    Twisted Dovetail
    35 Posts 11 Posters 5.2k Views 11 Watching
    • tuna1957T Offline
      tuna1957
      if memory strikes right , the late Tage Frid shows how to layout , cut and fit this joint in his book " Tage Frid Teaches Woodworking" . Hope to give it a try just for grins one of these days.
        I had the pleasure of watching Tage Frid handcut dovetails once years ago. He came to speak to a college woodworking class I was in. We watched as he laid out and quickly cut a set of dovetails. When he was finished, he put the joint together and then he looked around the room. Not at us but at the walls of the shop. The professor asked him what he was looking for and he replied, "A dovetail hammer." No one in the class including the professor ever heard of a dovetail hammer before. Frid broke into a smile and walked over to the hand tool wall and grabbed a claw hammer. He walked back over to where he'd been working and gave one of the pins a few whacks to spread out the fibers and fill a small gap he'd created when cutting the joint. Then he held up the hammer with a grin and said, "This is a dovetail hammer." πŸ˜†
        • robertWanR Offline
          robertWan
          Ipossible?
          Robert
          jaskolczy ogon.skp
            They slide in/out on the diagonal ?
              robertWan
              No. πŸ˜„
              Radial.
              .skp is up.
              Robert
              • jeff hammondJ Offline
                @robertwan said:
                Ipossible?
                ha. wow.. at first i was thinking "ok, there's no way that's going together.. especially getting all 4 pieces to do it"
                but, after checking your .skp, it appears like it will actually work.
                πŸ‘
                  slbaumgartner
                  It could be a challenge to create a jig for cutting that one accurately!
                    robertWan
                    I made on the CNC.
                    Robert
                    • cottyC Offline
                      cotty
                      Nice and clever!
                      my SketchUp gallery
                        robertWan
                        I tried on the CNC, but it can not be done. The test is .skp file above.
                        http://scontent-b.cdninstagram.com/hphotos-xaf1/t51.2885-15/e15/10693512_322800104559875_387077836_n.jpg
                        Robert
                          do you mean it can't be done with CNC or it can't be done at all?
                            robertWan
                            Chisel can be done.
                            I'll try to draw it later, it looked as if made on CNC.
                            Robert
                              robertWan
                              It's not bad, I thought there would be more problems.
                              That's what it looks like when made on CNC, there are few problems.
                              1-6 can be corrected with a chisel. 7 and 8 is an empty space, but invisible.
                              There's only 7x7x7 [mm] to cut out with a chisel.
                              Robert
                              jaskolczy ogon CNC.skp
                                are you going to cut one?
                                  robertWan
                                  Minimum of two pieces.
                                  Robert
                                  • 2 / 2
