    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 579 Posters 4.9m Views 581 Watching
    • fredo6F Offline
      Oxer,
      Thanks very much. This will go in next update
        mjvanderploeg
        Dear all,
        got a problem using libfredo6 with fredo tools and round corner. Error message is that libfredo6 is not 6.3 or higher, while the latest 6.4 is installed. See attached files. Can you help?
        error message 1
        installed libfredo6 version
        error message 2
        log file
        • fredo6F Offline
          Actually the message should say "you must install LibFredo6 6.4". So it's not a problem of version.
          The issue seems to come from a wrong installation of FredoTools.
          Did you install both LibFredo6 and FredoTools in the same directory?
          I suggest you have a look at the footprint and possibly cleanup and reinstall FredoTools (ideally from the PluginStore).
            mjvanderploeg
            Fredo,
            Thanks for your quick reply. A few things I forgot to mention. I'm running Sketchup 2013 in LinuxMint 17, using wine.
            This is the contents of the Plugin folder:
            drwxr-xr-x 3 margriet margriet 4096 nov 24 21:23 Fredo6_FredoTools
            -rw-r--r-- 1 margriet margriet 1633 okt 18 00:28 Fredo6_FredoTools.rb
            drwxr-xr-x 4 margriet margriet 4096 nov 24 21:23 Fredo6_!LibFredo6
            -rw-r--r-- 1 margriet margriet 12896 okt 18 00:17 Fredo6_!LibFredo6.rb
            drwxr-xr-x 4 margriet margriet 4096 nov 24 21:24 Fredo6_RoundCorner
            -rw-r--r-- 1 margriet margriet 1633 okt 18 15:57 Fredo6_RoundCorner.rb
            drwxr-xr-x 4 margriet margriet 4096 nov 22 09:32 su_advancedcameratools
            -rw-r--r-- 1 margriet margriet 1715 aug 6 2013 su_advancedcameratools.rb
            drwxr-xr-x 8 margriet margriet 4096 nov 22 09:32 su_dynamiccomponents
            -rw-r--r-- 1 margriet margriet 1717 aug 6 2013 su_dynamiccomponents.rb
            drwxr-xr-x 3 margriet margriet 4096 nov 22 09:33 su_sandbox
            -rw-r--r-- 1 margriet margriet 1663 aug 6 2013 su_sandbox.rb
            drwxr-xr-x 2 margriet margriet 4096 nov 22 09:33 su_webtextures
            -rw-r--r-- 1 margriet margriet 1299 aug 6 2013 su_webtextures.rb
            So all plugins are in the same folder.
            The Fredotools are indeed the latest version from the plugin store
            -rw-r--r-- 1 margriet margriet 305756 nov 24 20:08 FredoTools_v2.4a.rbz
            As the sketchucation tools do not work on my machine, I manually downloaded your plugins from the store and installed them via the Window -> preferences -> extensions menu.
            • fredo6F Offline
              I think this may be due to Linux, where the ! charcater is actually not the considered going before alphanumeric characters. This means that FredoTools seems to be loaded before LibFredo6.
              The only thing I see would be to simply remove the file Fredo6_FredoTools.rb(which is actually not useful). LibFredo6 will load it.
              • Spirou4DS Offline
                Spirou4D
                No my dear, your last release isn't 6.4a!!!! There are a mistake.
                Take alook on your lib, please.
                • BoxB Offline
                  Looks it to me.
                    Justusson
                    does anyone know why I'm getting dotted lines, when drawing with TOS, and not filled lines?
                    (Both with arch, rectangle sometimes and so forth,..)
                    These dotted lines, much like hidden lines don't affect the surface at all. They need to be filled in afterwards manually. They apply themselves to the curved surfaces, but don't do anything more than that.
                    Hope anyone can help me,
                    Best regards/
                      It sounds to me as if you have it set to draw construction lines instead of edges. You ought to spend some time looking at the info here. Especially look at the Quickcard PDF file available in the first post of the thread.
                        Justusson
                        Excellent, thanks Dave R, just was I was looking for. Hadn't seen the Construction lines/ Plain Lines.
                        Best /
                        Christoffer
                          sahli85
                          libfredo6 don't work 😢
                            Please check for proper installation...
                            BUT...
                            I'm not sure if this is relevant...
                            When SketchUp v2014 came in it should have fixed the issues with Windows users having accented characters in their user names.
                            Unfortunately, it was found that sometimes it still failed in some circumstances...
                            One issue was with a single-quote ['] in user names ! [like "B'Boss"]...
                            BUT I thought this had been addressed in later versions...
                            Also some "FILE" values etc fail if the result is not forced into UTF-8 encoding in the script itself - this is system dependent...
                            Any SUp guys care to comment ?
                            thomthom ??
                            • fredo6F Offline
                              The prolem comes from the quote in the username, which clashes with string parsing.
                              So not a non-ascii problem, but even worse, as I never thought quotes where allowed in usernames.
                                User-names and folder paths with single quotes ['] are allowed e.g. "Rich_O'Brien" [but still ill-advised!] - BUT all double quotes ["] are prohibited on PC and MAC...
                                As well as " - other prohibited path-name characters are /:|?¬* and an initial <space>, several others [like % and @] are best avoided...
                                The ' did cause some SUp 'finding Plugins folder' issues, but I think they might be fixed...
                                BUT any Ruby or JS string parsing should use "" around text to avoid the ' failures ?
                                • fredo6F Offline
                                  @sahli85
                                  Could you test the attached fix to see if this fixes the problem of your username with a quote.
                                  Just drop the attached file in the folder Fredo6_!LibFredo6
                                  Lib6Core.rb
                                  • Spirou4DS Offline
                                    Spirou4D
                                    No my Dear, your last release isn't 6.4a!!!! There are a mistake.
                                    Take a look on your lib files and particularly the init file (you can read 6.3 and this cause error in Fredo6 updater), please!!!
                                      I'm sure Fredo will comment... 😒
                                      But in the files in the Lib folder, for my v6.4a there is no reference to 6.3 ?
                                      Also there is no ' ini' file ??
                                      What did you mean by that ?
                                      The RB file in the Lib folder which sets the 'version' is:
                                      'LibFredo6.plugin'
                                      and that contains:
                                      VERSION = 6.4a
                                      The only place ' 6.3' is mentioned at all is in the version-checker in the loader RB itself [ Fredo6_!LibFredo6.rb] - which says:
                                      "...UI.messagebox "You must install LibFredo6 version **6.3 or higher** to run #{f6__base}"..."
                                      • and 6.4a is > 6.3 ?
                                      Please be more specific with the nature of this report - no one else can see your issue...
                                      • Spirou4DS Offline
                                        Spirou4D
                                        Yes TIG,
                                        When you download the LibFredo6 here: http://sketchucation.com/plugin/903-libfredo6
                                        and you read the Fredo6_!LibFredo6.rb, you read:
                                        (Name : Fredo6_!LibFredo6.rb
                                        Original Date : 20 Aug 2008 - version 3.0
                                        Type : Ruby Library
                                        Description : Top loading module for all Library utilities of Fredo6's scripts
                                        Usage : See Tutorial and Quick Ref Card in PDF format)
                                        and
                                        at the end:
                                        (UI.messagebox "You must install LibFredo6 version 6.3 or higher to run #{f6__base}")
                                        And in my SketchUp 2014, the Fredo6_updater tell me always to download the last release 6.4.
                                        I make it with SU internal updater but always when I load SU, I Have always the 6.3a release: NO CHANGE!
                                        Then I remove the script from my APPDATA folder and I download directly the rbz file on my desktop and I make the install with SU extension selector. BUT ALWAYS 6.3a release, NO CHANGE and always your addon that tell me to update the LibFredo6 plugin!!!!!
                                        • fredo6F Offline
                                          @Spirou4D
                                          The best is to check the About box for LibFredo6. You probably have 6.4a installed.Tell me if otherwise and if you have problems with the plugins (if so the best is to show a snapshot of your plugin directory)
                                          As TIG said, the message includes reference to 6.3 and higher, but this is normal.
                                            bcnguyen
                                            I need help.
                                            I successfully installed 6.4a LibFredo6
                                            but the tools are not displayed on the toolbar, so how to use plugins in LibFredo6, how do these tools to display and use.
                                            thank you!
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 111
                                            • 112
                                            • 45 / 112
