    Problems with a half-torus
    156 Posts 11 Posters 35.6k Views 11 Watching
      Aaaah, you have saved as 2015! ๐Ÿ˜ฎ
      So owners of other versions can't reload your file! ๐Ÿ˜ข
      It's so easy to save as V6 for a more large audience! ๐Ÿ˜„
      • TeigT
        Teig
        Gotcha! I think! Draw the profile at the very start. I've been trying for three hours now to put an arc under the bellmouth! ๐Ÿ˜’
        • TeigT
          Teig
          Oops! ๐Ÿ˜ณ I'll try again with an older version.
            Pilou,it's long past time for you to catch up to the rest of the world. ๐Ÿ˜‰
            • pbacotP
              Pilou, doesn't your computer run 2015? Before I even start using some versions, I get a copy of the latest just so I can open files from others (and also to try it out some). I then back-save a file myself if I really want to play with it, using my current plugin and setup.
                d12dozr
                You could use JointPushPull plugin to thicken a curved surface, but starting with a new profile is much cleaner and probably faster.
                http://goo.gl/f7ooYh
                • TeigT
                  Teig
                  I eventually got it sorted (hope), thanks to you folks. It really does look like the perfect bellmouth now - I couldn't sleep last night I was so excited ๐Ÿ˜„
                  I'm at work now; I'll put the (v6) .skp up later.
                    d12dozr
                    Nice! ๐Ÿ˜
                      Nearly there... ๐Ÿ˜„
                      I purged the model [Model Info > Statistics...]
                      I erased all guides.
                      I then regrouped the geometry.
                      It reported as a non-solid.
                      I suspected some un-faced edge[s] have been left hanging around...
                      I ran SolidSolver on it and it removed some 101 Un-faced or Coplanar edges.
                      Then it reported as a solid.
                      Simply using CleanUp would probably have made it a solid too...
                      It is now suitable for 3d printing...
                      • TeigT
                        Teig
                        I know it's not sensational or a spectacular Sketchup item but it's big to me ๐Ÿ˜„ Here it is in all its glory:
                        It's not solid and I don't know why, its in 4506 'entities'! I'm not bothering with the vents and mounting holes now; I can do them later on the milling machine and lathe, what does it need for 3D printing?
                        I've added the rounded lip on the edge of the bell mouth as an afterthought but I can't get rid of the joining lines; how do erase them?
                        Sub Stack11v6.skp
                        • TeigT
                          Teig
                          When I can figure out how to install those extensions I'll do mine then ๐Ÿ˜• Or do you mean I can click on it and download it from my previous post? You have facility for interactive editing then? WOW ๐Ÿ˜ฒ
                          • TeigT
                            Teig
                            I'm trying to work my way through that list but can't get rid of this guide. I went inside the mounting flange to try to erase it from the inside, no luck ๐Ÿ˜ข
                            • TeigT
                              Teig
                              Of course, thanks to the folk who've contributed ๐Ÿ˜„
                                So simple!
                                Goto the PluginStore (up right page corner)
                                Put the name of the plugin inside the engine research
                                When you have find it, load it in your computer
                                Launch SU
                                Menu Windows /Preferences/ Extension/Install Extension
                                That 's all! ๐Ÿ˜„
                                You can use the plugin directly! ๐Ÿค“
                                Thx for the V6! โ˜€
                                Advantage of old versions is that you can use Plugins who are maybe not adapted to the last version!
                                (Ps @ Pbacot
                                I have for habit to wait 6 month before use a new version! ๐Ÿ’š
                                Color by Z and Random Painter by Chris Fullmer (don't know if they works inside the 2015 ! ๐Ÿ˜’
                                • TeigT
                                  Teig
                                  So simple!
                                  Launch SU
                                  Menu Windows /Preference/ Extension/Install Extension
                                  That 's all! ๐Ÿ˜„
                                  You can use the plugin! ๐Ÿค“
                                  Thx for the V6! โ˜€
                                  (Ps @ Pbacot
                                  [attachment=1:2yrxtti7]<!-- ia1 -->donutsv6.jpg<!-- ia1 -->[/attachment:2yrxtti7]
                                  You're welcome Pilou and thank you so much, it's so easy when you know how ๐Ÿ˜„ The bell mouth has reported as solid!
                                  Edit: i went back into it and tried it, it wasn't solid anymore ๐Ÿ˜ I've rerun SolidSolver and renamed it: [attachment=0:2yrxtti7]<!-- ia0 -->Sub Stack11v6solid.skp<!-- ia0 -->[/attachment:2yrxtti7]
                                    To remove ALL guide lines and points use the menu item:
                                    Edit > Delete Guides
                                    While they don't directly affect an object's solidity they are best removed...
                                    With that you have a solid...
                                      d12dozr
                                      Teig, I would encourage you to finish the model in Sketchup so there is no more work after 3D printing. You almost had it there once, you can do it again. ๐Ÿ˜„ The beauty of 3D printing is a finished model, straight off the printer.
                                      What kind of machine will you be printing it with?
                                      • TeigT
                                        Teig
                                        I have no idea what machine it is, all I know is that it is my mate's brother's printer and he got it as an unfinished kit.
                                        I (think) I know what I'm doing now so I'll do the vents later. You're right, it is far easier to do them at this stage.
                                          d12dozr
                                          Ok, so it's a desktop printer. The reason I asked is on that kind of printer, the printer will need some kind of support to hold up the bell shape while printing. The support material is made of the same plastic, and you'll have to remove it by hand.
                                          You should be aware of this, as you may need to make your design to take support removal into account. Here is an image of a T-rex head with support material:
                                          http://www.3ders.org/images/isis-one-desktop-3d-printer-5.jpg
                                          ...and the same model with the support material removed.
                                          http://www.3ders.org/images/isis-one-desktop-3d-printer-10.jpg
                                          The gap under your bell shape is pretty small, and if it needs to be cleaned out you may be better off making the base and the bell shape in two different pieces that snap together.
                                          If you were making this on a commercial powder printer, you could just remove the support powder with compressed air...easy peasy. ๐Ÿ‘
                                          • TeigT
                                            Teig
                                            OK... that's a curve ball... ๐Ÿ˜ฒ What are the rules for support material then? I think it's fairly obvious I know zilch about 3D printing.
                                            But... the snap-together idea would make it easier to assemble, on the car, hunched over, in a tight space (this is designed to go on a 1976 mini car). I imagine there is some kind of template for clicky catch arrangement?
