    Hologram
    29 Posts 3 Posters 3.2k Views 3 Watching
    • robertWanR
      robertWan
      Error Loading File solid_pattern.rb
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
      ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
      solid_pattern.rb
        My typo !
        2 missing characters...
        Try:
        IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
        If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
        • robertWanR
          robertWan
          I use PSPad. I install Notepad++.
          Finished exporting vertex data.
          Running python script...
          Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
          solid_pattern.rb
            Try this:
            d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
            I misunderstood, there is no 'draw_pattern' variable !
            • robertWanR
              robertWan
              Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
              solid_pattern.rb
                I weary... try...
                d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                So many permutations... πŸ˜’
                • robertWanR
                  robertWan
                  @tig said:
                  I weary
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                  	puts "Data export done. Python results w...
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                  if(file_loaded("solid_pattern.rb"))
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                  	 menu = UI.menu("Plugins");
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                  	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                  solid_pattern.rb
                    I must sleep now...
                    BUT I think this is it...
                    d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
                    • robertWanR
                      robertWan
                      Nothing worked out, did it?
                      Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
                      solid_pattern.rb
                        I assume the .py and .pattern files exist ?
                        Try this instead - there was a missing \ before ' proposal':
                        d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
                        If you paste this into a Windows cmd window [including the "s] does it work ?
                        "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
                        • robertWanR
                          robertWan
                          Data export done. Python results will appear as soon as they are completed
                          Error; #<NoMethodError; private method `gets' called for false;FalseClass>
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
                          (www.screencast.com)
                            So it's working, sort of... πŸ˜•
                            d is set to the result of the system call...
                            Then if fails at:
                            while d.gets != nil puts d.gets end
                            Because ' d' is ' false' !
                            Why no add a puts d just after the system call to see what you are getting...
                            I suspect it'll NOT be complex data - just success/failure true/false ??
                            Also in the screen-cast the .py extension was not recognized as being associated with Python !
                            Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                            Also in the screen-cast the file was named Untitled.pattern**abc** ?
                            Why the extra characters ?
                            When you run the .py what do you expect ?
                            If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                            You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                              driven
                              @tig
                              on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                              you can then either harcode that path for a test or change the system call to puts to see if they match...
                              does that work on a PC?
                              • robertWanR
                                robertWan
                                Also in the screen-cast the file was named Untitled.patternabc ?
                                I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                                Robert
                                  So is it an error in your .file ?
                                  • 2 / 2
