    How's your Vray for SU 2015 Experience?!
    renderpluginsextensions
    16 Posts 8 Posters 3.4k Views 8 Watching
    • saberopusS Offline
      saberopus
      What was the issue w/ 2pt Projection before? I'd definitely had my share of wrangling with it, but I want to be clear on what was the source of that, and how it's now fixed! I too ended up using lens correction filters or tilt-shift guessing when the FOV/aspect ratio/projection type got too confusing...
      • dkendigD Offline
        dkendig
        lack of exposed functionality in the Ruby API for SketchUp. V-Ray For SketchUp 2.0 SR3 supports panning in 2 point perspective views in SketchUp 2015 only. 2013 and 2014 versions of SketchUp do not have the necessary information available to our plugin to support panning in 2 point perspective.
        Devin Kendig
        Developer
        • V Offline
          valerostudio
          Devin, Have you guys run any benchmark tests on 2014 and 2015 using the latest SP on both to see if there are speed improvements? I think we would all be interested.
            sketchuh
            Nice!!!
            • dkendigD Offline
              dkendig
              No, we haven't benchmarked it, but we DID start the next development cycle... πŸ˜‰
              Devin Kendig
              Developer
              • F Offline
                ftellez
                has anyone had problems with shades of SU2015, when applied HDRI lighting? In this latest version of Vray, it is not properly showing me the shadows thrown SU2015.
                appreciate the help
                • V Offline
                  valerostudio
                  It depends on how you are setting up your lighting. If you use HDRI lighting, you should use the dome light. The Default Lights check box no longer makes the SU shadows show anymore. That's an old hack from 1.49
                    cmoreink
                    I have been running SU8 and Vray 1.6 for a very long time and had no issues with my renders. Couple weeks ago I found a tutorial on 2D vray proxies (high poly trees) and I made few 2D proxy trees which looked realy good but my SU and vray would freez or I would just get a bug splat. It was driving me nuts. So few days ago I upgraded to SU15 and vray2 and never looked back.
                    Once I convert my high poly proxy tree into 2D proxy it's 10 fold less in size πŸ˜„ and in this case SU is not being used when render because it goes straight from vray πŸ˜„
                    So I am very pleased with SU15 and vray2 πŸ˜„
                    cheers
                    my portfolio
                    • V Offline
                      valerostudio
                      Would love faster parsing times on large scenes. Other than that, I am a very happy customer.
                      • dkendigD Offline
                        dkendig
                        I wish they would add Environment Fog.... πŸ‘Š
                        Devin Kendig
                        Developer
                        • V Offline
                          valerostudio
                          My Wish List
                          Parsing times to rival VR4Max
                          Fur / Grass
                          VRayEdgesTex (SU would benefit from this greatly) http://help.chaosgroup.com/vray/help/150SP1/vrayedgestex_params.htm
                          VRayXtraTex Pass (for an easy AO pass)
                          V-Ray Light material
                          • jiminy-billy-bobJ Offline
                            jiminy-billy-bob
                            +1, these two are high priority on my wishlist.
                            • dkendigD Offline
                              dkendig
                              whoops, I turned this in to a feature request thread! Nooooooooooooooooooooooooooooooooo
                              Devin Kendig
                              Developer
