    Problems with a half-torus
    156 Posts 11 Posters 35.6k Views 11 Watching
    • TeigT
      Teig
      Can I increase the number of circle segments now? Or will I need to redraw it from scratch again?
        d12dozr
        Definitely redo the model with higher resolution curves then - no reason to polish by hand more than necessary! Once you've push/pulled or follow-me'd, it has to be redrawn, unless you saved the intermediate steps like I show in the book.
        Yep, pretty much any printer will automatically add the support material - that's whats shown in the T-rex model I posted before. Cleaning the support material is the tricky part, especially in an enclosed area like your model. Sorry if I didn't make that clear earlier.
        Here's a video showing how the support material is cleaned out. On this particular model, it went very well.
        http://goo.gl/f7ooYh
        • TeigT
          Teig
          Thanks again d12dozr, that is a real help. I thought I had to put in all those supports and had been scrabbling around the t'interweb trying to find where and what spacing you put them in at. πŸ˜•
          Back to the drawing board for v14 it is then.... πŸ˜„
          • TeigT
            Teig
            I am getting the hang of it! V19 was drawn in 45 minutes last night, solid first time πŸ˜„
            Bellmouth50RRadialSlotSOLID.skp
              Cool but you have forgotten the V6! πŸ’š
              • TeigT
                Teig
                You need to get up to speed Pilou πŸ˜„
                  d12dozr
                  New design is SEXY!
                  One question...is this area under much stress? If so it may be a good idea to add some meat so it doesn't break easily.
                  • TeigT
                    Teig
                    Not much stress, it only has to hold the weight of itself up and the one my mate test-printed weighed in at 50g so not very much at all, nothing that a suitable washer won't support (I hope πŸ˜„). This version will weigh in a fair bit lighter too.
                    • TeigT
                      Teig
                      Well since you pointed that out I've had the compulsion to fiddle πŸ˜„ But... I can't work out a way to add a bit of 'meat' to that area? Short of starting from scratch that is. To strengthen that area I've tried making an arc on the base and Push/Pulling but it leaves gaps.
                      v6 added for Pilou πŸ˜›
                      Bellmouth50RRadialSlot2v6.skp
                        d12dozr
                        I would try making the shape you want to add as a separate solid group, then use Outer Shell to combine them.
                        • TeigT
                          Teig
                          More study required...
                          • TeigT
                            Teig
                            I'm back again πŸ˜„
                            I'm on version 34 (or so) now. After a lot of research reading mind-boggling papers on how to optimise the design I have changed my design slightly.
                            I'm having problems with the Follow Me tool again, it won't do this:
                            Is there any way I can make it work? I've tried it a few ways on different radius circles to follow, but it will not have it. I've tried it with half-circles and solid circles, this version is trying to be hollow to save weight. Anyone have any ideas?
                            v6 for Pilou πŸ˜„: BellmouthRoundlip45Rv34.jpg
                            BellmouthRoundlip45Rv34.skp
                            • cottyC
                              cotty
                              Moved the face away from the other geometry and scaled the model up (1000x)...
                              my SketchUp gallery
                                v6 for Pilou
                                Not just for me but for all users who have not the same up version than you! πŸ˜‰
                                PS you are making an engine in 3D Printing ?
                                What will be the fuel ? And for what vehicle ?
                                • TeigT
                                  Teig
                                  [attachment=0:1vs06ddx]<!-- ia0 -->follow34.jpg<!-- ia0 -->[/attachment:1vs06ddx]
                                  That looks brilliant.
                                  Err.. How do I move a face away from the other geometry? Every time I try I get little 'strings' attached that just stretch out.
                                  And the scale tool. Sorry for sounding stupid but if I scale it by a 1000x what do I sale by to get back to my dimensions?
                                  Thanks.
                                  • TeigT
                                    Teig
                                    @pilou said:
                                    v6 for Pilou
                                    Yes, it's to go on the carburettor intake on a petrol powered 1976 Austin Mini, my daily drive. πŸ˜„
                                      d12dozr
                                      Carsten (cotty) did it exactly how I would have πŸ‘
                                      .001
                                      You can also use the Tape Measure tool to quickly and accurately scale a model.
                                      It's neat to watch your design iterations gradually improve 😎
                                      • TeigT
                                        Teig
                                        .0001
                                        If you look at p. 36 of my book, I explain how to use the Tape Measure tool and a reference line to quickly and accurately scale a model.
                                        Thanks a lot Marcus, I knew it had to be some amount of 000s πŸ˜„ It is one mighty learning curve, I'm sure a hotel would be an easier way to get started πŸ˜„
                                        I'll go look at your book now, I haven't had much time to myself recently.
                                          d12dozr
                                          Hey Teig, I messed up the first time around...it should be .001. Sorry, I edited my post, but you already caught it.
                                          Also the way to move the geometry is to draw a line separating the piece you want to follow-me, then group it for moving (or copy it and erase the original).
                                          • BoxB
                                            And while you are at it, you can make the piece a component, then scale a copy up to do your edits, then delete the large copy and the edits will have worked on the small version.
                                            • 4 / 8
