    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 37.3k Views 19 Watching
      [sw:2dy9isx1]xrJ8KafT4A25Hz5[/sw:2dy9isx1]
        [sw:35hm4m43]ABLK1YyGWMOlGuE[/sw:35hm4m43]
          We added a turntable feature that you can set to be on or off. So that on first load the models spin...
          [sw:aeg98d49]ySJWrsTqm4YCpXM[/sw:aeg98d49]
          • JQLJ Offline
            JQL
            OMG I have to have time... argh...
            www.casca.pt
            Visit us on facebook!
              no rush for your tests. still a long way to go.... 😲
              tip: the viewer allows you to swap between orbit[o], pan[m] and zoom[z] while viewing by hitting the relevant key.
                [sw:1mfqgnep]msLKICAxlFhEOkb[/sw:1mfqgnep]
                  Can the initial 'turntable' effect be switched back on after you click the screen to orbit it if 'off'.
                  Either by key-press or another button ?
                    No, not currently.
                    You think the reset view button should also return it to turntable if enabled?
                      @rich o brien said:
                      No, not currently.
                      I ought - IMO...
                        [sw:3ksobeus]CRuId5tt5BDbkCL[/sw:3ksobeus]
                          disregard email.....
                          what's opinion Dave?
                            It's pretty slick. I found it easy enough to navigate through the edit options and I can see that it would make showing SketchUp models much more effective.
                            Is there any way to maintain the colors for the faces and backgrounds as in the preview?
                              driven
                              dave is yours a texture or a color?
                                Can you wing me the model?
                                hTere's lots of things we need to document but I'd love to see where this is causing an issue?
                                  @john
                                  what's your opinion on this thing?
                                    It's just the default color for the style.
                                    Check yer mail.
                                      Yes, that is the issue.
                                      We have one default color. White.
                                      You'd need to color the raw geometry to get that same result
                                        OK. I'll try one with some texture in a little while.
                                          [sw:23renr2t]AKWJAg6XMIoAUqg[/sw:23renr2t]
                                            [sw:1j6gu1zn]bQhrjDGhEd2X2xV[/sw:1j6gu1zn]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
