    Hologram
    29 Posts 3 Posters 2.4k Views 3 Watching
      My typo !
      2 missing characters...
      Try:
      IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
      If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
      • robertWanR Offline
        robertWan
        I use PSPad. I install Notepad++.
        Finished exporting vertex data.
        Running python script...
        Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
        solid_pattern.rb
          Try this:
          d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
          I misunderstood, there is no 'draw_pattern' variable !
            robertWan
            Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
            solid_pattern.rb
              I weary... try...
              d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
              So many permutations... πŸ˜’
                robertWan
                @tig said:
                I weary
                Error Loading File solid_pattern.rb
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                	puts "Data export done. Python results w...
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                if(file_loaded("solid_pattern.rb"))
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                	 menu = UI.menu("Plugins");
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                solid_pattern.rb
                  I must sleep now...
                  BUT I think this is it...
                  d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
                    robertWan
                    Nothing worked out, did it?
                    Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
                    solid_pattern.rb
                      I assume the .py and .pattern files exist ?
                      Try this instead - there was a missing \ before ' proposal':
                      d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
                      If you paste this into a Windows cmd window [including the "s] does it work ?
                      "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
                        robertWan
                        Data export done. Python results will appear as soon as they are completed
                        Error; #<NoMethodError; private method `gets' called for false;FalseClass>
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
                        http://www.screencast.com/t/lDjsrKcXTb
                          So it's working, sort of... πŸ˜•
                          d is set to the result of the system call...
                          Then if fails at:
                          while d.gets != nil puts d.gets end
                          Because ' d' is ' false' !
                          Why no add a puts d just after the system call to see what you are getting...
                          I suspect it'll NOT be complex data - just success/failure true/false ??
                          Also in the screen-cast the .py extension was not recognized as being associated with Python !
                          Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                          Also in the screen-cast the file was named Untitled.pattern**abc** ?
                          Why the extra characters ?
                          When you run the .py what do you expect ?
                          If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                          You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                            driven
                            @tig
                            on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                            you can then either harcode that path for a test or change the system call to puts to see if they match...
                            does that work on a PC?
                              robertWan
                              Also in the screen-cast the file was named Untitled.patternabc ?
                              I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                              Robert
                                So is it an error in your .file ?
                                • 2 / 2
