    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] CADup
    64 Posts 28 Posters 88.1k Views 28 Watching
    • yorik1984Y Offline
      yorik1984
      Thank you for work!
      Can the script do this tipe of projection of detail?
      http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
      And, optionaly, if it posible, user can choose what projection they need.
        Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
        It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
        • V Offline
          vfz
          Hey TIG,
          seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
          When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
          the ruby console says
          "skad
          Error: #<TypeError: reference to deleted ComponentInstance>
          <main>:in <main>' -e:1:in eval'
          nil"
          what do i do wrong?
            Unsure.
            It's an old plugin, but should still work in v2014...
            Do you always get the error?
            Can you post of PM a SKP containing the problem component...
            ๐Ÿ˜•
            • V Offline
              vfz
              Thanks for the fast answer.
              I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
              I really feel like an idiot now, but I don't see where can I send pm.
                I now have your PM and SKP.
                Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                • V Offline
                  vfz
                  Thanks TIG for the help. I've found my mistake. There were components inside the component.
                  I exploded everything and made one group/component and your plugin worked like a charm!
                    Thanks, saves me having to fix it ๐Ÿ˜‰
                      tombyrne
                      Ive Recently installed the CADup extension, I tried both ways, through the software and dropping it in the plugins folder, but I cant find it anywhere within the software, it tells me that its installed and ready for use but no sign of it, I looked under plugins and also toolbars,
                      Any tips?
                        So, select your Component-Instance OR Group [and nothing else].
                        Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
                        Ruby Console]
                        Nothing of this works for you?
                          Ruby Console]
                          As Pilou says - it appears under the 'Tools' menu as 'CADup'.
                          It works in all versions of SketchUp from v2015 downwards - at least down to v8, but I suspect Pilou uses it in an even earlier versions. ๐Ÿ˜‰
                          It is not without its foibles... some text on 'right-hand elevations/sections can get offset somewhat to the right - edit the container and relocate it manually; also the Axo views can sometimes over lap the last Ortho view nearest to them, but they can also be relocated easily...
                          Sometimes a few edges are missed off...
                          Its function is really to create a set of 2d Ortho/Axo views from a 3d component.
                          For DXF/DWG export for use to CAD - the CADup layering allows you to differentiate between hidden lines etc in the CAD display...
                            Here's v1.3.
                            A quick botch to trap some errors and signed for v2016...
                            Still very slow and flaky but it's just an idea...
                            http://sketchucation.com/pluginstore?pln=CADup
                              pibuz
                              ..am I the only one thinking this plugins is REALLY AWESOME and would need an update? This really has a great potential: reducing models to 2d lines inside SU could ease the load of layout in recalculating vector viewports!
                              TIG, is this a project you had some ideas on or not?
                              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                abuabu1982
                                Dear My Friend/
                                You created great Plugin. could you update it for Sketchup2022?
                                  Please install the latest version from the PluginStore [v2.0].
                                  It should be compatible with newer versions of SketchUp...
                                    mclaramoura
                                    Hello, TIG. Tnks for this, its amazing!
                                    Sorry my english, but i have a question.
                                    Working with Layout for Sketchup, will be insteresting if the plugin make cenes of this planes. Its possible?
                                    Remember me this Revit tool > https://help.autodesk.com/view/RVT/2024/PTB/?guid=GUID-3DD5B596-D353-489D-96EF-E3F46D287E5D
                                    With this, 2D orthogonal views will be referred to the model, updating when make changes in the model. I can do this manually, but can be a fast way to detail one architecture project with lot of carpentry. Basicly, one plugin that make cenes (section, top view, front view, axo...) of a component with one click.
                                    What do you think about that?
                                      What version of SketchUp are you actually using? You put 2018 Free/Make in your profile but that version has never existed.
                                        mclaramoura
                                        i work with skechup 2020 and recently 2023.
                                        • 3 / 4
