    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 13.2k Views 19 Watching
    • BoxB Offline
      Yep that works.
        Gábor
        @box said:
        Yep that works.
        (Although it looked better before 😄 )
        • BoxB Offline
          I just changed it so it was obvious. I might have a fiddle when I have time to make it look nice.
          I must say, if you can get the swipe to work this would be a godsend on mobile devices. For me it actually works better and faster on my phone than this old laptop I'm stuck with.
            Gábor
            Will see..... 😉
              Conductor is missing on the top view! 😉
              • Rich O BrienR Online
                [sw:2nmm7lj7]UiTqF1eYwKc9q5x[/sw:2nmm7lj7]
                Specular Tests with various lighting settings
                  [sw:4segqeqa]zi8EvGSru7vWBPS[/sw:4segqeqa]
                  Mixed specular materials
                    Cool stuff, Rich.
                    That last one loaded faster for me than any of the others have over the last few days.
                    • BoxB Offline
                      Here's one as a colour test.
                      Compared to the look of it in SU directly it is quite flat.
                      Certainly a very hand tool.
                      [sw:d92pbvyj]C879twdkomuSZmh[/sw:d92pbvyj]
                      • ntxdaveN Offline
                        ntxdave
                        Box I really like your last one. However, when it first loads (after clicking it) it is all black until I click the screen and then it appears. The background also disappears.
                        @Rich - I think this is really headed in a good direction.......
                        Press F1...thank me later
                        • ntxdaveN Offline
                          ntxdave
                          This one loads really fast for me as well
                            @box
                            play with the transparency and spec of the glass. mix with lights making sure the total light is 100 or less
                            don't add hemi at 100 + spot at 100 etc...
                              @box
                              set the hemi to lightblue and light yellow at 60.
                              set spec/shiness for material to 20 and the opacity to 60 or so
                                [sw:3gma5qi3]xIFwhX4yO072d4F[/sw:3gma5qi3]
                                • ntxdaveN Offline
                                  ntxdave
                                  Rich, I really like this one too. I like the color highlighting and the background.
                                  After it loads I see kind of a dark monochrome of the 3d model until I rotate it or do something like that. I am using IE 11. Does that have something to do with it or is that supposed to happen?
                                  I will go try it in Chrome and see if I see the same thing......
                                  OK - I tried it in Chrome and saw the same thing......
                                  • ntxdaveN Offline
                                    ntxdave
                                    @rich o brien said:
                                    @box
                                    Are you guys using a renderer or what the heck are you talking about (remember that I still consider myself a newbie to SU so I am trying to learn all I can)?
                                    • BoxB Offline
                                      Rich yeah I see there are lots of possibilities to edit the lighting and such, had a bit of a fiddle but have to be elsewhere now.
                                      Dave, the lights come on when you move it, hence the black until you do.
                                      And the background changes because what you are seeing is a still snapshot from the model, then you see the viewer background.
                                      They are settings within the viewer that we are testing.
                                        Gábor
                                        Yes, the viewer is a sort-of "real-time renderer" using the capabilities of WebGL. Of course it has far less sophisticated settings than the professional not real-time rendering software like Thea or V-Ray but still has some simple setting options for materials, lights, etc.
                                          Gábor
                                          BTW now it has the "fullscreen" option enabled (cross arrows).
                                          (If new functions like the fullscreen do not work, simply erase browser cache to let the new javascript load.)
                                            Full-screen X works - opens a new tab.
                                            So no need to press Esc to back step ?
                                            • 13
                                            • 14
                                            • 4 / 14
