    Put it back on a even plan
    20 Posts 6 Posters 1.1k Views 6 Watching
    • F
      FabienM
      Hey,
      ( i post a response but it doesn't appear,
      and i don't have saw the other responses ).
      Thank you very much ely862me, d12dozr, DaveR,
      Rich o Brien for the embedded code for the tutorial video,
      thanks for your help and your time.
      That's exactly resolve my problem,
      i appreciate really your help.
      Now i just have to work to up grade my knownledge of SU,
      and probably upgrade my old SU 6 Pro.
      Thanks again, have a nice day.
      • ely862meE
        ely862me
        @rich o brien said:
        @Eli
        The forum supports screenr.com embeds using the last bit of the emdbed code....
        [screenr ]FOFN[/screenr]
        ...wrapping the URL like the above
        I knew it supports, I have done it in the past, but it was way more difficult than now.
        I will remember this next time because it is easier now.
        Thanks !
        Elisei (sketchupper)
        Come and See EliseiDesign
        • BoxB
          There is also this option.
          http://i155.photobucket.com/albums/s296/storeben/SU/Spp.gif
          • ely862meE
            ely862me
            Well, that is something that would be way more faster . What is that ? I need it !
            • massimoM
              massimo Moderator
              The code was posted somewhere here by sdmitch if I remember well.
              I've just done a .rb file. Here it is.
              Raddrizza.rb
              • ely862meE
                ely862me
                Excellent ! Thank you ! But can you make it to work like Box' did ?
                • massimoM
                  massimo Moderator
                  Sorry, I don't have SU installed atm and I don't recall exactly how it works. Which is the difference? Maybe Box has something different?
                  • ely862meE
                    ely862me
                    Yours works only for one group/Component. And it would be nice to have them aligned and not having them stacked one over another.
                    • massimoM
                      massimo Moderator
                      Ah, ok. So the Box's one is something else.
                      • BoxB
                        How much is it worth to know what it is!!!
                        I'll have to remember where I got it from. From memory it was just a beta from Mattc, part of a full paper modelling plugin that he has never finished. It only works on groups and is a touch erratic. If I can find the thread where he posted it I will come back here.
                          try searching using this....
                          404 Not Found
                          (rich-o-brien.com)
                          • BoxB
                            That's a nice search feature Rich, but it still needs to know what you are looking for.
                            I found it using the normal advanced search.
                            Not bad memory for a 3 year old thread.
                            The code is in there and he added it as an .rb in the last post of the thread.
                            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=41419
                            • ely862meE
                              ely862me
                              Great ! Thanks !
                              Now I need to figure it out how to make it work with components ! Or changing the components to groups.
                              • F
                                FabienM
                                Thanks Rich for the search feature,
                                the Ruby's script : " Group to XY plane " work perfectly.
                                I'm on SU 8 ( not SU 6 than i thinking before, oups ).
