    CFileException 3 - ERROR!
    25 Posts 12 Posters 29.9k Views 12 Watching
      Are both of you running SU8? As mentioned in your profile?
      Can you right click the SU .exe file and Run As Admin
      • utilerU
        utiler
        2013 Rich. And thanks for bringing that to my attention.....
        Just Curious...
        • utilerU
          utiler
          Still getting this error on opening at first autosave.... pretty annoying!
          Just Curious...
          • N
            nu2net
            Having this error too with Sketchup 2013. Any solutions for this?
            • john2J
              john2
              I am getting this error with SU 2015 Make. What is wrong? Surprisingly, I saw this error for the first time ever while using sketchup. I have installed version 2014 also on my laptop but never get this error. Is there anyone who was able to fix this but never replied? πŸŽ‰
              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                Is the SketchUp.exe set in Right-click > Context-menu > Properties > Compatibility to 'always run as administrator' ?
                If not try ticking that box and restart SketchUp...
                Errors with 0.skb etc seem to occur on slow network connections, non-local folder locations or when the SKP is on say a memory-stick...
                Although you have obscured some of the path I expect that is to your own folder on the πŸ˜„ drive ?
                Have you checked that you, admins and SketchUp have FULL permission to write to that folder ?
                Is SketchUp.exe on the πŸ˜„ drive - where your SKP is ?
                What happens is that when you have 'make backup files' set you get the model's xxx.skp and the backup xxx.skb, which is the previous version of the model, when there is a save the old xxx.skb gets renamed 0.skb [or 1.skb etc if there is a name clash], then the existing xxx.skp file gets renamed xxx.skb and the model is then saved as xxx.skp, finally the unneeded 0.skb file is deleted...
                This all happens in the blink of an eye.
                Something somewhere is preventing the renaming [or deletion?] of the 0.skb ?
                Is there a 0.skb in that folder ?
                • john2J
                  john2
                  Did this, but no success. I am the only user of my laptop, and using it as administrator. I did check the box next to the specified option.
                  Sketchup.exe is on "C:\Program Files\SketchUpfresh\SketchUp 2015\SketchUp.exe"
                  Which folder are you asking? This error pops up everytime I work on Sketchup 2015.
                  P.S. When I was reading your answer, I got reminded of Eminem. He speaks so fast. It is amazing to hear him at first but takes time to make sense out of what he is saying. Your answer is really complex to grasp. Hats off to your indepth knowledge sir.
                    Do you get any 0.skb files left lying around ?
                    Do proper xxx.skb files get made ?
                    Have you tried a support email to Trimble / SketchUp team ?
                    This error is know but not so general...
                    Usually if you have the SKP on a memory-stick etc...
                    • john2J
                      john2
                      no
                      Yes
                      No
                      I fail to understand what is causing this. And I am not running sketchup on network. But I am facing a problem. I have to enable my wi-fi everytime to use Sketchup 2015 in order to bypass licensing error problem. I just enable my wifi adaptor, and not connect to anywhere. Is that causing this problem?
                      I have noticed, Su guys have made a useless "enable your laptop's wifi adaptor" so that sketchup starts easily. Else, it won't start.
                      • KrisidiousK
                        Krisidious
                        Just got one of these with 2015... no autosaves, 10 skb's none of any use. lost hours of work. HATE!
                        By: Kristoff Rand
                          slbaumgartner
                          According to the reference below, this exception means some part of the file path is not valid. That suggests the issue is not with permissions but with the path that SketchUp has constructed to access it.
                          https://msdn.microsoft.com/en-us/library/as5cs056.aspx
                            slbaumgartner
                            The new licensing scheme employed in SU 2015 uses your network adapter's hardware address to identify the computer. This information is not available when the network adapter is disabled, so SU's license check fails.
                            Do you momentarily turn on WiFi so SU will start and then turn it off again? I wonder if that could induce the invalid path error (don't know, just guessing...)?
                            • KrisidiousK
                              Krisidious
                              I'm not on wifi and have not turned off my network card. The error came again after a few more hours work and after changing to administrator use only.
                              By: Kristoff Rand
                              • ely862meE
                                ely862me
                                If you have the SUSOLID extension, try to remove it and see if the problem occurs that bad again.
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • KrisidiousK
                                  Krisidious
                                  I have Pro... So no need for Solid tools.
                                  By: Kristoff Rand
                                  • ely862meE
                                    ely862me
                                    It was pretty bad for me until I removed it, and now it happened just for once or twice. When it happens I try to Save as and then Save again. Sometimes it's related with the fix your model thing and the autosave.
                                    • KrisidiousK
                                      Krisidious
                                      Yeah when the error happens I click ok and it makes a backup file with every click of ok and the error never goes away... While I'm working I have the folder open in another window, I can see the autosave file. When the error happens the autosave file disappears. i do have check for errors and fix automatically checked. I wonder if whatever issue SUSolids has, if another plugin has it as well?
                                      By: Kristoff Rand
                                      • ely862meE
                                        ely862me
                                        It might be possible to be another plugin. I had to find it the hard way: I removed groups of 3 or 4 helped by Scf Plugin manager until the error didn't occurred anymore. Then tested those last 3 and there it was.
                                        The idea is to make the error repeatable. In my case, I set the Autosave to 1 minute and I was playing with move tool with the edges from a subdivided mesh. It worked every time. Exactly when the Autosave was kicking if I played with an edge the error occurred.
                                        • H
                                          hahiru
                                          You should check this 123
                                          I have setup windows and sketchup2015 overwrite the old.So my profile cause this problem.
                                          Some one said this program need microsoft.NET Framework 4.0,try install it.
                                          • KrisidiousK
                                            Krisidious
                                            still losing time on this...
                                            moved file to desktop and set reset autosave and backup. (so it would be on main harddrive)
                                            made sure program ran as admin. no help.
                                            seems to be when I move geometry manually...
                                            I think it's a plugin doing it. I'm getting it every 20 minutes or so. I lose everything back to open. autosave is deleted as error happens and backups start being made with every click of the ok button. the backups are of the last open. I saved myself last round by making save as copies.
                                            By: Kristoff Rand
