    Put it back on a even plan
    20 Posts 6 Posters 973 Views 6 Watching
      d12dozr
      I think you want something like the Flattery plugin: http://www.pumpkinpirate.info/flattery/
      http://goo.gl/f7ooYh
      • ely862meE
        ely862me
        Oh, I understand now. I have done something like this in the past and I will do it again in a couple of weeks.
        First thing to do is to create the shapes in only one plane and don't change the axes or don't rotate them inside the components. When you place it where you want just rotate it from outside.
        You will have to install Chris Fullmer's plugin Components onto faces.
        Then draw a rectangle, select that rectangle and select one of the shapes which has to be a component, then run the plugin Components onto each face. If you haven't change the initial shape axes, your shape will be aligned with the rectangle you have drawn. It is a tedious job, but it is a lot better than doing it manually.
        [screenr:2i6yxaqr]FOFN[/screenr:2i6yxaqr]
        Elisei (sketchupper)
        Come and See EliseiDesign
          @Eli
          The forum supports screenr.com embeds using the last bit of the emdbed code....
          [screenr]FOFN[/screenr]
          ...wrapping the URL like the above
          • F
            FabienM
            Hey,
            ( i post a response but it doesn't appear,
            and i don't have saw the other responses ).
            Thank you very much ely862me, d12dozr, DaveR,
            Rich o Brien for the embedded code for the tutorial video,
            thanks for your help and your time.
            That's exactly resolve my problem,
            i appreciate really your help.
            Now i just have to work to up grade my knownledge of SU,
            and probably upgrade my old SU 6 Pro.
            Thanks again, have a nice day.
            • ely862meE
              ely862me
              @rich o brien said:
              @Eli
              [screenr ]FOFN[/screenr]
              I knew it supports, I have done it in the past, but it was way more difficult than now.
              I will remember this next time because it is easier now.
              Thanks !
              • BoxB
                There is also this option.
                http://i155.photobucket.com/albums/s296/storeben/SU/Spp.gif
                • ely862meE
                  ely862me
                  Well, that is something that would be way more faster . What is that ? I need it !
                  • massimoM
                    massimo Moderator
                    The code was posted somewhere here by sdmitch if I remember well.
                    I've just done a .rb file. Here it is.
                    Raddrizza.rb
                    • ely862meE
                      ely862me
                      Excellent ! Thank you ! But can you make it to work like Box' did ?
                      • massimoM
                        massimo Moderator
                        Sorry, I don't have SU installed atm and I don't recall exactly how it works. Which is the difference? Maybe Box has something different?
                        • ely862meE
                          ely862me
                          Yours works only for one group/Component. And it would be nice to have them aligned and not having them stacked one over another.
                          • massimoM
                            massimo Moderator
                            Ah, ok. So the Box's one is something else.
                            • BoxB
                              How much is it worth to know what it is!!!
                              I'll have to remember where I got it from. From memory it was just a beta from Mattc, part of a full paper modelling plugin that he has never finished. It only works on groups and is a touch erratic. If I can find the thread where he posted it I will come back here.
                                try searching using this....
                                404 Not Found
                                (rich-o-brien.com)
                                • BoxB
                                  That's a nice search feature Rich, but it still needs to know what you are looking for.
                                  I found it using the normal advanced search.
                                  Not bad memory for a 3 year old thread.
                                  The code is in there and he added it as an .rb in the last post of the thread.
                                  http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=41419
                                  • ely862meE
                                    ely862me
                                    Great ! Thanks !
                                    Now I need to figure it out how to make it work with components ! Or changing the components to groups.
                                    • F
                                      FabienM
                                      Thanks Rich for the search feature,
                                      the Ruby's script : " Group to XY plane " work perfectly.
                                      I'm on SU 8 ( not SU 6 than i thinking before, oups ).
