    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 220.5k Views 79 Watching
    • gillesG
      gilles
      404 Not Found
      (sketchucation.com)
      • T
        tspco
        Got my problem solved, what I was doing was not FAKs fault, apparently there is a issue with Follow me helix, and doing what I wanted, I went and got drawhelix13, good to go!
        archydro.skp
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        • U
          uma30
          good day can someone help me off here im having problem with downloading and installing of follo me tool please help thank you
          • BurkhardB
            Burkhard
            How can we help with no information of what you tried to do?
            Downloading in general is basic knowled. You should tell a bit more.
            Installation problems is not possible when you could not download it.
            http://www.ia-plus.de
              Aroundthebend
              Hi can someone help. I'm trying to create a Spiral Guard see attached image.
              I've created a Helix (The path used to create the helix was also used to create the wire/cable that runs inside the Helix). Using the helix I'm trying to create the Spiral Guard that will wrap around the wire. But I've had no luck. The profile I've created is not following the helix the way I want. any ideas?
              Please find attached a SU example.
              This is an image of a Spiral Guard.
              attached a SU example of helix and profile used when trying create Spiral Guard using FollowMe and Keep
              • BoxB
                You might have more luck with ...
                Follow me Helix
                http://sketchucation.com/forums/viewtopic.php?p=353956
                or Helix along curve
                http://sketchucation.com/forums/viewtopic.php?t=51770
                  Aroundthebend
                  Follow me Helix
                  Thanks for the quick reply Box.
                  I used Helix along curve to create the Helix. I'm having trouble creating the 'Spiral Guard'. I've drawn a profile (cross section of the 'Spiral Guard') but I can't get it to follow the Helix the way I would like Using FMK or SUs Follow Me tool. I'll have a look at Follow me Helix
                  • C
                    callinas
                    Hi, have installed the plug-in and worked fine. Today i m trying to use the tool, but simply dont work. What may i do ?
                    • cottyC
                      cotty
                      You may upload an image or the model...
                      my SketchUp gallery
                      • T
                        tailgater
                        Is it in your plugins folder? Are you using an updated version of SketchUp?
                        I somehow find out how I solved mine.
                        If your problem is same as mine, open your FAK.rb and paste this line of code on the very top line:
                        require 'sketchup.rb'
                        Save it, then make sure the rb file is in the tools folder and not in the plugins folder.
                        • T
                          terrylewis
                          Incredible!
                          Thank you! Why don't you distribute this through sketchup and sign it? It is very nice work and it would make it easier for the user.
                          • I
                            idcampza
                            ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ gggg
                              ricdach
                              Do you have an English version?
                                This is a really old plugin, it's encrypted and terribly out of date !
                                Also it ships in its RBZ in two versions - the EN one is actually in Chinese and always fails, the other file [CN?] is actually in ENglish and works !
                                There are instructions in earlier posts on how to fix this...
                                In any case it may well prove flaky in newer versions of SketchUp, but you can try it and see...
                                  JohnMTB
                                  Wikii,
                                  I can see the extension in my Extension Manager, but it shows up as, โ€˜Blockedโ€™. If I click on the arrow, I am advised that it is unsigned.
                                  What do I do please?
                                  johnmtb
                                  • jujuJ
                                    juju
                                    @johnmtb said:
                                    Wikii,
                                    johnmtb
                                    unsigned isn't a problem the extension will work just fine, just relax your extension loading policies
                                      JohnMTB
                                      juju,
                                      I have done as you suggest and it is now in the Extension Manager as enabled.
                                      It also appears as FollowMeAndKeep, under Extensions, but I do not see it in the Toolbars, so how do I get it onto the main screen?
                                      johnmtb
                                        Read the tool's usage notes.
                                        Many Extensions don't appear under the Extensions menu !
                                        Some appear elsewhere - e.g. for Fredo's tools are under:
                                        Tools > Fredo Collection OR Fredo Tools...
                                        The Toolbars are activated separately...
                                        To use Extensions/Plugins effectively you must read their usage notes...
                                        So don't even have menu items - e.g SectionCutFace which is a context-menu tool only available when there's a selection of a single Section-Plane...
                                          JohnMTB
                                          TIG,
                                          where do I find the usage notes?
                                          johnmtb
                                            The '[More ]Info' button when considering downloading/installing etc is a good starting point, but also read the main thread's posts for each tool - there are often good tips and advice in those...
                                            • 11
                                            • 12
                                            • 11 / 12
