    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
    • TK0001T
      TK0001
      About this time last year, I discovered clicking on the arrow buttons locks you into that axis when moving or copying objects. Now I use the arrows religiously.
        rv1974
        To migrate 2013 Shortcuts to 2015 one should open Preferences.dat in Notepad and use 'find and replace' feature to replace all 'Plugins' words with 'Extensions'.
        Important: there must be only one backspace between the shortcut descriotion and the 'Extensions' word.
        2015 Plugins folder location:
        C:\Users\Your_Username\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
        • oceanembersO
          oceanembers
          shift to lock inferences/directions/etc. was one that I found way too late x_x
            Never seen that! 😳
            Draw a circle, Select the circumference : right Click / Divide ! 😲
            Works only one time! πŸ€“
            http://sketchucation.com/forums/download/file.php?id=126133
            • BoxB
              It only works one time Pilou because once you divide it it becomes separate segments. Those individual segments can then be divided, and the divisions can be divided etc
              It works with polygons and arcs also. There is even at least one plugin that I know of that will put the segments back together so you can divide the circle again. So you can go round and round again.
                ...and speedy fill your computer memories! πŸ˜„
                • david_hD
                  david_h
                  Quick question. . .It seems to me that in SU's long past. . .version 4 or so there was a push pull trick where you could just click on a shape to be PP'd and then either hold a shift key to lock the axis or and endpoint of something and it would just auto push to that point. Kinda like Follow me, but it was innate to the PushPull tool. Does anyone remember this?
                  Thx,
                  D
                  • cottyC
                    cotty
                    There are different options in Fredo6s JointPushPull (like vetor push pull), something like that?
                    my SketchUp gallery
                    • david_hD
                      david_h
                      Yeah. . I've got those and they're great. It just seemed to me there was a native SU trick to do that, but I guess I am mistaken. Hence the D'oh!
                      • jeff hammondJ
                        Thx,
                        D
                        the only push/pull modifier key is:
                        Option(alt) = create new starting face.
                        (as seen in the lower left hand corner of the drawing window πŸ˜‰ )
                          Can you put an image of that ?
                          • BoxB
                            It's Ctrl on windows.
                            • jeff hammondJ
                              oops.. thought it was ctrl for cmmd & alt for option
                              thanks
                              • BoxB
                                Don't you mean D'oh instead of oops!!?
                                  I am reassured! πŸ˜„
                                  • jeff hammondJ
                                    πŸ˜† d'oh!
                                    you're right.
                                    • emerald15E
                                      emerald15
                                      Not so much 'Doh' but 'Eureka'! for me. I've been trying to draw a circle directly to the vertical plane for a least two years! 😳 I only knew it was possible from watching other video clips. At last I've found this thread! πŸ˜„
                                      404 Not Found
                                      (sketchucation.com)
                                      • pbacotP
                                        @cotty said:
                                        I didn't know that you can get non-perpendicular axes 😲
                                        This seems less like a "Duh!" than "WTF!" What could one (mortal) do with such a thing?
                                        • Bob JamesB
                                          Bob James
                                          @jql said:
                                          Apologies accepted if you post it on the Duh thread!
                                          So here goes my duh:
                                          @bob james said:
                                          This seems so simple that it must already exist, but I could not find it.
                                          For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
                                          I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
                                          I apologize if this already exists
                                          @jql said:
                                          LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
                                          Or you can make your life painless if you draw a 4 sided polygon without exploding it.
                                          Those two are native tools. Do you forget sketchup also has native tools?
                                          @bob james said:
                                          Duh 😳
                                          (But still think it would be a useful one-click native tool) πŸ˜†
                                          • JQLJ
                                            JQL
                                            πŸ‘Ώ All that ::DUH:: belong to us! πŸ‘Ώ
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
