    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 220.5k Views 79 Watching
    • N
      News
      And thank you Box, i can open it now!
      • N
        News
        @tig said:
        Either draw in the missing piece, or perhaps more easily - deselect everything, and then use the Move tool to drag and relocated the end of one part snapped onto the other, thereby closing the gap.
        Double-click again and everything should highlight.
        What i don't understand is that when i use the move tool at the end of the straight line on the top, the curved line moves with it, as if it was already snapped. So i don't figure out where is the gap you are talking about
          With nothing selected the Move tool looks for objects below the cursor and offers you the best hit.
          That can be a face, edge or the start/end vertex of a edge - hover over the very end and it should display a green-dot, then press+drag that to the nearby other vertex - on the other side of the gap... then the gap is 'healed'...
          • N
            News
            Thank you for your answer.
            I had to redraw all the path in one time, because even doing what you said at last, it wasn't working. I am sure there's something i don't get, i'll figure out one day.
            Thank you for all your effort !
            • T
              tspco
              Trying to make a screw conveyor, using Follow me helix, making a profile, then trying FAK, the result is not pretty, nor round as it should be. Quite frustrated at this point.
              fakerror.skp
              SU make 2017, /Twilight Render Hobby
              Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
              • gillesG
                gilles
                Try Screw_1.5.
                • gillesG
                  gilles
                  404 Not Found
                  (sketchucation.com)
                  • T
                    tspco
                    Got my problem solved, what I was doing was not FAKs fault, apparently there is a issue with Follow me helix, and doing what I wanted, I went and got drawhelix13, good to go!
                    archydro.skp
                    • U
                      uma30
                      good day can someone help me off here im having problem with downloading and installing of follo me tool please help thank you
                      • BurkhardB
                        Burkhard
                        How can we help with no information of what you tried to do?
                        Downloading in general is basic knowled. You should tell a bit more.
                        Installation problems is not possible when you could not download it.
                        http://www.ia-plus.de
                          Aroundthebend
                          Hi can someone help. I'm trying to create a Spiral Guard see attached image.
                          I've created a Helix (The path used to create the helix was also used to create the wire/cable that runs inside the Helix). Using the helix I'm trying to create the Spiral Guard that will wrap around the wire. But I've had no luck. The profile I've created is not following the helix the way I want. any ideas?
                          Please find attached a SU example.
                          This is an image of a Spiral Guard.
                          attached a SU example of helix and profile used when trying create Spiral Guard using FollowMe and Keep
                          • BoxB
                            You might have more luck with ...
                            Follow me Helix
                            http://sketchucation.com/forums/viewtopic.php?p=353956
                            or Helix along curve
                            http://sketchucation.com/forums/viewtopic.php?t=51770
                              Aroundthebend
                              Follow me Helix
                              Thanks for the quick reply Box.
                              I used Helix along curve to create the Helix. I'm having trouble creating the 'Spiral Guard'. I've drawn a profile (cross section of the 'Spiral Guard') but I can't get it to follow the Helix the way I would like Using FMK or SUs Follow Me tool. I'll have a look at Follow me Helix
                              • C
                                callinas
                                Hi, have installed the plug-in and worked fine. Today i m trying to use the tool, but simply dont work. What may i do ?
                                • cottyC
                                  cotty
                                  You may upload an image or the model...
                                  my SketchUp gallery
                                  • T
                                    tailgater
                                    Is it in your plugins folder? Are you using an updated version of SketchUp?
                                    I somehow find out how I solved mine.
                                    If your problem is same as mine, open your FAK.rb and paste this line of code on the very top line:
                                    require 'sketchup.rb'
                                    Save it, then make sure the rb file is in the tools folder and not in the plugins folder.
                                    • T
                                      terrylewis
                                      Incredible!
                                      Thank you! Why don't you distribute this through sketchup and sign it? It is very nice work and it would make it easier for the user.
                                      • I
                                        idcampza
                                        πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ gggg
                                          ricdach
                                          Do you have an English version?
                                            This is a really old plugin, it's encrypted and terribly out of date !
                                            Also it ships in its RBZ in two versions - the EN one is actually in Chinese and always fails, the other file [CN?] is actually in ENglish and works !
                                            There are instructions in earlier posts on how to fix this...
                                            In any case it may well prove flaky in newer versions of SketchUp, but you can try it and see...
                                            • 11
                                            • 12
                                            • 10 / 12
