    [Plugin] Mirror
    211 Posts 72 Posters 474.0k Views 72 Watching
      A "bit of a falling out" in the pre-EWH days... while SCF PluginStore was already being setup...
      A loooooooooooong story...
      I might forgive them one day πŸ˜‰
        Here's an updated v4.2, in the PluginStore http://sketchucation.com/pluginstore?pln=Mirror
        I have adjusted the description in the tool's page to explicitly say it's PC & MAC compatible, for all SketchUp versions ! Some users were misunderstanding and assuming it was PC only !
        I have also adjusted the script so that now it only installs the additional toggleWindows script [now loaded from .txt] and Win32API.so if the computer is a PC AND the SketchUp version is old [<v2014] - this workaround was introduced to sidestep rare Outliner crash issues, in older SketchUp versions on PCs. This is not needed for newer SketchUp versions, or on any MACs at all - so now if the files were previously installed they are now deleted to keep things tidy.
        πŸ€“
          Mucho gracias
          • K
            kaas
            Great plugin. Thanks for the update. I use it quite often. Quite strange this function has never been added to the native SU tools.
            • josephkim626J
              josephkim626
              Probably this is a single plugin I use most often.
              On that note TIG, I have a small request to make. Can you change or allow us to change the settings to have the newly generated object/geometry to be selected after the mirror command?
                I'm not changing the established selection staying with the retained original.
                BUT it's quite easy for you to adjust your own RB file yourself.
                Use Notepad/Notepad++ [PC] or TextWrangler[MAC] to edit it - NEVER use a Wordprocessor with Ruby files.
                The existing code at line #392 needs a new line of code adding - just before the 'commit_operation' -
                 @ss.clear; nents.each{|e|@ss.add(e) if e.valid?}
                Now the selection always passes to the copy, whether or not you have chosen to keep the originals.
                  seasdes
                  Will this plugin work with SU2015?
                  Using Sketchup Pro 2019
                    It works fine with SU2015. Do you have some reason to think it wouldn't?
                      seasdes
                      Thanks for your reply. The reason that I ask is that SU 2015 is not listed in the Sketchucation store.
                        Currently the choices offered for 'compatibility', to authors when they are setting up their PluginStore entries are <=v8, v2013 and v2014.
                        If there were a v2015 it'd be used.
                        I've PM'd GΓ‘bor about adding that choice - OR changing to ">=v2014".
                        The good news is, if a Plugin is compatible with v2014, then it is almost certainly going to be compatible with v2015.
                        The big changes in coding came at v8/v2013 and then the biggy at v2014, as that used a newer version of Ruby which handles a few things slightly differently, and is less forgiving of sloppy syntax etc, so there were potential issues stepping up versions.
                        However, most authors updated their Plugins to suit the new Ruby when v2014 came along around a year ago.
                        The main outstanding incompatibility was with Dider Bur's tools - but with his permission I have recently finished updating those to be compatible with the newer SketchUps - now available in the PluginStore.
                        A v2014 compatible tool is almost certainly going to work in v2015, but it might have some issues when used in v2013 or even more likely <=v8, particularly if it now relies on some of the new features only available in the newer Ruby version etc, and there the author has included no workarounds for the earlier versions.***
                        There are a few new methods now available in v2015, but that is more likely to mean that a v2015 based tool will not work [or be restricted] in earlier versions, which lack that new functionality.
                        ***For example the SCF PluginStore toolset itself makes use of several of the new features available in the newer Ruby [v2014/v2015], but it is written to find the version of SketchUp running it, and where needed it runs alternative code - this may be slower, more clunky etc, but at least the user still gets most of the toolset's functionality, even when they have an old SketchUp version...
                          seasdes
                          Thanks for your reply TIG.
                          • josephkim626J
                            josephkim626
                            Great! I can try that.
                            Thank you so much TIG
                            -----------------edit
                            Works great.
                            Thank you so much for your help TIG!
                            • kimi kimiK
                              kimi kimi
                              Hi TIG,
                              First of all, I really appreciate all of your work! Everything you created is so awesome. I just wanted to ask you one thing. Could you make another plugin, almost the same as this one. It's also a mirror plugin. But it mirrors only against a vertical plane. 90% of these mirror operations, at least in my experience, end up by choosing the blue axis. It would be cool if we could just make 2 clicks instead of 3. I hope you can consider this request.
                              And one more thing I would probably change is that "Erase original selection?" question. It's sometimes really hard to focus and "talk" to SketchUp after a long day. I often forget if it's asking me to erase or to keep, and I'm too tired to read. So, my preference would be to have these two possibilities as two separate commands or shortcuts.
                              I know I'm getting to 4 different outcomes now with all that I wrote. Maybe call it mirror pro? πŸ˜„
                              Anyway, I never had any problems with your plugins. It always executed perfectly without any problems. I just thought you could save us a few clicks. And since I use this thing at least 100 times a day, it would really mean a lot to me.
                              Best regards!
                              • cottyC
                                cotty
                                You can change the dialog in such a way that the more often used answer is the default one which you can simply choose by hitting the enter key without reading the text...
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=31410%26amp;p=510289%26amp;hilit=dialog#p510289
                                (The mirroring with two clicks is occupied by the mirror through an axis)
                                my SketchUp gallery
                                • Bob JamesB
                                  Bob James
                                  Since my most likely next operation is to move the new mirrored object, I've made the changes Tig provided. In doing so I noted that 12 additional lines have been added to the original post noted by cotty. So note the following nit-pick update to Tig's great plugin:
                                  ***Edit the "Mirror.rb" script with a plain-text editor - like Notepad++ - and find line #367 and change
                                  @msg = "Mirror: Erase Original Selection ?"
                                  to read:
                                  @msg = "Mirror: Keep Original Selection ?"
                                  so that the stausbar prompt is in step...
                                  Then go to line #379
                                  if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6 ### 6=YES 7=NO
                                  edit it to read:
                                  if UI.messagebox("Keep Original Selection ? ",MB_YESNO,"")==7 ### 6=YES 7=NO
                                  which reverses the question and the result of Pressing 'Yes'...
                                  For tidiness's sake also on line #381
                                  else ### NO
                                  change the rem note 'NO' after the ### to:
                                  else ### YES
                                  UPDATE
                                  Since my most likely next operation is to move the new mirrored object, is there something I can change so that after I hit Return that the copy is selected rather than the original?
                                  • pbacotP
                                    Using this GREAT tool a lot lately in framing models. Thanks for the note James. I really never want to erase the original, it seems, and it would be easier to just delete it rather than answer that dialog.
                                    • Bob JamesB
                                      Bob James
                                      If this is directed to me, I don't understand your reply.
                                      What I would prefer is that the new mirrored object be the one selected so I can immediately move it. This leaves me with the original in its location and the mirrored copy in the moved location.
                                      No big deal: super extension πŸ‘
                                        I'll consider your ideas in any future updates...
                                        • pbacotP
                                          I thought your edits would obviate answering whether to erase original each time. I guess COTTY was actually the one to show that. I don't care regarding selection afterwards as I do NOT usually move the object.
                                            Here's v5.0.
                                            It's now an extension and is future-proofed...
                                            • 11
                                            • 8 / 11
