[Plugin] FollowMe and keep (v0.04 update 20090210)
Trying to make a screw conveyor, using Follow me helix, making a profile, then trying FAK, the result is not pretty, nor round as it should be. Quite frustrated at this point.
Try Screw_1.5.
Got my problem solved, what I was doing was not FAKs fault, apparently there is a issue with Follow me helix, and doing what I wanted, I went and got drawhelix13, good to go!
good day can someone help me off here im having problem with downloading and installing of follo me tool please help thank you
How can we help with no information of what you tried to do?
Downloading in general is basic knowled. You should tell a bit more.
Installation problems is not possible when you could not download it. -
Hi can someone help. I'm trying to create a Spiral Guard see attached image.
I've created a Helix (The path used to create the helix was also used to create the wire/cable that runs inside the Helix). Using the helix I'm trying to create the Spiral Guard that will wrap around the wire. But I've had no luck. The profile I've created is not following the helix the way I want. any ideas?
Please find attached a SU example.
You might have more luck with ...
Follow me Helix
http://sketchucation.com/forums/viewtopic.php?p=353956
or Helix along curve
http://sketchucation.com/forums/viewtopic.php?t=51770 -
Follow me Helix
http://sketchucation.com/forums/viewtopic.php?t=51770Thanks for the quick reply Box.
I used Helix along curve to create the Helix. I'm having trouble creating the 'Spiral Guard'. I've drawn a profile (cross section of the 'Spiral Guard') but I can't get it to follow the Helix the way I would like Using FMK or SUs Follow Me tool. I'll have a look at Follow me Helix
Hi, have installed the plug-in and worked fine. Today i m trying to use the tool, but simply dont work. What may i do ?
You may upload an image or the model...
Is it in your plugins folder? Are you using an updated version of SketchUp?
I somehow find out how I solved mine.
If your problem is same as mine, open your FAK.rb and paste this line of code on the very top line:
require 'sketchup.rb'
Save it, then make sure the rb file is in the tools folder and not in the plugins folder. -
Incredible!
Thank you! Why don't you distribute this through sketchup and sign it? It is very nice work and it would make it easier for the user.
gggg
Do you have an English version?
This is a really old plugin, it's encrypted and terribly out of date !
Also it ships in its RBZ in two versions - the EN one is actually in Chinese and always fails, the other file [CN?] is actually in ENglish and works !
There are instructions in earlier posts on how to fix this...In any case it may well prove flaky in newer versions of SketchUp, but you can try it and see...
Wikii,
I can see the extension in my Extension Manager, but it shows up as, ‘Blocked’. If I click on the arrow, I am advised that it is unsigned.
What do I do please?
johnmtb
@johnmtb said:
Wikii,
johnmtb
unsigned isn't a problem the extension will work just fine, just relax your extension loading policies
juju,
I have done as you suggest and it is now in the Extension Manager as enabled.
It also appears as FollowMeAndKeep, under Extensions, but I do not see it in the Toolbars, so how do I get it onto the main screen?
johnmtb
Read the tool's usage notes.
Many Extensions don't appear under the Extensions menu !
Some appear elsewhere - e.g. for Fredo's tools are under:
Tools > Fredo Collection OR Fredo Tools...The Toolbars are activated separately...
To use Extensions/Plugins effectively you must read their usage notes...
So don't even have menu items - e.g SectionCutFace which is a context-menu tool only available when there's a selection of a single Section-Plane...
