    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Do you have a sample model to reproduce this?
      • B
        bracisig
        hey mate i added the EX but i cant find it in my sketchup dont know what to do ?
          Assuming you mean EXtension, how did you 'add it'.
          Did you install it from the RBZ archive ?
          Did you also install the 'TT_Lib' RBZ required by thomthom's tools ?
          Both available in the PluhginStore...
          http://sketchucation.com/pluginstore?pln=TT_Lib
          http://sketchucation.com/pluginstore?pln=tt_cleanup
          Did you restart SketchUp ?
          Did you read the tool's instructions ?
          http://sketchucation.com/forums/viewtopic.php?p=193587#p193587
          Is its Extension activated in the relevant section of the 'Preferences' dialog ?
          Did you look under the 'Plugins' menu submenu for its items [remember that this is now renamed 'Extensions' in v2015 !]
          • K
            kyleboyd
            Fortunately for me, unfortunately for debugging, I can't seem to reproduce my previous issues.
            In trying, I triple checked my cleaning settings, so perhaps I was just boneheaded and it was all user error. (I thought I went through and checked-unchecked the different settings, but maybe not).
            Anyhow, thanks for the response, if it happens again, I will be sure to attach the offending sample of model. Thanks again for all your awesome work!
              Why this is not cleaning! 😮
              Works by hand line by line!
              noclean.skp
              • CadFatherC
                CadFather
                because they belong to faces inside - it always worked that way
                  Thanks! 😎
                  So that works after use the Remove inner faces by Wiiki! 👍
                  • CadFatherC
                    CadFather
                    yes, or some good solidsolvers..
                      AcesHigh
                      It seems it can´t UN-SMOOTH the models?
                      I have this model with a ridiculous amount of groups and subgroups. And it's all softened, although it should not be softned at all.
                      It´s impossible to unsoften by hand because of the amount of groups, and I also don´t want to ungroup them all (because I might have to move the groups around)
                      But setting the SOFTEN to 0 degrees does not unsoften the groups and subgroups, unlike the Soften Edges Panel...
                      • pbacotP
                        That would be nice. I notice a group can be unsoftened /softened but not a nested group (without first opening the parent group). That's with the Soften/Smooth dialog.
                          Use with care !
                          Copy+Paste into the Ruby Console + <enter>.
                          m=Sketchup.active_model; m.start_operation("Un...",true); es=m.entities.grep(Sketchup;;Edge); m.definitions.each{|d|next if d.image?; es<<d.entities.grep(Sketchup;;Edge)}; es.flatten.each{|e|e.soft=false;e.smooth=false}; m.commit_operation
                          You can also do e.hidden=false too...
                          To process a selection...
                          m=Sketchup.active_model; s=m.selection; m.start_operation("Un...",true); es=s.grep(Sketchup;;Edge); s.grep(Sketchup;;Group).each{|g|es<<g.entities.grep(Sketchup;;Edge)};; s.grep(Sketchup;;ComponentInstance).each{|i|es<<i.definition.entities.grep(Sketchup;;Edge)}; es.flatten.each{|e|e.soft=false;e.smooth=false}; m.commit_operation
                            amalthee
                            Thanks a million Thomthom, though i was going to throw my computer away, downloaded CleanUp its magic.
                            Scenes that took minutes to open now not even time to say "thank you Thomthom..."and the scene is open.
                            Made my day or actually my late night !
                            • DDKD
                              DDK
                              wow thank you so much for this, was told I would have to optimize with a different program and learn that... this saves me so much time , I love it...need it for my objects in game engines... I've only had one issue where I lost a part of my project but I fixed it and is all good.. you do great work, you are awesome!!! ☀
                                MistahGrizzly
                                for me is not working 😞 is only deleting max 15 and when i click to show hidden geometry is not showing nothing 😞
                                • dereiD
                                  derei
                                  After the SUbD rising and other quad-based modeling helpers in SketchUp, maybe some fixes to the CleanUp plugin would be in order. And frankly, I would be very happy if we would have some fixes (i may even send you a cookie 💚 )
                                  So, what I'm thinking:
                                  1.option to cleanup with preserving the quads (there are still plenty of faces to merge and messy geometry to clean) - as now it will clean absolutely everything.
                                  2.add the possibility to save presets. There are already some presets in the menu, but many times special combinations of settings are required. Would be awesome to save those as presets for quick use (and even adding kb shortcuts to them, if is not too much to ask 😄)
                                  Thank you very much.
                                  DESIGNER AND ARTIST DEREI.UK
                                    Good suggestions. I filed it in the issue tracker: https://bitbucket.org/thomthom/cleanup/issues/10/preserve-quads
                                    • K
                                      KDhyne
                                      Hello! Your extension is very useful!
                                      I'd like to know if there is a way to automate this plugin via ruby script? I need to import a 3ds file, run this extension, save as .skp, and repeat about 1500 times 😄
                                      Is this possible? Thank you!
                                        sasasaps
                                        Great plug-in! Thanks a lot TT.
                                        Also here for a question, in case anybody got to it already: What would be the recommended settings of the CleanUp plug-in so it doesn't kill the proxy materials??
                                        In my experience it has taken down the "linked" materials used in proxies, someone else had the same trouble?
                                          sasasaps
                                          Sorry, I forgot to explain that I use proxies in Vray 2.0 (in SKP2016).
                                          Thanks,
                                            shannonnovus
                                            For the most part I love this plugin, but I'm having an issue with the "smooth by angle" feature. I'm running SketchUp 2015, with CleanUp3 (3.3.1).
                                            It seems like the CleanUp plugin is "seeing" the lines that it could fix, and claims to be doing so, but isn't actually fixing anything.
                                            Steps to reproduce:
                                            1. Select the geometry (building outlines that have several line segments that are almost but not quite parallel)
                                            2. Run CleanUp3, with Smooth Edges by Angle set to 5.0.
                                            3. It runs, and says "Edges reduced: 1500", and the validity check is showing no problems.
                                            4. BUT, then I still have the same number of edges in my model (8417) that I had at the beginning. Looking at the outlines in detail, the offending lines are still there.
                                            I've tried both with faces included and faces deleted.
                                            Any ideas?
                                            Thanks,
                                            Shannon
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 45 / 49
