    Hologram
    29 Posts 3 Posters 2.4k Views 3 Watching
    • robertWanR Offline
      robertWan
      Finished exporting vertex data.
      Running python script...
      Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
      current plugin
        driven
        have a look at Dan's
        [Plugin] Hypocycloid Cam Profile Generator v1.0.0 http://sketchucation.com/forums/viewtopic.php?p=470834#p470834
        it was based on a python [py/dxf] script that I couldn't get to run...
        he reworked it to SU ruby, may be a simpler approach...
          I'm no expert on 'python' but isn't the cmd code more like this:
          path_to_py argument(s)
          Also have you got 'python' set up right in cmd window ?
          ftype Python26.File="C:\Python26\python.exe" "%1" %
          assoc .py=Python26.File*
          AND then run it...
          IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
          OR
          **system**('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
          OR perhaps the .py part can't be inside "" ?
          Read this about file associations... http://eli.thegreenplace.net/2010/12/14/problem-passing-arguments-to-python-scripts-on-windows/
            robertWan
            Error Loading File solid_pattern.rb
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
            ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
            solid_pattern.rb
              My typo !
              2 missing characters...
              Try:
              IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
              If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
                robertWan
                I use PSPad. I install Notepad++.
                Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
                solid_pattern.rb
                  Try this:
                  d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
                  I misunderstood, there is no 'draw_pattern' variable !
                    robertWan
                    Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                    solid_pattern.rb
                      I weary... try...
                      d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                      So many permutations... πŸ˜’
                        robertWan
                        @tig said:
                        I weary
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                        	puts "Data export done. Python results w...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                        if(file_loaded("solid_pattern.rb"))
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                        	 menu = UI.menu("Plugins");
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                        	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                        solid_pattern.rb
                          I must sleep now...
                          BUT I think this is it...
                          d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
                            robertWan
                            Nothing worked out, did it?
                            Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
                            solid_pattern.rb
                              I assume the .py and .pattern files exist ?
                              Try this instead - there was a missing \ before ' proposal':
                              d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
                              If you paste this into a Windows cmd window [including the "s] does it work ?
                              "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
                                robertWan
                                Data export done. Python results will appear as soon as they are completed
                                Error; #<NoMethodError; private method `gets' called for false;FalseClass>
                                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
                                http://www.screencast.com/t/lDjsrKcXTb
                                  So it's working, sort of... πŸ˜•
                                  d is set to the result of the system call...
                                  Then if fails at:
                                  while d.gets != nil puts d.gets end
                                  Because ' d' is ' false' !
                                  Why no add a puts d just after the system call to see what you are getting...
                                  I suspect it'll NOT be complex data - just success/failure true/false ??
                                  Also in the screen-cast the .py extension was not recognized as being associated with Python !
                                  Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                                  Also in the screen-cast the file was named Untitled.pattern**abc** ?
                                  Why the extra characters ?
                                  When you run the .py what do you expect ?
                                  If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                                  You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                                    driven
                                    @tig
                                    on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                                    you can then either harcode that path for a test or change the system call to puts to see if they match...
                                    does that work on a PC?
                                      robertWan
                                      Also in the screen-cast the file was named Untitled.patternabc ?
                                      I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                                      Robert
                                        So is it an error in your .file ?
                                        • 2 / 2
