    Problems with a half-torus
    156 Posts 11 Posters 29.7k Views 11 Watching
    • TeigT
      Teig
      @tig said:
      Use a combination of Xray mode and SectionPlanes to 'look inside' the object.
      You can select a face and press <delete>, or [where it's not 'destructive'] use the Erase tool to delete unwanted edges and related faces.
      To reiterate what was said several times before...
      A 'solid' object cannot contain anything but geometry [guides are acceptable BUT best avoided]
      That geometry consists of edges and faces.
      Every edge must have exactly two faces associated with it.
      No fewer, no more.
      So that means...
      No faceless edges.
      No edges with only one face - e.g. around a 'hole' or forming the edge of a 'flap' or 'shelf'.
      No edges with more that two faces - e.g. internal 'partitions' where some edges have three or more faces, or two otherwise solid-looking forms [like two cubes] sharing a 'common edge' - so that some edges have four faces !
      No overlaid faces - this is rare, but sometimes two faces 'that ought to auto-merge into one' continue to exists and so their edges then have extra faces too !
      In your case the SolidSolver messages suggests multiple 'internal partitions'.
      If these are too convoluted, then deleting one might then compromise what's left and so result in no solution...
      In that case only a manual fix suffices...
      My algorithms [aka 'brain'] isnot up to solving some of the complex balls-ups which you users can contrive !!
      πŸ˜‰
      I'm sorry if it doesn't sink in quickly... Your explanation there is useful - a bit more 'plain English' that I can understand πŸ˜„
      • TeigT
        Teig
        @d12dozr said:
        Teig, two of the holes on the bottom are causing the problem, as pointed out in the following image.
        [attachment=1:1wvyo62i]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:1wvyo62i]
        If you pull those 2 faces down a fraction of a mm and clean up the resulting internal faces, the model becomes solid.
        Thank you very much once again d12dozr. πŸ‘ I pulled those faces down by 0.03mm, grouped it again, it reported back as a group sigh . I exploded it again, pushed the faces 'up', it wanted to snap to .04mm so I left it, did the other one. Drumroll It reported back as solid!!! 😍
        @d12dozr said:
        @teig said:
        So I don't need the supporting material if I go to a commercial printer? I'm starting to think that it might be the better option.
        For a part with this complexity, you'd be better off. Something like Shapeways Strong and Flexible (S&F) plastic should work well. BTW, since this is a part for a carburetor, how hot would the piece get? Shapeways S&F melting point is ~180C.
        ABS from a desktop printer melts at ~200C.
        You pre-empted my next question πŸ˜„
        Either of those two plastics should be fine then, I can't imagine it getting over 180C even in traffic on a summer's day? The venturi will constantly pulling cool air over it as well.
        [attachment=0:1wvyo62i]<!-- ia0 -->Sub Stack11v6solidFinal.skp<!-- ia0 -->[/attachment:1wvyo62i]
          d12dozr
          Great! It's a learning process, and you're getting a crash course πŸ˜„
          http://goo.gl/f7ooYh
          • TeigT
            Teig
            You're not wrong there!!! πŸ˜›
            Just trying to get a quote now, had one for Β£43 which I thought a bit harsh so I'm trying some other companies now.
            I can't see the plastic you recommended so I've just gone for 'standard' ABS.
            • TeigT
              Teig
              Airbox Bellmouth2.skpI think I've cracked it!
              I've drawn another one tonight, a mere hour to draw:
              http://i1006.photobucket.com/albums/af190/Nursi555/A Mini/AirboxBellmouth2_zpsc2ec470a.jpg
              πŸ˜„
              • cottyC
                cotty
                Looks good!
                You can use the soften edges window to smooth out some of the lines (no difference for printing, only looks nicer πŸ˜‰ ).
                my SketchUp gallery
                  d12dozr
                  That's about the best price for a part of this size on a commercial printer. Cost on a desktop printer is about 1/10 that price, which is the biggest advantage of using one of them. With your newer design, you actually have a little more room for cleaning out support material.
                  @cotty said:
                  Looks good!
                  +1 πŸ‘
                  On the flip side, this is closer to what it'll look like after printing:
                  See the faceting on the curved bell surface? If you want that to print smooth, you'll need to increase the # of segments on the curves (Chapter 4 of the book). If the faceting is no problem, then you're good to go. πŸ˜„
                  • TeigT
                    Teig
                    The faceting is a problem, I would need to polish all those off to a mirror surface, for the bellmouth itself at least, the mounting flange etc doesn't matter.
                    I've been told that some desktop printers will automatically build in support material so it looks like it's going back to that again πŸ˜„
                    • TeigT
                      Teig
                      Can I increase the number of circle segments now? Or will I need to redraw it from scratch again?
                        d12dozr
                        Definitely redo the model with higher resolution curves then - no reason to polish by hand more than necessary! Once you've push/pulled or follow-me'd, it has to be redrawn, unless you saved the intermediate steps like I show in the book.
                        Yep, pretty much any printer will automatically add the support material - that's whats shown in the T-rex model I posted before. Cleaning the support material is the tricky part, especially in an enclosed area like your model. Sorry if I didn't make that clear earlier.
                        Here's a video showing how the support material is cleaned out. On this particular model, it went very well.
                        • TeigT
                          Teig
                          Thanks again d12dozr, that is a real help. I thought I had to put in all those supports and had been scrabbling around the t'interweb trying to find where and what spacing you put them in at. πŸ˜•
                          Back to the drawing board for v14 it is then.... πŸ˜„
                          • TeigT
                            Teig
                            I am getting the hang of it! V19 was drawn in 45 minutes last night, solid first time πŸ˜„
                            Bellmouth50RRadialSlotSOLID.skp
                              Cool but you have forgotten the V6! πŸ’š
                              • TeigT
                                Teig
                                You need to get up to speed Pilou πŸ˜„
                                  d12dozr
                                  New design is SEXY!
                                  One question...is this area under much stress? If so it may be a good idea to add some meat so it doesn't break easily.
                                  • TeigT
                                    Teig
                                    Not much stress, it only has to hold the weight of itself up and the one my mate test-printed weighed in at 50g so not very much at all, nothing that a suitable washer won't support (I hope πŸ˜„). This version will weigh in a fair bit lighter too.
                                    • TeigT
                                      Teig
                                      Well since you pointed that out I've had the compulsion to fiddle πŸ˜„ But... I can't work out a way to add a bit of 'meat' to that area? Short of starting from scratch that is. To strengthen that area I've tried making an arc on the base and Push/Pulling but it leaves gaps.
                                      v6 added for Pilou πŸ˜›
                                      Bellmouth50RRadialSlot2v6.skp
                                        d12dozr
                                        I would try making the shape you want to add as a separate solid group, then use Outer Shell to combine them.
                                        • TeigT
                                          Teig
                                          More study required...
                                          • TeigT
                                            Teig
                                            I'm back again πŸ˜„
                                            I'm on version 34 (or so) now. After a lot of research reading mind-boggling papers on how to optimise the design I have changed my design slightly.
                                            I'm having problems with the Follow Me tool again, it won't do this:
                                            Is there any way I can make it work? I've tried it a few ways on different radius circles to follow, but it will not have it. I've tried it with half-circles and solid circles, this version is trying to be hollow to save weight. Anyone have any ideas?
                                            v6 for Pilou πŸ˜„: BellmouthRoundlip45Rv34.jpg
                                            BellmouthRoundlip45Rv34.skp
                                            • 4 / 8
