    [Plugin] CleanUp
    974 Posts 217 Posters 861.3k Views 217 Watching
      mac1
      Link 2 http://www.netfabb.com/news.php?nid=16
      • Z Offline
        zhenning
        Found the cause of it. Actually its from the stl 😞 I have used netfabb to try to fix it. So, the CFace errors are those extra surfaces added from netfabb to make the model water tight. Then only i imported into sketchup and try to clean it. I managed to solve it by importing the stl directly, clean using cleanup, redraw uneven and erroneous faces. No problem after that. Thanks for the replies mac1
          @lersince1991 said:
          Is Cleanup working in SKU 2015? Doesn't seem to be appearing in the extensions tab at all?
          Did you also install the latest Lib for thomthom's tools ?
          He updated everything to suit v2015 a few weeks ago...
            Lersince1991
            Edit: Sorry it is working! (I thought I had restarted ketchup but I hadn't)
              Lersince1991
              Edited:
              Sorry for alerting you!
              I'm now using the sketchucation extension manager which is a god send for keeping everything up to date and installing quickly!
                TRIPOD
                I use SU 2015 x64 Portable. First starting SU was correct with plugins. Next start SU appear errors loading cleanup. TT Lib (latest version) had already installed with extension manager but SU says that it not install. Screenshot below. What is it? Why CleanUp is not loading.
                http://i67.fastpic.ru/big/2014/1125/98/191fa7fbdbc9dd68ea1d99dae96a8c98.jpg
                  Jim
                  What is "Portable" SketchUp? Where did you get it? Whatever it is, it is not a supported installation.
                    TRIPOD
                    It is the same as "usually" SketchUp is, but does not require standart installation. It very easy if you are often re-install windows OS.
                    It gave me my friend.
                    Why? The way of file system is the same as SketchUp standard installation ones. Other plugins successfully loading into portable version.
                      kyleboyd
                      Thom Thom et. all,
                      I recently got a new computer (Mac running 10.9) and Sketchup 2015 and I am experiencing some odd issues. When I click Clean and run through the dialog box, many coplanar faces are not removed). When I then just click on the Merge Faces button, they are picked up. It seems to be fairly erratic though.
                      Your help would be greatly appreciated, as CleanUp has been extremely useful over the years and is one of my most used plug-ins (and a large tool in my workflow). Thanks so much for all your awesome work!
                        Do you have a sample model to reproduce this?
                          bracisig
                          hey mate i added the EX but i cant find it in my sketchup dont know what to do ?
                            Assuming you mean EXtension, how did you 'add it'.
                            Did you install it from the RBZ archive ?
                            Did you also install the 'TT_Lib' RBZ required by thomthom's tools ?
                            Both available in the PluhginStore...
                            http://sketchucation.com/pluginstore?pln=TT_Lib
                            http://sketchucation.com/pluginstore?pln=tt_cleanup
                            Did you restart SketchUp ?
                            Did you read the tool's instructions ?
                            http://sketchucation.com/forums/viewtopic.php?p=193587#p193587
                            Is its Extension activated in the relevant section of the 'Preferences' dialog ?
                            Did you look under the 'Plugins' menu submenu for its items [remember that this is now renamed 'Extensions' in v2015 !]
                              kyleboyd
                              Fortunately for me, unfortunately for debugging, I can't seem to reproduce my previous issues.
                              In trying, I triple checked my cleaning settings, so perhaps I was just boneheaded and it was all user error. (I thought I went through and checked-unchecked the different settings, but maybe not).
                              Anyhow, thanks for the response, if it happens again, I will be sure to attach the offending sample of model. Thanks again for all your awesome work!
                                Why this is not cleaning! 😮
                                Works by hand line by line!
                                noclean.skp
                                • CadFatherC Offline
                                  CadFather
                                  because they belong to faces inside - it always worked that way
                                    Thanks! 😎
                                    So that works after use the Remove inner faces by Wiiki! 👍
                                      CadFather
                                      yes, or some good solidsolvers..
                                        AcesHigh
                                        It seems it can´t UN-SMOOTH the models?
                                        I have this model with a ridiculous amount of groups and subgroups. And it's all softened, although it should not be softned at all.
                                        It´s impossible to unsoften by hand because of the amount of groups, and I also don´t want to ungroup them all (because I might have to move the groups around)
                                        But setting the SOFTEN to 0 degrees does not unsoften the groups and subgroups, unlike the Soften Edges Panel...
                                        • pbacotP Offline
                                          That would be nice. I notice a group can be unsoftened /softened but not a nested group (without first opening the parent group). That's with the Soften/Smooth dialog.
                                            Use with care !
                                            Copy+Paste into the Ruby Console + <enter>.
                                            m=Sketchup.active_model; m.start_operation("Un...",true); es=m.entities.grep(Sketchup;;Edge); m.definitions.each{|d|next if d.image?; es<<d.entities.grep(Sketchup;;Edge)}; es.flatten.each{|e|e.soft=false;e.smooth=false}; m.commit_operation
                                            You can also do e.hidden=false too...
                                            To process a selection...
                                            m=Sketchup.active_model; s=m.selection; m.start_operation("Un...",true); es=s.grep(Sketchup;;Edge); s.grep(Sketchup;;Group).each{|g|es<<g.entities.grep(Sketchup;;Edge)};; s.grep(Sketchup;;ComponentInstance).each{|i|es<<i.definition.entities.grep(Sketchup;;Edge)}; es.flatten.each{|e|e.soft=false;e.smooth=false}; m.commit_operation
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 48
                                            • 49
                                            • 13 / 49
