    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • falkF
      falk
      Thanks. And now that I've made it to the end of this thread (Best. Thread. Ever.), here's a tiny little plugin that I use all the time. It adds a "Show shortcuts" item to the Help menu. I find it very useful when I can't remember what I've assigned keys to. Especially when you're trying to assign a shortcut, and preferences tells you that key is already in use, and you can't remember what for.
      show_shortcuts.rb
        You should try Shortcutter plugin.
        It is bundled with SketchUcation Tools
        • TK0001T
          TK0001
          About this time last year, I discovered clicking on the arrow buttons locks you into that axis when moving or copying objects. Now I use the arrows religiously.
            rv1974
            To migrate 2013 Shortcuts to 2015 one should open Preferences.dat in Notepad and use 'find and replace' feature to replace all 'Plugins' words with 'Extensions'.
            Important: there must be only one backspace between the shortcut descriotion and the 'Extensions' word.
            2015 Plugins folder location:
            C:\Users\Your_Username\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
            • oceanembersO
              oceanembers
              shift to lock inferences/directions/etc. was one that I found way too late x_x
                Never seen that! 😳
                Draw a circle, Select the circumference : right Click / Divide ! 😲
                Works only one time! πŸ€“
                http://sketchucation.com/forums/download/file.php?id=126133
                • BoxB
                  It only works one time Pilou because once you divide it it becomes separate segments. Those individual segments can then be divided, and the divisions can be divided etc
                  It works with polygons and arcs also. There is even at least one plugin that I know of that will put the segments back together so you can divide the circle again. So you can go round and round again.
                    ...and speedy fill your computer memories! πŸ˜„
                    • david_hD
                      david_h
                      Quick question. . .It seems to me that in SU's long past. . .version 4 or so there was a push pull trick where you could just click on a shape to be PP'd and then either hold a shift key to lock the axis or and endpoint of something and it would just auto push to that point. Kinda like Follow me, but it was innate to the PushPull tool. Does anyone remember this?
                      Thx,
                      D
                      • cottyC
                        cotty
                        There are different options in Fredo6s JointPushPull (like vetor push pull), something like that?
                        my SketchUp gallery
                        • david_hD
                          david_h
                          Yeah. . I've got those and they're great. It just seemed to me there was a native SU trick to do that, but I guess I am mistaken. Hence the D'oh!
                          • jeff hammondJ
                            Thx,
                            D
                            the only push/pull modifier key is:
                            Option(alt) = create new starting face.
                            (as seen in the lower left hand corner of the drawing window πŸ˜‰ )
                              Can you put an image of that ?
                              • BoxB
                                It's Ctrl on windows.
                                • jeff hammondJ
                                  oops.. thought it was ctrl for cmmd & alt for option
                                  thanks
                                  • BoxB
                                    Don't you mean D'oh instead of oops!!?
                                      I am reassured! πŸ˜„
                                      • jeff hammondJ
                                        πŸ˜† d'oh!
                                        you're right.
                                        • emerald15E
                                          emerald15
                                          Not so much 'Doh' but 'Eureka'! for me. I've been trying to draw a circle directly to the vertical plane for a least two years! 😳 I only knew it was possible from watching other video clips. At last I've found this thread! πŸ˜„
                                          404 Not Found
                                          (sketchucation.com)
                                          • pbacotP
                                            @cotty said:
                                            I didn't know that you can get non-perpendicular axes 😲
                                            This seems less like a "Duh!" than "WTF!" What could one (mortal) do with such a thing?
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
