    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.4k Views 155 Watching
    • JQLJ Offline
      JQL
      @fredo6 said:
      It is only when you want to set the face with respect to a reference point in the model that you need to interactively drag the faces.
      This is probably why I'm the one bringing up the subject. This the process I use 90% of the time with sketchup native tools and JPP. The fact is that the functionallity you offer is flawless. There is nothing to point on that regard, so I actually feel ashamed of myself by seeming that I'm somehow bragging about UI.
      The thing is that the way I always worked on Architecture is all about references to other geometry - alignements, porportions, visual axis, middle points, endpoints,... - as that adds geometric rule to space. I almos never think of space as an addition/subtraction of numbers. The thing that made me fall in love with Sketchup is no other than the inference system wich is an almost perfect system for the way I study space. I bet even if inference.
      I feel that if there was a way to toggle selection on/off that free movement could break temporarily and then continue freely.
      But don't mind about this questions of mine though, The functionality is there and I've been using your tools long enough already to know what to expect. An though they're feeling different from SU they do work! They do facilitate our life tremendously! And that is the purpose after all!
      Thanks again,
      João
      www.casca.pt
      Visit us on facebook!
        schnydix
        Thank you very much Fredo
        Happy and good new year to you
        and a little German german quick card
        Esense 3d
          schnydix
          Quick card German
            rv1974
            It appears RoundPP refuses to deal with obtuse angle geometry.
            round.skp
            Ruby Error - Round Push Pull - 14-Jan-15 10_10_15.txt
            • ely862meE Offline
              ely862me
              Hi guys.
              Do you have any idea why JPP is not working ?(for a friend)
              The other tools from you (Fredo) , are working but this one doesn't .
              I have the latest Libfredo, I use Sketchup 2015 64 bit . I have also tested it with no other plugins in the Plugins folder. In vain.
              The plugin seems installed, all the incons are alright . When I select one of its tools and try to run it on a face it just highlights a polygon or a triangle and then nothing. Somehow it doesn's select the surface as it should !
              The Face selection is set to Surface, but it does not select the surface, it is only highlighting a polygon that is under the surface .
              I ran out of ideas.
              EDITED
              I have read back and found out about the DC being disabled. I have checked the behavior on my own Sketchup with them turned off and this seems to be it . Lets see if it works for my friend. I am not sure if it is written in the documentation about this, but could you post it at the conflicts ? Thank you !
              Elisei (sketchupper)
              Come and See EliseiDesign
              • fredo6F Offline
                What is "DC"? Is it Dynamic components?
                I don't know why there would be a conflict.
                Thanks for feedback
                • TIGT Online
                  DC rubies add several additional methods into the base Sketchup and related Classes.
                  If you have used any of these methods in your code, then IF those DC rubies have not loaded you will get errors.
                  These include:
                  ` Geom::Transformation.rotx
                  Geom::Transformation.roty
                  Geom::Transformation.rotz
                  Geom::Transformation.xscale
                  Geom::Transformation.yscale
                  Geom::Transformation.zscale
                  UI::WebDialog.last_width
                  UI::WebDialog.last_width=
                  UI::WebDialog.last_height
                  UI::WebDialog.last_height=
                  Sketchup::ComponentInstance.copy
                  Sketchup::ComponentInstance.description
                  Sketchup::Drawingelement.local_transformation
                  Sketchup::Drawingelement.scaled_size
                  Sketchup::Drawingelement.unscaled_size
                  Sketchup::Drawingelement.set_last_size
                  Sketchup::Drawingelement.last_scaling_factors
                  Model.typename
                  Model.entityID
                  Model.delete_attribute
                  Model.layer`
                  There are other " DC..." classes too, but I'd expect you won't have used those !
                  • fredo6F Offline
                    TIG,
                    Thanks for clarification.
                    I think I may use model.entityID. Actually I thought it was a native method (which would make sense).
                    I have to check my code to track these instances.
                    • TIGT Online
                      Model.entityID is a weird one it always returns "Model", so unsure why it's used... 😲
                      You can trap it with something like:
                      if defined?(Sketchup.active_model.entityID)
                        mid = Sketchup.active_model.entityID
                      else
                        mid = "Model"
                      BUT then mid = "Model" is always right - so why not use the simplest fix !
                      • JQLJ Offline
                        JQL
                        @Tig and Fredo
                        You have the notion you look like aliens with superpowers to the rest of us mortals down here...don't you?
                        www.casca.pt
                        • fredo6F Offline
                          @TIG:
                          Now I know this is not a native method, I will be careful. In fact this method is convenient because you can use entityID on a parent whether Group, ComponentInstance or active model.
                            j03150315
                            This tool is amazing! However, I encountered some error with the follow push/pull.
                            When I tried to use follow push/pull, the following error occurred:
                            undefined method `angle_between' for nil:NilClass
                            Ruby File Line Method
                            JointPushPullAlgo.rb 1339 vertex_average_factor
                            JointPushPullAlgo.rb 1089 follow_compute_direction
                            JointPushPullAlgo.rb 1056 block in block_prepare_vertices_F
                            JointPushPullAlgo.rb 1056 each
                            JointPushPullAlgo.rb 1056 block_prepare_vertices_F
                            JointPushPullAlgo.rb 890 block in block_prepare_vertices_all
                            JointPushPullAlgo.rb 890 each
                            JointPushPullAlgo.rb 890 block_prepare_vertices_all
                            JointPushPullAlgo.rb 500 algo_prepare_calculation_exec
                            JointPushPullAlgo.rb 477 algo_prepare_calculation
                            JointPushPullTool.rb 692 dragging_start
                            JointPushPullTool.rb 1190 onMouseMove
                            22-Feb-15 14:56:56
                            Does anyone know why?? I followed exactly what the video showed, push/pull the top of a cone shaped object.
                            Would love some help! Thank you!!
                            • fredo6F Offline
                              It may depend on your model.
                              So the best is to post it or PM it to me.
                              • cottyC Offline
                                cotty
                                Hi Fredo, I've experienced this round push pull error for this simple geometry...
                                rpperror.txt
                                my SketchUp gallery
                                • erkanE Offline
                                  erkan
                                  I'm getting the same error in a specific geometry, any plans of implementing the safer generation method?
                                  @fredo6 said:
                                  @stamatispsarras said:
                                  I am also getting this error in a complex model.
                                  Any ideas what I should avoid when modeling, so it wont happen again?
                                  Unfortunately, these kind of errors may happen with complex models where the generated offset surface contains overlaps. This is due to the fast method of generation. I have the plan to have a default safe generation method to takeover when there are such errors. Should go in a next release.
                                    littleche
                                    HI fredo
                                    this face have problem with joint pull push plugin but easily work with puss pull tool in sketchup !
                                    It was very surprising for me! Since this face is very Simple !
                                    I uploud this file . I thank you for the review explained above.
                                    P&P.skp
                                      It's poorly drawn at the end near the red axis. If you did a better job of drawing it, Joint Push/Pull wouldn't fail.
                                        littleche
                                        HI Dave
                                        I had not checked the lines For this reason,The main tool push&pull was not any problem.
                                        I did not know that fredo plugin is more sensitive.
                                        thank you ...
                                          I don't know that it's more sensitive but since you have that little triangular loop with no face in it, i'd guess that causes problems. Try this: Scale the entire geometry up by a factor of 1000. make a face on that triangle by tracing one edge of it with the Line tool. Then trying running Joint Push/Pull on the result.
                                          • dereiD Offline
                                            derei
                                            Hy, I am a bit confused on how to PROPERLY use this plugin... Ok, I understood that I should keep the mouse button pressed while pulling the face, because click will only select/deselect (which is a bit annoying, honestly). But there is a funny behavior AFTER I do the push pull... sometimes (couldn't figure out in which conditions), when I press ENTER it actually CANCEL my pushpull.
                                            Until now, every successful pushpull i did was out of luck... I have no idea how I confirmed the operation, because apparently I do the same thing like when it's canceled.
                                            In my opinion it should do better use of ESC and ENTER keys (first to cancel, second to confirm). Also, selection of faces would be best to be key-assisted, as in regular SU behavior.
                                            Is very confusing when plugins ask for different commands to do similar SU actions... is like two different programs. Select should be performed the same in native Su and under plugins (same key+mouse combinations), other operations should be similar.
                                            Wish you best.
                                            DESIGNER AND ARTIST DEREI.UK
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
