    Problems with a half-torus
    156 Posts 11 Posters 17.6k Views 11 Watching
      d12dozr
      @teig said:
      I've been trying for three hours now to put an arc under the bellmouth! πŸ˜’
      You could use JointPushPull plugin to thicken a curved surface, but starting with a new profile is much cleaner and probably faster.
      http://goo.gl/f7ooYh
      • TeigT Offline
        Teig
        I eventually got it sorted (hope), thanks to you folks. It really does look like the perfect bellmouth now - I couldn't sleep last night I was so excited πŸ˜„
        I'm at work now; I'll put the (v6) .skp up later.
          d12dozr
          Nice! 😍
            Nearly there... πŸ˜„
            I purged the model [Model Info > Statistics...]
            I erased all guides.
            I then regrouped the geometry.
            It reported as a non-solid.
            I suspected some un-faced edge[s] have been left hanging around...
            I ran SolidSolver on it and it removed some 101 Un-faced or Coplanar edges.
            Then it reported as a solid.
            Simply using CleanUp would probably have made it a solid too...
            It is now suitable for 3d printing...
            • TeigT Offline
              Teig
              I know it's not sensational or a spectacular Sketchup item but it's big to me πŸ˜„ Here it is in all its glory:
              It's not solid and I don't know why, its in 4506 'entities'! I'm not bothering with the vents and mounting holes now; I can do them later on the milling machine and lathe, what does it need for 3D printing?
              I've added the rounded lip on the edge of the bell mouth as an afterthought but I can't get rid of the joining lines; how do erase them?
              Sub Stack11v6.skp
              • TeigT Offline
                Teig
                When I can figure out how to install those extensions I'll do mine then πŸ˜• Or do you mean I can click on it and download it from my previous post? You have facility for interactive editing then? WOW 😲
                • TeigT Offline
                  Teig
                  I'm trying to work my way through that list but can't get rid of this guide. I went inside the mounting flange to try to erase it from the inside, no luck 😒
                  • TeigT Offline
                    Teig
                    Of course, thanks to the folk who've contributed πŸ˜„
                      So simple!
                      Goto the PluginStore (up right page corner)
                      Put the name of the plugin inside the engine research
                      When you have find it, load it in your computer
                      Launch SU
                      Menu Windows /Preferences/ Extension/Install Extension
                      That 's all! πŸ˜„
                      You can use the plugin directly! πŸ€“
                      Thx for the V6! β˜€
                      Advantage of old versions is that you can use Plugins who are maybe not adapted to the last version!
                      (Ps @ Pbacot
                      I have for habit to wait 6 month before use a new version! πŸ’š
                      Color by Z and Random Painter by Chris Fullmer (don't know if they works inside the 2015 ! πŸ˜’
                      • TeigT Offline
                        Teig
                        So simple!
                        Launch SU
                        Menu Windows /Preference/ Extension/Install Extension
                        That 's all! πŸ˜„
                        You can use the plugin! πŸ€“
                        Thx for the V6! β˜€
                        (Ps @ Pbacot
                        [attachment=1:2yrxtti7]<!-- ia1 -->donutsv6.jpg<!-- ia1 -->[/attachment:2yrxtti7]
                        You're welcome Pilou and thank you so much, it's so easy when you know how πŸ˜„ The bell mouth has reported as solid!
                        Edit: i went back into it and tried it, it wasn't solid anymore 😐 I've rerun SolidSolver and renamed it: [attachment=0:2yrxtti7]<!-- ia0 -->Sub Stack11v6solid.skp<!-- ia0 -->[/attachment:2yrxtti7]
                          To remove ALL guide lines and points use the menu item:
                          Edit > Delete Guides
                          While they don't directly affect an object's solidity they are best removed...
                          With that you have a solid...
                            d12dozr
                            Teig, I would encourage you to finish the model in Sketchup so there is no more work after 3D printing. You almost had it there once, you can do it again. πŸ˜„ The beauty of 3D printing is a finished model, straight off the printer.
                            What kind of machine will you be printing it with?
                            • TeigT Offline
                              Teig
                              I have no idea what machine it is, all I know is that it is my mate's brother's printer and he got it as an unfinished kit.
                              I (think) I know what I'm doing now so I'll do the vents later. You're right, it is far easier to do them at this stage.
                                d12dozr
                                Ok, so it's a desktop printer. The reason I asked is on that kind of printer, the printer will need some kind of support to hold up the bell shape while printing. The support material is made of the same plastic, and you'll have to remove it by hand.
                                You should be aware of this, as you may need to make your design to take support removal into account. Here is an image of a T-rex head with support material:
                                http://www.3ders.org/images/isis-one-desktop-3d-printer-5.jpg
                                ...and the same model with the support material removed.
                                http://www.3ders.org/images/isis-one-desktop-3d-printer-10.jpg
                                The gap under your bell shape is pretty small, and if it needs to be cleaned out you may be better off making the base and the bell shape in two different pieces that snap together.
                                If you were making this on a commercial powder printer, you could just remove the support powder with compressed air...easy peasy. πŸ‘
                                • TeigT Offline
                                  Teig
                                  OK... that's a curve ball... 😲 What are the rules for support material then? I think it's fairly obvious I know zilch about 3D printing.
                                  But... the snap-together idea would make it easier to assemble, on the car, hunched over, in a tight space (this is designed to go on a 1976 mini car). I imagine there is some kind of template for clicky catch arrangement?
                                    d12dozr
                                    Do yourself a favor and learn a little...watch the videos on this page, or at least the Filament printing one. Heck, spend $5 and get the ebook in my signature. #ShamelessPlug In a few hours you'll understand a lot more about how the process works, and how models need to be made in order to be printable, and you can keep all of your hair 😎
                                    There's not a template for making a snap fit, but here's a hint. You'll want to leave a ~0.3mm gap in between the parts to allow the parts to fit tightly, but not so tight they won't fit together.
                                      Anton_S
                                      [attachment=0:2dlsulxo]<!-- ia0 -->donutsv6.jpg<!-- ia0 -->[/attachment:2dlsulxo]
                                      Eh Pilou! Looks like you like colours πŸ˜„
                                      • TeigT Offline
                                        Teig
                                        Well I bit the bullet and bought your book for the grand sum of less than a pint of beer πŸ˜„ I've had another thought: If I made them screw together it would make it easier for assembly and disassembly. Time for a look into creating threads in SU πŸ€“ do I set the same kind of ~0.3mm tolerance for threads? I'll go look around.
                                          cadmunkey
                                          Just bought it also. Looking to buy a small 3d printer soon so finding your book came just at the right time, thanks πŸ˜‰
                                            d12dozr
                                            Thanks! πŸ‘
                                            For making threads, I'd start a little higher, like 0.5mm. You may have to tweak that after printing and testing though. You may be able to find and repurpose a model with threads from the 3D Warehouse or Thingiverse. I explain how to do that in Chapter 5.
                                            Thank you too, I hope it helps you! β˜€
                                            • 2 / 8
