    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    451 Posts 143 Posters 669.3k Views 142 Watching
    • JClementsJ Offline
      JClements
      Awesome! Thank you.
      Did you keep track of the number of hours you spent developing this? I'm guessing it was massive.
      Regards, John
      • CadFatherC Offline
        CadFather
        ๐Ÿ˜ฒ i just have a question... WHO is Fredo6!!! ๐Ÿ˜†
        this stuff should be in the evening news!
        Thanks Fredo
        • pbacotP Offline
          I just used this on imported contours that I had reworked in CAD beforehand. Toposhaper was the smoothest part of the whole operation. Looking good. If you need another real world case, I can send it. I also made some simple fill outlines from the building and edges from the mesh. Ran Toposhaper to create those as well. Thanks Fredo!
            And at the end apply a Color by Z (By Chris Fullmer or Sdmitch) and you will have a perfect tool for Topography! ๐Ÿ˜Ž
            • cottyC Offline
              cotty
              Fantastic update, thank you!
              my SketchUp gallery
              • fredo6F Offline
                I am indeed interested by this real world case!
                  Panga
                  Fredo, what can I say...and my parents were telling me that Santa dit not exist !! I'll try it right now and give you some feedback, but I'm already give you my BRAVO !
                  Regards.
                  • utilerU Offline
                    utiler
                    Ahhh, toposhaper from cloud points! Just what I needed when I asked this question:
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=53781
                    Thank you Fredo. You are genius!!!
                    purpose/expression/purpose/....
                    • utilerU Offline
                      utiler
                      I too am happy to send you real world case, Fredo. I have a few good surveys that I can send you....
                      One question re: cloud points: when a survey file is sent you to the points are provided as just that; points. Do I have to somehow convert them to guide points? And if so, how??
                        pierro44
                        super plugin congratulations Fredo6,
                        is it possible for you to improve the plugin by adding the stamp function because the basic function of Sketchup does not function well with a non-flat platform.
                        we could from the current stamp function by adding a regular slope adjustment feature. (angle parameter).
                        Because of Sketchup stamp function offers a parrallel offset.
                        this feature could be ideal for earthmoving ground with regular slope even allows pente.it's draw on autocad perfectly calibrated slope and sutout non parrallel.
                        excuse me for my English I am french
                        thank you
                          pierro44
                          hi, I am a draftsman in an architectural firm, the "toposhaper" function is beautiful, congratulations FREDO 6, it works great.
                          I have an idea to improve the plug-in by adding a function on the basis of the tool "STAMP" to create platform on an existing field (created by toposhaper) with a side slope adjustment function that will permit to have non parrallel slope to the platform.
                          What about you? -
                          Is this possible?
                          The "STAMP" of Sketchup does not work very well and slopes are parrallel to the platform.
                          Thank you.
                          Sorry for my English, I'm French
                          • fredo6F Offline
                            NEW RELEASE: TopoShaper v2.1a - 25 Mar 14
                            This release provides a documented service API to calculate terrains from isocontours. It also fixes a few bugs.
                            See main post of this thread for Download of TopoShaper.
                            • KrisidiousK Offline
                              Krisidious
                              Thank You Fredo...
                              By: Kristoff Rand
                                Hi Fredo,
                                Do you think adding csv import to Toposhaper is feasible?
                                This would make terrain generation much more unified into one tool rather than installing 2 plugins to what you need in one.
                                • pbacotP Offline
                                  I think I said this before. Excellent work on this!
                                  When I use it I wish the grid could be set to a standard horizontal square dimension and set to always align to the origin. then work can be more easily patched and combined.
                                  Another wish is for the edges to be restricted to conform (close as possible) to land on a bounding contour. Again this will help joining with other forms.
                                    does toposhaper can use this sort of file ?
                                    Because it generates bugs! ๐Ÿ˜ฎ
                                    (I have last version Prog / Lib )
                                    test_topo.skp
                                    • fredo6F Offline
                                      Pilou,
                                      What do you mean by 'use'.
                                      Did you generate the terrain via Toposhaper QaudMesh instead?
                                        Start from this file
                                        No just speedy by hand for the grid (a copy/Move square) + SandBox for deformation
                                        • pbacotP Offline
                                          The plugin requires Point cloud or isocontours.
                                            Seems that is the key ! ๐Ÿ˜„
                                            When I create points from the file then use TopoShaper that works!
                                            (except for the little triangle bottom left corner? )
                                            PS The alert message when you select points who are not a group/ component is empty!
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
