    SketchUp 2016 Wishlist
    192 Posts 69 Posters 102.5k Views 69 Watching
    • pbacotP
      Someone just mentioned Outliner. I was pointing out the plugin as another answer to the question Actually I don't know how outliner would help when I am looking at a house full of nested components. I would first have to search for that component (if it isn't a group) in a list... bleah. Let me double click (plus modifier key) on a face and be able to work on it right then ...is what I mean. And why not use the Backout plugin method with a keystroke rather than go to a special window simply to enter the root context?
        driven
        you can 'Backout' with the 'Esc' key, and 'in' with simple mouse clicks?
        what am I missing?
        • AureusA
          Aureus
          what am I missing?
          Not missing anything.
          You're right again. The ESC key does that work the with no need for any plugin (not you have to keep Outliner open).
          All you need is to press it as many times as steps you've made when going into a certain group/component.
          So for example, if you're editing a group which is inside a component which is inside another component which is...inside another group which is inside another component which is...inside another component (don't laugh - if you model a tree, you know what I mean)...then you need to press the ESC key five times in a row and voila - you've been pulled out. Luckily, it takes a 0.5 sec for those ones with quick fingers.
          • pbacotP
            Esc only take you out one level. Going out is relatively fast, though you just hit the key until you realize nothing is changing any longer. Double "clicking in" is slow depending on the speed of the model.
            Once a house model is assembled there are often many modifications or maybe you just want to change the muntins on a window. If you have used components to an advantage there will be many instances and nested componnets. "Clicking in" often needs a third click to discover you still need to click in more to the level you want. Redraws in a complex model for each click slow it down. Sometimes you can't tell if the view hasn't changed because of some subtlety or you've miss-clicked. At last you've arrived at your geometry and forgot what you came for...
            There's enough opposition to improving this, that apparently it must be non-problem to most. After years of CAD my patience for mouse clicks must be wearing thin. Case closed.
            • P
              pcmoor
              From my experience when you select the component or group in the drawing the highlighted entity shows up regardless of its position in the outliner list, clicking once on each expanding button in outliner reveals the nestings, easy to select, copy ,move, explode, outer shell, etc.even multi-select.... then one click completely out. No sore repetitive strain with multi clickings and escapes. Outliner makes it easy, no need to look it up unless you cant actually see it on the drawing, then outliner would show it even if it is hidden
              • pbacotP
                Thanks for the reply. Like I said, searching in a list. I don't see how that improves upon multiple double-clicking on an object that is "in plain sight".
                • T
                  ThunderclapMorgridge
                  Ok, To those of you who want UV mapping, why? Its already embedded in. You can texture without it. Straight onto the model itself. I love this aspect of this and its the primary reason I use this tool. Seriously making UVs is a pain and i hate it. Discovering accidently that I didn't have to. That it would take a photorealistic image and paint it without distortion onto a face is an awesome thing. Yes, I understand about normals etc. That can be prepped outside of a 3d tool anyway. The sooner UV is shot in the head the better.
                  All the other wish items I see are ones that you all could get in Blender, zbrush and other tools. I don't need rigging nor animation. I have access to that in Blender.
                  What I do want to see is:
                  1. Selectable axis arrows like in Blender so I can click one and thats the only axis it moves on.
                    2 a Move function that is isolated to move only. The bounding box turns into a a 3 ring sphere, click a ring and the component/model rotates only in that direction/axis. Move the copy and other functions elsewhere and kill the protractor. Move needs to be simple basic and not need a tutorial to relieve confusion and frustration.
                    3.an interest function that actually intersects. The purpose of intersect is to merge two components together as one. That should be the default function. Highlight both components and them merge them together, intersect and bang, one component.
                  2. OBj import
                  3. stl export
                    a match photo function that works with pictures shot from top down.
                    (I can't helicopter shots because it makes steve look like he's falling into a black hole)
                    I am happy this tool does have rigging or animation or other robust items. I don't feel It needs them.
                  • jeff hammondJ
                    in the other thread but...
                    use the arrow keys
                    so it's move only.. but also rotate? ๐Ÿ˜„
                    i get it though.. you want one of these:
                    a gumball, or gizmo, or widget, or whatever they're called.. that one is mostly move,scale, and rotate with some other functionality as well and i personally think it would be a waste to have one that only moves.
                    thomthom's bezier surface plugin has a custom made one:
                    http://sketchucation.com/forums/viewtopic.php?t=32810
                    he now works for trimble.. beg him ๐Ÿ˜„
                    intersect intersects.. you're describing Booleans.. the solid tools are boolean tools. would be nice to see their functionality on non-solids as well.
                    1. OBj import
                    until that time may come..
                    http://www.fluidimporter.com
                    • AureusA
                      Aureus
                      2 a Move function that is isolated to move only... Move needs to be simple basic and not need a tutorial to relieve confusion and frustration.
                      One doesn't need a tutorial for moving only - you move and don't press CTRL. As simple as that. But it's great that it copies things when you press CTRL. And then when you're there you type, for example "6x" and after ENTER you have 7 same things (lines, surfaces, groups, components, whatever) at the same distance. Or if you press "/6" it puts them inbetween and you don't have to calculate distances. And of course, if you use keyboard shortcuts, it's so quickly and easy.
                      The same can be said for the ROTATE tool.
                      I don't want this being changed. ๐Ÿ˜„
                      Move+copy, rotate+copy... less than 20 seconds
                      • TommyKT
                        TommyK
                        I know this was a few replies back, but I should reiterate this:
                        @jql said:
                        6 - Filters and groups on component browser for in model components and search to work on ๐Ÿ˜„ instead of warehouse
                        +1 ๐Ÿ‘
                        We shouldn't be searching 3D warehouse for models in the components browser anymore (much quicker to find things on the 3D warehouse browser now). So I would love the search box to filter in-model components. Or more accurately, the search box should filter the list of components for that context (In Model, My Collections, local collection etc)
                        This is an obvious win for:
                        • people who want to pop in an existing component into the model, without having to trawl through the list
                        • inputting data into components (name, description etc.) systematically, perhaps when preparing the model for LayOut auto label take offs.
                        • people with a system for component names (eg - all electrical items have a suffix "electrical", which effectively gives the user a palette of electrical components to easily pick from, but simply entering "electrical" into the search box)
                        • people with a local library of components
                        So yes, please do this. It would make my life so much easier.
                        While you're at it, perhaps you could integrate the component window with improved Dynamic Components? I understand that Dynamic Components uses javascript running on a browser (IE or Safari). I know Safari is slow with Javascript compared to Chrome. Perhaps get rid of Javascript and use C? I know this is a big ask, but if we want Dynamic Components to have a future, I think it probably needs to be rebuilt.
                        • jgbJ
                          jgb
                          Either REPLACE an existing SU-Ver whatever and maintain all configuration settings (toolbars, shortcuts, file locations, etc) including updated plugins and extensions so far as possible.
                          OR
                          Install the new version and transfer all old configuration settings (etc) to the new version.
                          It took me 2 1/2 days to configure my newly installed SU-15 to mirror my old SU-8.
                          jgb
                          • jujuJ
                            juju
                            OR
                            seconded, it's such bliss when upgrading software and it looks for the old installation (if present) and migrates settings, etc. to the upgraded installation.
                            • NemesisN
                              Nemesis
                              Hello.
                              I think many of us have often heard that SketchUP is not a serious 3D software, because they saw just some simple models. My small idea is to add a splash screen with most impressive SketchUP modelling examples from this thread: http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=33509 . Many software products use this kind of approach and this is good inspiration for newbies.
                              • G
                                gmolina1
                                Allow choosing Vertex colors through the API!! That would be awesome for heatmmaps and other stuff.
                                  slbaumgartner
                                  This would be a bigger change than it sounds, since Vertex isn't a Drawingelement and has no on-screen representation or material at present.
                                    Vertices are not easily accessible...
                                    But of course placing a colored-by-height 'tag component' at every vertex in a selection is already easily done with a Plugin...
                                    Chris Fulmer already made a color-by-height Plugin which colors selected mesh faces by their height; and also there are ones to color-by-slope.
                                    You can also manually project a gray-scales black-to-white [or even colored] textured material from an image, onto a mesh, so that the higher parts display in say 'white'...
                                    • DesertRavenD
                                      DesertRaven
                                      I kind of asked for this before and we all agreed that without 64 bit and loads of memory it would not go anywhere.
                                      Well now we got 64 bit and plenty of computing power. So let's see what you think.
                                      This does not have to be fancy with true colors or high resolution, just basically a pen or marker that you can use to sketch a bitmap directly on a surface.
                                      The tool could have say 4 different resolutions or anything between 320 by 320 pixels up to 3200 by 3200 pixels. 4 different line widths from thin to thick and of course an eraser.
                                      Many times I was thinking to have some pen to draw on a say empty landscape surface or wall, to sketch in some rough ideas on the fly in a presentation or work meeting.
                                      The point is that we could draw in rough geometry on a surface as a bitmap and later 3d edit with lines, arches and circles as geometry.
                                      It would only work on a special sketch material that would appear in the materials window. Each surface that gets sketched on will create its own new material. Background colors could be chosen before the first line gets drawn.
                                      simplicity is the ultimate sophistication
                                      • TommyKT
                                        TommyK
                                        I rather like this idea. I think it would work well with the sketchy way in which people use sketchup. I wonder if it can be achieved with a plugin....?
                                        • DesertRavenD
                                          DesertRaven
                                          @aerilius said:
                                          It "can" be achieved, .....
                                          [*]User workflow: The faces must be seamlessly textured before. This is trivial for planar projections, but in many cases users would need more advanced mapping techniques to avoid image stretching.[/list]
                                          What if this would only allow one face/coplanar shape at a time? One texture image per face at a time is produced? The pen sticks to this face during the command / operation and only draws in the limits of the extents. Maybe by pressing the alt key it also aligns, zooms to extents and centers the camera to the face in question?
                                          2048 resolution would be sufficient. The image size will automatically fit to the size of the face's extents/ bounding box. The origin is set in the lower left corner of the extent/bounding box.
                                          E.g. My wall is a n-gon shape/ face, as I attempt to draw on it SU creates a texture image this image is treated like any other image you can load into SU.
                                          I don't know what it would take to get rid of the limitations of the "API", but maybe there is a way?
                                          Maybe not as a plug in but as a native SU tool?
                                            Aerilius
                                            It "can" be achieved, but not reasonably good and usable. In fact I have this laying around for a couple of years. I'm not sure how useful it is (since resolution is very limited in SketchUp to 1024โ€“2048px, and SketchUp does not have adaptive texture resolution techniques like Ptex). There are a couple of problems that would lead to undesired behaviors:
                                            • Interactivity: SketchUp's API does not allow direct pixel manipulation, and saving images to disk and reloading takes a too big fraction of a second, and makes it feel very sluggish.
                                            • Mousemove events: SketchUp signals only mouse positions in time steps. When the mouse hovers a face and then leaves it (to hover another face or empty space), it is hard to reconstruct the path that the mouse took in between, it requires a lot of intersections which had sometimes numerical errors.
                                            • User workflow: The faces must be seamlessly textured before. This is trivial for planar projections, but in many cases users would need more advanced mapping techniques to avoid image stretching.
                                            • 7 / 10
