    Problems with a half-torus
    156 Posts 11 Posters 18.3k Views 11 Watching
    • TeigT Offline
      Teig
      @tig said:
      Extra tips:
      Model so the faces' fronts are 'outwards' - context-menu 'reverse'...
      Depending on the Style settings the front color is generally 'off-white' and the back color 'bluish' - your faces look like 'backs'...
      I have reversed the face of the bell if that's what you mean TIG:
      http://i1006.photobucket.com/albums/af190/Nursi555/A Mini/SubStack8bellreversed_zps6652d59a.jpg
      • cottyC Offline
        cotty
        It's not a solid (no thickness , internal faces, ...) so you will not be able to print it with a 3d printer.
        my SketchUp gallery
          d12dozr
          @teig said:
          If anyone wants to run an eye over it for errors at the 3D printing stage I'd be much obliged
          I had a quick look...your model needs to be "Solid" to be 3D printable. Right now, you have a bunch of single-face walls with no thickness that will not print. You have to actually create the desired wall thickness for it to print properly.
          See this link and my attachment for more details: http://www.dummies.com/how-to/content/understanding-solid-objects-in-google-sketchup-8.html
          http://goo.gl/f7ooYh
          • TeigT Offline
            Teig
            I see what you mean. Sort of. Until you pointed it out I thought the area under the bellmouth was solid: how can I make it solid? I just know the push/pull of Follow tool will be a nightmare...
            I don't/ can't see what the internal face is that I need to delete?
              d12dozr
              Teig, the bottom of the bell was likely not formed when performing the follow me operation at too small of a scale.
              Does the center have a hole like a donut? Assuming so, here's how I'd make the overall shape:
              Click to view full size
              After you run the follow me tool, you're left with a solid that you can add the bottom holes to.
                Aaaah, you have saved as 2015! ๐Ÿ˜ฎ
                So owners of other versions can't reload your file! ๐Ÿ˜ข
                It's so easy to save as V6 for a more large audience! ๐Ÿ˜„
                • TeigT Offline
                  Teig
                  Gotcha! I think! Draw the profile at the very start. I've been trying for three hours now to put an arc under the bellmouth! ๐Ÿ˜’
                  • TeigT Offline
                    Teig
                    Oops! ๐Ÿ˜ณ I'll try again with an older version.
                      Pilou,it's long past time for you to catch up to the rest of the world. ๐Ÿ˜‰
                      • pbacotP Offline
                        Pilou, doesn't your computer run 2015? Before I even start using some versions, I get a copy of the latest just so I can open files from others (and also to try it out some). I then back-save a file myself if I really want to play with it, using my current plugin and setup.
                          d12dozr
                          You could use JointPushPull plugin to thicken a curved surface, but starting with a new profile is much cleaner and probably faster.
                          • TeigT Offline
                            Teig
                            I eventually got it sorted (hope), thanks to you folks. It really does look like the perfect bellmouth now - I couldn't sleep last night I was so excited ๐Ÿ˜„
                            I'm at work now; I'll put the (v6) .skp up later.
                              d12dozr
                              Nice! ๐Ÿ˜
                                Nearly there... ๐Ÿ˜„
                                I purged the model [Model Info > Statistics...]
                                I erased all guides.
                                I then regrouped the geometry.
                                It reported as a non-solid.
                                I suspected some un-faced edge[s] have been left hanging around...
                                I ran SolidSolver on it and it removed some 101 Un-faced or Coplanar edges.
                                Then it reported as a solid.
                                Simply using CleanUp would probably have made it a solid too...
                                It is now suitable for 3d printing...
                                • TeigT Offline
                                  Teig
                                  I know it's not sensational or a spectacular Sketchup item but it's big to me ๐Ÿ˜„ Here it is in all its glory:
                                  It's not solid and I don't know why, its in 4506 'entities'! I'm not bothering with the vents and mounting holes now; I can do them later on the milling machine and lathe, what does it need for 3D printing?
                                  I've added the rounded lip on the edge of the bell mouth as an afterthought but I can't get rid of the joining lines; how do erase them?
                                  Sub Stack11v6.skp
                                  • TeigT Offline
                                    Teig
                                    When I can figure out how to install those extensions I'll do mine then ๐Ÿ˜• Or do you mean I can click on it and download it from my previous post? You have facility for interactive editing then? WOW ๐Ÿ˜ฒ
                                    • TeigT Offline
                                      Teig
                                      I'm trying to work my way through that list but can't get rid of this guide. I went inside the mounting flange to try to erase it from the inside, no luck ๐Ÿ˜ข
                                      • TeigT Offline
                                        Teig
                                        Of course, thanks to the folk who've contributed ๐Ÿ˜„
                                          So simple!
                                          Goto the PluginStore (up right page corner)
                                          Put the name of the plugin inside the engine research
                                          When you have find it, load it in your computer
                                          Launch SU
                                          Menu Windows /Preferences/ Extension/Install Extension
                                          That 's all! ๐Ÿ˜„
                                          You can use the plugin directly! ๐Ÿค“
                                          Thx for the V6! โ˜€
                                          Advantage of old versions is that you can use Plugins who are maybe not adapted to the last version!
                                          (Ps @ Pbacot
                                          I have for habit to wait 6 month before use a new version! ๐Ÿ’š
                                          Color by Z and Random Painter by Chris Fullmer (don't know if they works inside the 2015 ! ๐Ÿ˜’
                                          • TeigT Offline
                                            Teig
                                            So simple!
                                            Launch SU
                                            Menu Windows /Preference/ Extension/Install Extension
                                            That 's all! ๐Ÿ˜„
                                            You can use the plugin! ๐Ÿค“
                                            Thx for the V6! โ˜€
                                            (Ps @ Pbacot
                                            [attachment=1:2yrxtti7]<!-- ia1 -->donutsv6.jpg<!-- ia1 -->[/attachment:2yrxtti7]
                                            You're welcome Pilou and thank you so much, it's so easy when you know how ๐Ÿ˜„ The bell mouth has reported as solid!
                                            Edit: i went back into it and tried it, it wasn't solid anymore ๐Ÿ˜ I've rerun SolidSolver and renamed it: [attachment=0:2yrxtti7]<!-- ia0 -->Sub Stack11v6solid.skp<!-- ia0 -->[/attachment:2yrxtti7]
                                            • 2 / 8
