sketchuv of Whaat and do 'triangulate'. 3ds will be exported with one texture.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
